wrench light on 2012 gt - Mustang Evolution
Old 10-27-2015, 06:56 PM   #1
Hey. I am new to this forum and mustangs in general and I have a bit of a issue. When I start it up there is no wrench light. As soon as I give it a bit throttle the light pops on and no response. The car goes into limp mode and won't drive. I got a new throttle body because I heard those have problems. I disconnected the battery for a hour but it still has the same issue. I can't find anyone online that will help me with the issue. I'm not sure if it has a tune or not. Bought it used. Any suggestions?
erikfrolov is offline   Reply With Quote
Old 10-27-2015, 07:12 PM   #2
DiESeven's Avatar
How long have you had it before the issues started? Did you replace it with a stock throttle body or a different aftermarket one?
Instagram: @v6beast
Old 10-27-2015, 07:14 PM   #3
natestang07's Avatar
Bleh multiple threads. Scan the codesssssss
Old 10-27-2015, 07:17 PM   #4
It had the issue since I bought it. I bought it off an auction. I bought a oem throttle body from ford.
Old 10-27-2015, 07:30 PM   #5
oxford5pointoh's Avatar
This thread will do you no good without more information. As stated, scan it for the code first. Then maybe we can help you.
Old 10-27-2015, 07:43 PM   #6
dave73's Avatar
Auction huh? Well I hope you got it cheap!
dave73 is offline   Reply With Quote
Old 10-27-2015, 07:52 PM   #7
I scanned it with the obd2 scanner. No codes.
Old 10-27-2015, 07:59 PM   #8
Something is off here. You shouldn't get a wrench light and thrown into limp mode without codes.
Old 10-27-2015, 08:24 PM   #9
Do I need some special code reader maybe?
Old 10-27-2015, 08:31 PM   #10
dave73's Avatar
I have heard of this situation before wrench and no code and I believe it was something to do with the MAF sensor
Old 10-27-2015, 08:34 PM   #11
Would a bad maf sensor cause it to go into limp mode? How can I know if it's the sensor?
Old 10-27-2015, 08:37 PM   #12
dave73's Avatar
Yes somebody had this problem before and it did the same thing Check the connections on the TPS too in fact I think it was the TPS not the MAF
Old 10-27-2015, 09:40 PM   #13
Senior Member
Spartanator's Avatar
How is the title (If I may ask)?
Do you have an aftermarket cold air intake?
Is your factory cold air box sealed properly? (I did this once)?
Search button pulls this guy first: wrench light on the dash
Weird Dash light; "Limp Home" mode?
Here is some other stuff from another forum:
http://www.allfordmustangs.com/forum...nch-light.html
I suggest you find a parts car if your going to start swappin' parts...
Edit: If you don't mind whats the mileage? More of a curiosity thing for me...
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 10-27-2015, 09:45 PM   #14
It's is salvage title but there was no damage to the engine bay or any sort. It was only hit in the wheel so it just needed a shock and control arm. So nothing under the hood was damaged or messed with.
Old 10-27-2015, 10:07 PM   #15
Maybe the maf got wet?
Old 10-27-2015, 10:11 PM   #16
It was completely dry under the hood and I live in California so unless someone sprayed it directly with a hose, I don't think it got wet.
Old 10-28-2015, 07:38 AM   #17
Joaquin_ii's Avatar
I had that and put a new battery in it and it fixed everything.
Joaquin_ii is offline   Reply With Quote
Old 10-28-2015, 07:42 AM   #18
Region: West Virgina
I wonder if your catalytic converter brick was damaged during the wreck blocking flow. I had what you described on a salvage car I rebuilt once and acted the same way with little to no throttle response but it idled fine.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 10-28-2015, 07:47 AM   #19
Kevin.Cook
Guest
Posts: n/a
Hey if you want a MAF sensor, I have an extra one I can give for almost free. I just want reimbursed for shipping. Assuming the 3.7 and 5.0 take the same sensor? I can clean it with MAF cleaner before sending it if you want.
Old 10-28-2015, 07:49 AM   #20
Kevin.Cook
Guest
Posts: n/a
Also wondering how your fuel system is. I would run some cleaner through it and check all the usual stuff. Like spark plugs and such.
But yea, I had an issue like this when my MAF got wet. I got a code though. I cleared it and dried the MAF and I was back on my way.
Old 10-28-2015, 07:49 AM   #21
dave73's Avatar
Check the blades in the connector of the TPS sensor this was an issue
2012 gt
wrench light on the dash jessesse 2011-2014 V6 Mustang 17 06-24-2016 12:28 PM
Gt500 wrench light pound Shelby Mustang 7 09-09-2015 05:35 AM
Wrench Light/check engine krusignuolo 2005-2010 Mustang GT 8 02-04-2015 12:37 PM
2012 Mustang GT wrench light Sprintradc 2011-2014 Mustang GT 7 07-24-2012 02:19 PM
Got a locking lug nut dont have the wrench/socket Ibanezplayer272 Mustang Wheels & Tires 19 12-30-2005 01:40 PM
04:07 PM
