Idiot Question: 2011 GT Auto WOT pull - Mustang Evolution
Old 10-27-2015, 10:36 PM   #1
So I recently installed a blower and I am trying to get this thing dyno tuned. I was told that I need to complete the dyno pull in 4th gear for accurate HP and TQ numbers. readings suggests that 2011+ in 4th gear is the 1:1 ratio.
The question is, I have an automatic, so how do I do this?
Click the 'overdrive' button on the shifter and turn off advance trac?
FirstGeneration is offline   Reply With Quote
Old 10-28-2015, 04:09 AM   #2
Grabber Blue5.0's Avatar
Your tuner can lock it in 4th to do a pull.
Old 10-28-2015, 08:57 AM   #3
Let me clarify my position. I am email tuning at the moment, so when I take it to a local dyno I am only doing pulls for data logging.
Having a local tuner lock it into 4th sounds like there needs to be a program flashed to the ECU which means more $$$. Dyno pulls alone are inexpensive.
IMO if there is no mechanical way to do this, then I should receive a file from the remote tuner I bought the kit from, correct?
Old 10-28-2015, 11:48 AM   #4
DallasStang77's Avatar
You can't select shift the gears manually?
Old 10-28-2015, 11:55 AM   #5
In an 2011 GT automatic? D-3-2-1 are my options.
I am new to this and right now I am the filter between the eTuner and my local tuner and it is getting a little frustrating.
I can chalk it up to being ignorant, but so far "just do this" isn't helping me personally.
"How do I get to the top of Mount Everest."
"Just Climb"
Sure, but what tools and techniques do I need?
Old 10-28-2015, 02:25 PM   #6
Correct that your tuner can send you a file to lock your car in 4th to do a pull. How come you aren't doing your logging on the street? Which blower did you go with and who is doing the tuning?
Old 10-28-2015, 02:40 PM   #7
thelastsumurai's Avatar
That does not sound like a productive combination. Do your data logging on the street (if you can) and let your tuner make the adjustments. A dyno pull without a before number is meaningless. Unless you just want bragging rights. Which I can then understand.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-28-2015, 07:05 PM   #8
I don't see how it is reasonable to data log on the street. Target RWHP was 600 with a redline of 7000 RPM. I do not see how this is possible without risk (ticket, safety).
The original instructions said to data log a pull in only 1 gear: 2nd, 3rd, or 4th. I am going to the dyno for safety reasons, and secondary of course is HP/TQ numbers. 4th is optimal due to the closeness of a 1:1 ratio.
How in the world do I datalog in a 2011 GT automatic only through 1 gear (4th gear) while keeping speed down and hope to redline to 7000 RPM?
The overall issue is that I hit a peak 500RWHP at 6250 RPM and then there is a roll off down to 400RWHP when I hit 7000RPM. I was told this is abnormal as HP should continue to build in a more-or-less linear fashion.
My eTuner (VMP Tuning) told me that the dyno pull is wrong, and I need to do it in 4th gear. What I do not yet understand is does this fix the calculation of the HP/TQ and 'fix' the roll off and/or look for an underlying problem?
Old 10-29-2015, 06:23 AM   #9
BlackBetty2012's Avatar
Region: Rhode Island
I have the same car, i just did my dyno pulls in third. The numbers were right on par with others so i don't see the need for the 4th gear locking tune dyno pull. Just pull in third...
Sent from my SPH-D710 using Mustang Evolution mobile app
BlackBetty2012 is offline   Reply With Quote
Old 10-29-2015, 09:05 AM   #10
Sorry bout that I forget that not everyone has the access to roads that I do.
Old 10-29-2015, 10:30 AM   #11
If 4th gear is not absolutely critical, then I am a little frustrated that I have sent reems of data already just not locked in 4th gear.
I have a few I can try, but it requires me being an early riser. Just before dawn.
At this point I am more concerned that there is a underlying problem why my numbers plummet after 6250 RPM. I still have the stock fuel pump, so maybe that needs to be upgraded. I won't know until I get data.
Old 10-29-2015, 10:41 AM   #12
Is the boost dropping off? My car has issues with belt slip at times over 4500 and I lose 5-6# of boost.
Sent from my XT1045 using Tapatalk
Old 10-29-2015, 11:05 AM   #13
For now I will say no, because we have been monitoring the boost with a Roush gauge during the pull: ~10 PSI and that is expected with the 82mm pulley.
Belt slip has come up, but we see no physical evidence of it: residue, belt getting roughed up, etc.
Whatever it is, it has been consistent. At 6250 RPM the HP rolls off: 500 peak to 400 at 7000 RPM. Looking at the knock sensor, the knock goes crazy: +2.5 at 6250 RPM with a yet undetermined reason. Temps too high? fuel pump maxed out? Bad gas? Don't know.
2011 gt
Pull up your pants...NOW!!!! PureVenom The Bar 8 06-14-2007 04:07 PM
Whats this tard trying to pull?? SpectorV The Bar 1 11-01-2005 06:38 PM
autozone won't pull my cel code!? candmforever Pre-2005 V6 Mustang 8 12-10-2003 09:19 PM
99 FR350 DYNO pull 99FR350 Pre-2005 V6 Mustang 4 10-11-2003 03:09 PM
Idiot people and their idiot ways DropTop_Stang Pre-2005 V6 Mustang 5 08-08-2003 12:37 PM
10:51 PM
