do you need caster camber plates - Mustang Evolution
Old 10-22-2015, 08:06 AM   #1
Just received my new bmr springs and was wondering if you have to buy new caster camber plates. Our will my stock ones work. Springs will lower car by about 1 1/2 inches. Thanks
briansplace is offline   Reply With Quote
Old 10-22-2015, 08:07 AM   #2
Yes you need them.
Old 10-22-2015, 08:08 AM   #3
Forgot to add it's for a 2014 gt with 17,000 miles
Old 10-22-2015, 08:31 AM   #4
I have them on mine, same springs.
Old 10-22-2015, 09:22 AM   #5
Who did you guys go with for ccplates. Thanks
Old 10-22-2015, 09:36 AM   #6
Maximum Motorsports.
Old 10-22-2015, 09:42 AM   #7
camp70's Avatar
I went with the J&M adjustable ones, but the shop I had install them wasn't very fond of them. He said he thought they were kinda janky. Not sure what others think. He recommended I go with Maximum Motorsports. Curious of what others think
camp70 is offline   Reply With Quote
Old 10-22-2015, 10:34 AM   #8
Labrat's Avatar
I use the same plates and have had them now for almost 5 years with no problems.
Labrat is offline   Reply With Quote
Old 10-22-2015, 11:05 AM   #9
Do you like the bmr springs. And did it give you the 1 1/2" drop. Thanks for the replies looks like i will be ordering some cc plates tonight.
Old 10-22-2015, 02:39 PM   #10
olerodder's Avatar
Region: Oregon
No you do not need caster/camber plates for 1.5" drop.
I put Eibach Sportlines on my 14 TrakPak car 7000 miles ago with and have no issues.
After putting them in and letting them settle I had the Ford dealer check the alignment and the caster was +7.8 degrees...Ford spec's say +6.4 degrees to +7.9 degrees. Camber was -1.2 after the drop and the Ford spec is from -1.5 degrees to +0.0 degrees. I've helped 4 other late model Mustang guys drop their cars also with BMR and Eibach springs and not one needed caster/camber plates and all were within Ford Specs after the drop....If you are going to track the car then by all means get the plates....the best plates are Steeda and Maximum Motors Sports.....IMHO
Old 10-22-2015, 03:09 PM   #11
Grabber Blue5.0's Avatar
No they are not needed.
Old 10-22-2015, 03:52 PM   #12
Thank you very much for the info had time to cancel the order pretty much just a daily driver. Can put that money towards stall converter. Now just tring to figure out what converter to purchase
Old 10-22-2015, 04:02 PM   #13
olerodder's Avatar
Region: Oregon
Grabber Blue5.0 can steer you in that direction.
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Caster/Camber Plates...will they be a problem with this? Joel5.0 1979-1995 Mustang GT 4 10-22-2005 04:36 PM
Steeda Springs - Do I need caster camber plates? audioqueso Pre-2005 V6 Mustang 8 12-05-2003 05:34 PM
08:23 PM
