3rd gear lockout after clutch upgrade - Mustang Evolution
Old 10-27-2015, 07:48 PM   #1
Droidman86's Avatar
I recently installed mcleod twin disc rxt clutch. Not sure if it was pure coincidence but after I installed the clutch, the 2nd to 3rd gear will grind (not engage) every single time when I try to shift fast when racing. I've tried over 50 times, nothing.
Now if I do granny shifting 2nd to 3rd (letting rpms go down a bit, like 1 sec between engaging clutch and shifting to 3rd), it does work fine.
This used to happen rarely when drag racing/High RPMs a while ago, but after I installed the MGW shifter it went away. However, now it does it all the time.
I'm thinking it's either the 3rd gear synchro or clutch slave cylinder/throwout bearing that I didn't change when I installed the clutch.
Has somebody experienced something similar or know.
2012 Mustang 5.0
Steeda CAI, Boss Manifold, 3.73 Gears, E85, NX Wet 150 Shot, AED Tuned, LT Headers, Aluminum Driveshaft, Mcleod Twin Disc Clutch, KB Bap, N2MB wot box w/ window switch.
Droidman86 is offline   Reply With Quote
Old 10-28-2015, 04:37 AM   #2
Strange Mud's Avatar
WAG....if you have not already upgrade your clutch line. I doubt it will help but simple/cheap
Old 10-28-2015, 07:32 AM   #3
Droidman86's Avatar
agree, I will be installing new clutch line along with throwout bearing/slave cylinder to see if that makes a difference.
2012 Mustang 5.0
Old 10-28-2015, 03:10 PM   #4
thelastsumurai's Avatar
I would at least make sure to bleed it again, and make sure it's done correctly. I don't know the correct procedure for bleeding clutch lines but i'm sure people on this forum do. I seem to recall a member having this same issue, and it turned out to be air in the clutch line.
try this U tub video ./watch?v=HkmFh7hxico
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-29-2015, 04:40 AM   #5
they are self bleeding, you just pump the clutch pedal one gazillion times. After replacing my line I had to repeat it the next day but only about 100 times. Keep an eye on brake fluid (shared reservoir) I doubt it's the problem....I didn't notice any thing after doing my line (did as preventive) but I liked the theory of replacing it.
Old 10-29-2015, 11:11 PM   #6
I would say 3rd gear synchro, change the transmission oil and look for metallic particles by putting it in a glass bottle and holding it out in the Sun
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 10-30-2015, 08:45 AM   #7
Does double clutching make it easier to get it into third?
Old 11-08-2015, 11:57 PM   #8
Droidman86's Avatar
yes it does help, but maybe it's just that since double clutching takes longer.
I'll be replacing throwout bearing, pilot bearing and stainless steel clutch line to see if all that helps.
2012 Mustang 5.0
Haze in 3rd brake light after washing? jayochs 2011-2014 V6 Mustang 6 12-29-2014 10:47 AM
Spongy clutch after removing clutch assist spring. Fax22 2011-2014 Mustang GT 2 09-06-2014 10:19 PM
DVD Lockout Electronics Package 11SHELBYGT500 2011-2014 Mustang GT 12 03-19-2011 12:47 PM
NFL Headed For A Lockout Brent The Bar 1 05-18-2008 08:50 PM
transmission stuck in 3rd gear need help theglory 1979-1995 Mustang GT 18 02-15-2006 10:20 AM
01:06 AM
