Suspension - Mustang Evolution
Old 11-06-2015, 09:47 AM   #1
MarkCoyote's Avatar
Suspension
I have non adjustable LCA and pan hard bar. I'm looking for better weight transfer by getting drag springs. Will I need to get adjustable LCA and pan Bar? All bmr products
MarkCoyote is offline   Reply With Quote
Old 11-08-2015, 11:18 AM   #2
Trevorhart3's Avatar
I would recommend it if the springs are lower, that way you don't shift your drive line
Trevorhart3 is offline   Reply With Quote
Old 11-08-2015, 11:29 AM   #3
olerodder's Avatar
Region: Oregon
Maybe you could tell us what you have, is it lowered, how much and have you done any mod's to it. Are you going to use slicks and what size wheels and tires to you currently have?
As was mentioned if you have lowered the car you really should get an adjustable pan hard just to center the axle.
I would assume you are experiencing some axle hop?, if not then I'm not sure I'd change anything. Have you checked your pinion/drive line angle, if so what was it?
Old 11-09-2015, 07:26 AM   #4
MarkCoyote's Avatar
As of now current mods 4C converter nitrous outlet plate kit 100 shot bigs and littles 26 mt sportsman up front 275/60 et pros in the rear o/r X, LCA, and pan bar. I want drag springs for weight transfer
Old 11-09-2015, 07:27 AM   #5
MarkCoyote's Avatar
Or just try upgrading struts and shocks and don't change springs
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help 35thAniVertible Pre-2005 V6 Mustang 23 10-31-2003 12:54 PM
Stang Suspension Laser02 The Bar 14 10-30-2003 09:15 AM
Duals or Suspension? Killer Squirrel Pre-2005 V6 Mustang 1 05-13-2003 03:36 AM
02:28 AM
