2015 "Brembos" on a 11-14 - Mustang Evolution
Old 10-22-2015, 08:29 PM   #1
The_Chech's Avatar
So for some of us that happened to have the 5.0 that didn't come with the brembos. I've stumbled onto a well what used to be a very cheap and easy way to get into a set of 4 piston ford "Brembos". I've finally figured out what has to be run in order to make these work. Mind you I got every thing for less then 300$ brand new. Click image for larger version
Name:	ImageUploadedByMustang Evolution1445567325.812508.jpg
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 10-22-2015, 08:45 PM   #2
Subd
Old 10-22-2015, 09:03 PM   #3
The_Chech's Avatar
Name:	ImageUploadedByMustang Evolution1445569313.956702.jpg
About to send them off to get powder coated before they go on 😁👍🏼. Not having big brakes on this car has been a never ending itch I couldn't scratch.
2011 Kona Blue Gt
IG - The_Chech
Old 10-22-2015, 09:21 PM   #4
oxford5pointoh's Avatar
That's sweet that they fit. What color you getting them coated?
Old 10-23-2015, 12:16 AM   #5
NewMtang's Avatar
Originally Posted by The_Chech View Post
Attachment 192679
2011 Kona Blue Gt
IG - The_Chech
_________________
Are you going to the 2016 American Muscle Car Show?
Old 10-23-2015, 05:13 AM   #6
The_Chech's Avatar
I should be for 2016, I wasn't able to this year.
2011 Kona Blue Gt
IG - The_Chech
Old 10-23-2015, 07:18 AM   #7
c_rizzle's Avatar
Are they plug & play ?
c_rizzle is offline   Reply With Quote
Old 10-23-2015, 10:34 AM   #8
OX1
specs on rims??
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
Old 10-23-2015, 10:38 AM   #9
kapcan2k's Avatar
Less then 300$ brand new. Wow I wish I could get a deal like that. I would love to add some brembos to my car.
kapcan2k is offline   Reply With Quote
Old 10-23-2015, 10:54 AM   #10
You can. eBay from Shelby American in LV. They lost a new set every other day it seems. 199.99 starting bid plus shipping.
Old 10-23-2015, 03:16 PM   #11
Noodles76's Avatar
I'd like to do that upgrade but then I would need new wheels.
Noodles76 is offline   Reply With Quote
Old 10-23-2015, 03:43 PM   #12
The_Chech's Avatar
As of now to make them fit, you'll need 11-14 Brembo brake lines, I went with Russell's front and rear lines, 11-14 Brembo specific rotors, 15-16 calipers, 15-16 brake pads (not sure if 11-14 Brembo pads work in these yet), and depending on wheels possibly a wheel spacer.
2011 Kona Blue Gt
IG - The_Chech
Old 10-23-2015, 03:50 PM   #13
The_Chech's Avatar
Originally Posted by OX1 View Post
specs on rims??
Here's the specs for the MMD 551c wheels that I have on mine.
Name:	ImageUploadedByMustang Evolution1445637029.527608.jpg
2011 Kona Blue Gt
IG - The_Chech
Old 10-23-2015, 09:35 PM   #14
olerodder's Avatar
Region: Oregon
Now all you need to do is upgrade your puny 11.8" rear discs to the GT500 13.8" and you'll have a great brake setup...and the rear can be done for about $300 also...and they fill up all of the empty space in the 20" wheels.
Picture on the left is the stock 11.8" discs and the one on the right is the 13.8" disc...the wheels are the 13/14 OE GT500's which are 20's.
Just a thought....................
Name:	2015-04-08 10.54.47.jpg
ID:	192704   Click image for larger version
Name:	2015-04-11 12.52.16.jpg
Old 10-24-2015, 07:24 AM   #15
i was going to post asking if any non track owners put the OE track brembos on their car and how they did it
good thread and awesome price
2013GTpremium is offline   Reply With Quote
Old 10-24-2015, 07:44 AM   #16
The_Chech's Avatar
Ole I have the bracket actually for that sitting in my office i just need to order the rotors and new pads
Old 10-24-2015, 09:58 AM   #17
kapcan2k's Avatar
2011 Kona Blue Gt
IG - The_Chech
I'm a noob in regards to brakes. Do you mind posting some links( like a vendor) to the brembo brake lines or russell brake lines you used for this.
Old 10-24-2015, 10:12 AM   #18
Oh yes, I need to get on this.
Question: would the 13.8" 2015 rear disks and calipers work on our 2011-14 stangs?
Old 10-24-2015, 10:29 AM   #19
olerodder's Avatar
Region: Oregon
I thought they only had 13" rear disc's, not 13.8.
I know the 15 has 3 different brake options....just didn't think they had the big rear brakes off the GT500.
Also, why do you want to use the rear 15 brake system as I thought it was the same as the 14....still has the single piston rear caliper?
Old 10-24-2015, 10:33 AM   #20
The calipers come with the auction, so I was just wondering.
It says 13.8" big brake upgrade, I'm just going off of what it says.
Name:	ImageUploadedByMustang Evolution1445704417.821545.jpg
Old 10-24-2015, 11:06 AM   #21
olerodder's Avatar
Region: Oregon
Attachment 192713
First I don't know if these would fit as the 15 is an IRS type rearend....second is that to be able to put 13.8" rotors on a 13/14 you need to move the caliper up about 2" inches...this can be done with the stock OE GT500 caliper bracket which you will need to disassemble the rearend to install it(take the axles out) so I just don't see why you would want to buy the calipers and lines since they are the same as your 13/14....wasted money in my book.
