Driveshaft clunk - Mustang Evolution
Old 10-28-2015, 07:32 AM   #1
Kustumb's Avatar
Driveshaft clunk
Is the only way to get rid of this while shifting is by getting a one piece driveshaft?
I'm also looking for a complete solution for the shifter being all notchy while shifting on turns. I have the following slotted down:
Mgw race spec shifter
White line bushing
McLeod clutch line
Anything else?
Kustumb is offline   Reply With Quote
Old 10-28-2015, 07:36 AM   #2
Kevin.Cook
Guest
Posts: n/a
Good trans fluid will also help smooth things out. Not much, but every little bit helps.
Now are you referring to clunking or the vibration we get sometimes with the stock setup? Usually heavy vibration when decelerating and such.
Old 10-28-2015, 08:06 AM   #3
Strange Mud's Avatar
my biggest improvement was motor mounts. Bad news kinda a pita and increased NVH. It still was my fav improvement. Mine is still notchy from 1-2 esp but I'm happy. The mounts helped me from getting blocked esp at hard accel and in turns.
Old 10-28-2015, 10:59 AM   #4
Kustumb's Avatar
Hmm can you link what you used?
Old 10-28-2015, 11:32 AM   #5
JHR HARDCORE BILLET ADJUSTABLE MUSTANG MOTOR MOUNT KIT 2005-2011 - Groove Automation Inc
these are what I used in my 2012 V6 (V6/V8 same) for me it was the biggest improvement in blocking issues. I've done MGW (did a shifter mount first) clutch line (no difference noted) fluid (helped notchy some). I went to MGW after finding one used at a good price. The other thing that helped me was concentrating on learning tight gates and to use centering spring. I think they helped because of the tight L/R gates any movement of the engine/tranny would throw off my shifting. My only warning is there is a good bit more NVH
If you go do them I have hints from the install on my V6. Simple wrenching but pain to get OEM's out.
Old 10-28-2015, 11:46 AM   #6
Kustumb's Avatar
Thanks for all this. that'll be my first step then.
Was NVH bothering? I have music or the top down all the time usually.
Old 10-28-2015, 12:23 PM   #7
I'm OK with it but it's a subjective thing. The only real bad bit is with the V6 and it's dual mass flywheel is when that starts it's decel vibration (Google dual mass fly if ya don't know) it feels like mild rumble strips. It made my various rattles worse but it's not a Camary.
Old 10-28-2015, 12:33 PM   #8
Kevin.Cook
Guest
Posts: n/a
Yea next year I will probably get the Spec clutch and flywheel because of this. and may pick up a 1 piece driveshaft while I am at it.
Old 10-28-2015, 12:44 PM   #9
Kustum, note this has nothing to do with drive-line clunk.....
Old 10-28-2015, 01:59 PM   #10
c_rizzle's Avatar
Its different on an auto, but for me the one-piece driveshaft reduced NVH for me.
c_rizzle is offline   Reply With Quote
Old 10-28-2015, 02:02 PM   #11
Kevin.Cook
Guest
Posts: n/a
Sometimes Pinion Angel being slightly off can cause a clunk. I had the 1 piece driveshaft installed on my 2014 Auto. Stock suspension. I got a clunk going into Reverse. I got my 3.73 gears installed and the tech adjusted the pinion angle, and that clunk is gone.
Old 10-28-2015, 02:15 PM   #12
thelastsumurai's Avatar
Your car is an '07 V6, and your just now noticing the clunk? I would start by rotating the drive shaft by hand and hearing where the clunk actually is coming from, At your cars age I would pay particular attention to my U joints.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 10-28-2015, 02:34 PM   #13
shunc01's Avatar
Did you have to buy an aftermarket part to adjust your pinion angle like the upper control arm? And what kind of shop would adjust pinion angle? Thanks man.
MPT tune, Axle exchange Aluminum driveshaft, 3:73 gears, borla stype, frrp x pipe, Mac ceramic shorty headers, airaid cai, Jlt separator, koni orange shocks and struts, SR Springs, gt500 mounts, J&M Panhard bar, Bmr LCA, 2010 gt500 wheels, roush chin splitter, roush louvers, and RTR stripes... 😎 🚘
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 10-28-2015, 02:44 PM   #14
MPT tune, Axle exchange Aluminum driveshaft, 3:73 gears, borla stype, frrp x pipe, Mac ceramic shorty headers, airaid cai, Jlt separator, koni orange shocks and struts, SR Springs, gt500 mounts, J&M Panhard bar, Bmr LCA, 2010 gt500 wheels, roush chin splitter, roush louvers, and RTR stripes... ������ ������
Wow that car looks bad *** from the description on your signature
Old 10-28-2015, 02:52 PM   #15
shunc01's Avatar
Thanks I think I'm all done modding this car just trying to keep up with it but yeah thanks man..
Mods:
Old 10-30-2015, 09:32 AM   #16
Kustumb's Avatar
Maybe related, do you guys ever have issues pulling it out of gear wen driving? Sometimes it'll be super smooth for me and it'll go out of gear easy but other times I'll have to pull relatively hard.
---------- Post added at 10:32 AM ---------- Previous post was at 10:31 AM ----------
And by the above I'm not saying pulling it out of gear to neutral specifically. That and/or shifting.
Old 11-02-2015, 07:31 AM   #17
Kustumb's Avatar
Bump
WIN A 2015 Driveshaft Shop Driveshaft & Half-Shafts at AmericanMuscle! AMAlexLazarus 2015 Mustang GT 13 02-22-2015 02:54 PM
Driveshaft Clunk ty98gt 1996-2004 Mustang GT 8 04-06-2014 08:21 AM
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
2004 Ford Mustang - clunk? lisalulu Pre-2005 V6 Mustang 7 05-08-2007 08:01 AM
06:20 AM
