Mustang gt small problems - Mustang Evolution
Old 11-03-2015, 11:46 PM   #1
So just getting ur opinions.. when ever I get on my car and sometimes spin the tires in first the clutch pedal sticks about half way for prolly 15 seconds or until i push it in and out once or twice. It will eventually pop out.. is the clutch going out or something small? Doesn't do it all the time but it has happened more frequently.. also when I first start the car It clicks/ grinds into gear and sometimes I have to either force it(which I dont) or go from a different gear back to first or reverse(where it happens the most) to get it in gear. Thanks guys
brett.fries23 is offline   Reply With Quote
Old 11-04-2015, 01:12 AM   #2
Upgrade the clutch and get a braided clutch line.
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 11-04-2015, 07:39 AM   #3
3.7Muscle's Avatar
Is this a common GT problem? My Sixxer does not do this. I dont have anything upgraded Engine/Transmission wise. Even the fluids are stock Ford Motorcraft stuff.
Only reason I ask is I want a GT soon. and plus the OP is facing a (to me) serious issue.
See my Baby Here
2012 101a Mustang V6 M/T 6-Speed
3.7Muscle is offline   Reply With Quote
Old 11-04-2015, 10:54 AM   #4
Nah. Mine doesn't do this.
Old 11-04-2015, 07:07 PM   #5
Robostang's Avatar
Mine does not have this issue.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 11-05-2015, 04:22 PM   #6
Koryak's Avatar
I think there's a TSB for early Coyote GTs when the clutch tries to stay disengaged during higher rpm shifts. Something to do with the original factory install and fixable under power-train warranty if you're still covered.
At any rate get the clutch fixed soon before the trans suffers some damage from the clutch problem!
Koryak is offline   Reply With Quote
Old 11-05-2015, 05:27 PM   #7
Clutch slave cylinder I bet.
litfuse is offline   Reply With Quote
Old 11-05-2015, 07:39 PM   #8
jande063's Avatar
Every 2011-2014 3.7 or 5.0 (no GT500 has done this to me) mustang I have ever raced that had a manual transmission has done this (I race every weekend, and I have only driven my own car six times this year; people throw me their keys to figure out where they lose time to me). This will typically happen on high rpm, high throttle shifts.
As soon as I pull the assistance spring from the pedal, the problem is impossible to reproduce (though you will have about 1/8" of play at the top of the travel that the spring would normally hide).
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Small Mustang project-Any suggestions? BlackSmoke02 Mustang Paint, Appearance & Detailing 1 11-12-2012 08:37 PM
2013 Mustang, came with a small black sunglasses holder, mounting? FluffyFenrir 2011-2014 V6 Mustang 11 07-10-2012 01:03 PM
what are small things i can do to my 2003 mustang to add some appearance? Mord Fustang 1996-2004 Mustang GT 22 03-08-2012 03:26 PM
Small update on the mustang sonic04edge Pictures and Videos 7 10-14-2010 11:16 PM
01:28 AM