If you don't want to pull your axles this is the bracket you need to buy;
05 14 Mustang 14" Rear Brake Rotor Adapter Brackets GT Boss 302 GT500 V6 13 8" | eBay
Then all you need are the 13.8 disc's and pads..............use your same caliper and lines..................then you will have the same brakes as the 13/14 GT500.
Old 10-24-2015, 02:13 PM   #22
The_Chech's Avatar
This is the Bracket you need for the rear to run the 13.8 2013-21014 GT500 rear rotors. You reuse your stock calipers and brackets. Click image for larger version
Name:	ImageUploadedByMustang Evolution1445717544.634771.jpg
You can also use the actual brackets that come off the GT500 itself
2011 Kona Blue Gt
IG - The_Chech
Old 10-24-2015, 02:21 PM   #23
The_Chech's Avatar
Name:	ImageUploadedByMustang Evolution1445718048.971175.jpg
ID:	192720Click image for larger version
Name:	ImageUploadedByMustang Evolution1445718062.680204.jpg
2011 Kona Blue Gt
IG - The_Chech
Old 10-24-2015, 04:43 PM   #24
Dang, that adapter is overpriced. Thanks for the info.
Old 10-24-2015, 05:12 PM   #25
The_Chech's Avatar
Go look at the price of a whole Gt500 rear 13.8 brake setup and what all is involved in making it work. You might change your mind
2011 Kona Blue Gt
IG - The_Chech
Old 10-24-2015, 05:12 PM   #26
I did the same adapter. Man it sure makes the mod easier than pulling axle shafts. I felt like it was worth the price.
Old 10-24-2015, 05:22 PM   #27
Haha. I know guys. Two little adapters for $65/piece. Do you guys recommend those centric rotors from rock auto? And what pads should I go with?
Old 10-24-2015, 05:30 PM   #28
I went with the bendix rotors from rock auto. Only thing I didn't like was that they are completely raw. So they would look like crap if you don't paint the parts that don't contact the pad. So I painted mine with an engine paint and they still look good. Went with hawk pads, I don't know that I recommend them as they create a TON of brake dust. But they don't squeak so that's a plus.
Old 10-24-2015, 05:50 PM   #29
olerodder's Avatar
Region: Oregon
You can buy the OE GT500 adapters for $150, drain the rearend, take off the cover, take out the C clips, then pull the whole brake system off the housing, put the GT500 adapters on, put the brake system back together, put the axles back in, put the C clips in, put the rear end cover back on, spend money for the fluid and friction modifier...........this would take you a whole day when you can buy the brackets for $130, buy OE disc's from Ford for $182 for the pair and $55 for the ceramic pads...............took me about 1 hour to change everything and the hardest part was screwing the caliper pistons back in to put the new pads on..well worth it if you ask me. Also, please prime and paint the raw aluminum before you put them on....since alot of you guys live East of the Rockies...
Old 10-24-2015, 06:09 PM   #30
The_Chech's Avatar
This is the whole reason I picked up a set.
Old 10-24-2015, 06:15 PM   #31
Copy dudes. Thanks.
Old 10-24-2015, 07:55 PM   #32
kapcan2k's Avatar
2011 Kona Blue Gt
IG - The_Chech
The ebay listing by shelby includes the 2015 rotors. Did you use the 2015 rotors that come with the calipers? I ask because you state that 11-14 specific brembo rotors are needed. Just wondering why the 2015 rotors can not be used with the 2015 calipers. Thanks again for all the info you have provided.
Old 10-24-2015, 08:31 PM   #33
The_Chech's Avatar
You cant use the 2015 rotors because like wheels, rotors have different offsets. that being said once you mount up the caliper from the 2015-2016 on a 2011-2014 spindle it is set up in the right spot to run the 11-14 rotors. I wish I had a picture of them side by side because the 2015 rotors sit to far back for the caliper to mount onto the spindle.
Hopefully this explains how this works a bit better.
Old 10-24-2015, 08:51 PM   #34
kapcan2k's Avatar
Ok, the way you explain it makes sense now. Best place to find some 11-14 brembo rotors at a decent price would be ebay then I'm guessing? I like the idea behind all this it's just a matter of finding everything at a good price to make it all work.
Old 10-24-2015, 09:23 PM   #35
The_Chech's Avatar
I got some one to trade me new rotors for rotors. But your best bet is to try Rockauto.com the prices they have on brakes is ridiculously cheap. Just make sure your looking at rotors that are the 14" ones for Brembos and not the 13" regulars.
2011 Kona Blue Gt
IG - The_Chech
HELP! 2013 gt no brembos or 2012 with brembos tlebron20 General Mustang Discussion 9 01-29-2015 09:28 AM
Help! 2012 gt with Brembos or 13 gt with no brembos . tlebron20 2011-2014 Mustang GT 15 01-24-2015 08:50 PM
19" Track Pack wheels for sale (Black Brembos) GrabberBlue5.0 Mustang Parts for Sale and Wanted 17 05-18-2013 05:47 PM
Brembos and 18"x8" rims xz06 2005-2010 Mustang GT 3 10-10-2006 01:47 PM
05:39 AM
