DEAD spot in powerband, NEED HELP! - Mustang Evolution
Old 11-03-2015, 06:08 PM   #1
hey everyone, as the title enthusiastically states, im finding a total dead spot in my power band. from 2k to 3400 i can floor it, car crawls. after it reaches around 3500 it lunges forward with full power
heres where im at thus far:
its not TCS/STC issue
its not the tune, its present stock and tuned. currently running bama 93, when calling them they confirmed my tune was spot on for the mods im running
really need help from anyone who may know whats going on, or suggestions to fix it
happens in every gear
thanks in advance everyone, as Robostang will attest, something is definitley up
2013GTpremium is offline   Reply With Quote
Old 11-03-2015, 06:37 PM   #2
Billgluckman's Avatar
Check engine light?
Billgluckman is offline   Reply With Quote
Old 11-03-2015, 06:48 PM   #3
No cel, love your name by the way haha malibus most wanted is hilarious
Old 11-03-2015, 06:51 PM   #4
Kevin.Cook
Guest
Posts: n/a
Have you tried disconnecting your battery for an hour and retrying?
Also maybe clean the tb and maf sensor. Make sure no hoses are pinched.
Does the car sputter or act weird at idle?
Old 11-03-2015, 06:59 PM   #5
Seems to idle smoothly at Around 650-700 when warm. Haven't pulled the battery yet. Would doing so or performing the gas pedal throttle reset technique jeapordize my tune? Ty for the feedback!
Old 11-03-2015, 07:03 PM   #6
Robostang's Avatar
I took a ride with 2013GTpremium today and the car is definitely flat between 2k and 3500 rpm.
You might want to set the car back to stock before you disconnect the battery. An alternative to disconnecting the battery is to pull a fuse. I can't remember which one but someone will chime in or you can search it.
Rob
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 11-03-2015, 07:04 PM   #7
Kevin.Cook
Guest
Posts: n/a
Fuse 47. That is for the adaptive shifting and such. I would just rather disconnect the battery. Do revert to stock just to be safe.
Old 11-03-2015, 07:17 PM   #8
Kevin.Cook
Guest
Posts: n/a
If that doesnt work, i have heard of faulty throttle bodies on the s197s kicking the car into limp mode.
Maybe keep the car on the stock tune, and if all else fails - take it to Ford if you have any "warranty" left to get it checked. Unless you have a friend that will let you swap stuff just to test.
Old 11-03-2015, 07:19 PM   #9
The bumper to bumper expired about 1100 miles ago of course. Previous owner was kind enough to run it to exhaustion. I'll do suggested ideas you guys mentioned, starting with the battery. And go from there !
Car pulls really hard once it wakes back up just wanna get this sorted
Old 11-03-2015, 07:33 PM   #10
Kevin.Cook
Guest
Posts: n/a
Sounds good. Definitely make sure nothing is kinked, loose, or disconnected.
Old 11-03-2015, 08:45 PM   #11
Sounds like a tune issue. Frankly, there are lots of tunes that can pump up the limp bottom end on these cars. Go to the tuner and ask for a revision or pick a tuner that can do this for you, it's not hard.
Old 11-03-2015, 08:52 PM   #12
Kevin.Cook
Guest
Posts: n/a
He said the issue was present while stock also.
Old 11-03-2015, 08:53 PM   #13
natestang07's Avatar
Well I think a datalog may help. Or at least the can see if there are any issues there op needs to take care if
Old 11-03-2015, 09:31 PM   #14
Yeah, these cars suck off the bottom end stock as well. A tune *should* fix this but maybe this one didn't.
Old 11-04-2015, 01:19 PM   #15
thelastsumurai's Avatar
The engine will be Warrantied for 5 yrs or 60 K. I believe this would fall into the emissions category. Make sure you go back to stock tune before going to Ford for service.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 11-04-2015, 01:23 PM   #16
I actually think I may have figured it out. I'll post results later when I can check
As for the returning to stock
Ford knows when you've put a tune. Even if returned to stock lol
Old 11-04-2015, 01:34 PM   #17
Kevin.Cook
Guest
Posts: n/a
Very true, but doesnt always mean they will go nuts on you if they see it. Ask me how I know! lol
Old 11-04-2015, 05:16 PM   #18
Jvibe92's Avatar
Name:	ImageUploadedByMustang Evolution1446682476.320967.jpg
By dead spot I think he means what you see around the 3k rom area where torque is low then kicks in after 3500rpm.
Jvibe92 is offline   Reply With Quote
Old 11-04-2015, 05:29 PM   #19
datalog this thing: TP (actual and commanded), timing advance, STFT, LTFT, KR, lambda or afr, rpm and vehicle speed.
Old 11-04-2015, 05:30 PM   #20
Kevin.Cook
Guest
Posts: n/a
Gotcha. I thought he meant his car was going into a limp mode. My bad.
Old 11-04-2015, 06:17 PM   #21
Originally Posted by Jvibe92 View Post
Attachment 193264
Nah this was different. I appreciate your input but when I say dead spot, I mean foot to the floor and could get out run by a lady with a walker. Problem has since been corrected and I thank everyone for helping out. You're he best
Old 11-04-2015, 06:19 PM   #22
Kevin.Cook
Guest
Posts: n/a
So what was the fix?
Old 11-04-2015, 06:28 PM   #23
I know I'm gonna get smoked for
This. Be gentle.
The damn Venturi tube was still there
Hear me out.
I'm coming from a 350z, never owned a stang or knew what I was looking for. It was dark out, looked into the tube and didn't see anything. Upon closer inspection after racking my brain I took a closer look and it was there
I'm begrudgingly posting in case any other noobs like me run into the same issue, lesson learned
I do appreciate everyone chiming in to help
Old 11-04-2015, 06:34 PM   #24
Robostang's Avatar
You can send some heat my way also. I was with 2013GTpremium when he looked inside the CAI. Unfortunately, I didn't bother to take a close look at the inside of the tube myself. If I had, we probably would have solved this problem a lot quicker. Anyway, looking forward to another ride in that beast now that it is sorted.
Old 11-04-2015, 07:17 PM   #25
man, don't worry, that doesn't even tweak my Stupid-o-Meter. glad it is solved!
Old 11-05-2015, 11:11 AM   #26
How do you know Kevin. I am hesitant to put a tune on my car. Afraid it will void my warranty
briansplace is offline   Reply With Quote
Old 11-05-2015, 11:22 AM   #27
Kevin.Cook
Guest
Posts: n/a
They have to prove the tune caused the issue or was related. I took my car in because the ecu was messing up. It was tuned, but i put it back to stock before they towed it.
They had to reflash the ecu. The car wouldnt start or anything anymore. That fixed it. When they gave the car back, they didnt mention the tune or anything. And the reflash fee was waived.
I did check afterwards and the computer is still the same with the same strategy code. So my tunes were still valid.
Just be nice when you take your car in. I am sure if you are a d***, it wont help your chances.
How to spot a tard PureVenom Pictures and Videos 19 09-27-2006 12:41 AM
Where's the local meeting spot? modular2valve Regional Mustang Discussion 12 08-18-2006 10:20 PM
Help me spot the poser... DarkShadow The Bar 47 01-25-2006 05:19 PM
Spot Light Body Kit Dom Mustang Audio & Video 4 07-02-2004 05:21 PM
» Members Mustangs
Bonni
drusmith
RED
Randl114
Add your Mustang
09:27 PM
