Setting spark on SCT tuner - Mustang Evolution
Old 11-11-2015, 03:25 PM   #1
blmustang01's Avatar
Ok so what should I set the spark to? It is default at 0. I'm running 93 octane, race tune and a tps sensor signal booster. It is great however it can be better, do I just advance the timing to 4 or to max and listen to engine for any abnormalities? Clue me in please thanks!!
2013 mustang gt/leather/pony projection/gt500 axle backs
blmustang01 is offline   Reply With Quote
Old 11-11-2015, 04:03 PM   #2
NO...don't do that. Inch it up a degree at a time. If you need to add more than a couple, you should get a tune revision. Global adds or subtracts spark everywhere, which isn't ideal for what your engine needs, guaranteed. Pulling it is NBD, adding it can be hazardous. Proceed slowly.
Old 11-11-2015, 04:12 PM   #3
ok i'll just inch it up slowly and listen and feel for how it handles.
Old 11-11-2015, 05:56 PM   #4
By the billowing sails of the Beagle, your statements scare me. this is an 11:1 compression engine running on ****ty pump gas making over 400 horsepower. DATALOG.
Don't just "listen" for stuff. By the time you hear it, damage can be long done.
Datalog your spark advance 1 and spark advance and your KR. Include rpm, throttle position commanded and absolute and vehicle speed so you have some reference points.
Old 11-12-2015, 03:57 AM   #5
I wasn't actually going to set spark to max value, I just read somewhere where someone did that. I have datalogged for my 93 tunes but still want to try advancing spark some.
Old 11-12-2015, 07:04 AM   #6
You still don't seem to understand the seriousness of what you are suggesting. The timing curve is probably pretty close as is. What I am saying is go up in small increments, datalog after each change and see where you're at. It's the only safe way to do this.
Old 11-12-2015, 02:10 PM   #7
Yeah I'll see what the datalog reads as of now where it stands with my current tune and see where it will be with advancing the timing. I was simply going to plan on advancing spark by 1 or 2 and that's all. How bad could that really be from 0?
Old 11-12-2015, 02:12 PM   #8
It could mean a lot. I wouldn't mess with it.
litfuse is offline   Reply With Quote
Old 11-12-2015, 02:14 PM   #9
Ok I'll take everyones advice and just send the datalogs in to a tuner to see how the spark is if it is that serious lol.
Old 11-12-2015, 02:31 PM   #10
Old 11-12-2015, 02:38 PM   #11
1 to 2 degrees could be nothing or rattling death. More is not better here. There is a point where power falls off fast, even if spark knock isn't present, because the spark is too far in front of the full compression of the charge.
Old 11-12-2015, 03:13 PM   #12
scott_0's Avatar
perhaps you should do some research before throwing ANY amount of timing at your car! these motors don't take too well to adding global timing, lots of lunched #8's were the result of global timing, leave the tuning to guys that know what they're doing
Sent from my S6 using tapatalk
Old 11-12-2015, 06:21 PM   #13
I hear ya!! I have different tunes that address the fly by wire which didn't provide much improvement and it seems the pistons seem like they are retarded. When do I take it in on an actual dyno time will tell.
Old 11-12-2015, 06:24 PM   #14
What? I've built a few engines up but, I've not heard stuff expressed like this.
Old 11-13-2015, 03:33 AM   #15
First time for everything lol.
Old 11-13-2015, 07:25 AM   #16
Diehard's Avatar
"pistons seem like they are retarded."
Is this referring to the ignition?
Old 11-13-2015, 07:48 AM   #17
I'm even more uncertain op actually understands how an engine actually works.
Play at your peril...
Old 11-13-2015, 09:18 AM   #18
thelastsumurai's Avatar
Listen to 5LHO
You are taking a very big chance... I would ask my tuner how he feels about this....BEFORE I make any changes.
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 11-14-2015, 04:34 PM   #19
Definitely listen to those telling you to be cautious. You do NOT want to add global spark. In fact you should not be tuning with the handheld at all. The ECU blends values from several tables to evaluate spark. What is particularly important is the threshold your knock sensors are set to. If you add global spark and the knock sensors will only pull say 4-6 degrees of timing. You could set yourself up for a situation where the knock sensors would need to pull more timing than the tables allow. There are so many factors to consider with how these ECU's blend values and the handheld tuner just does not give you access to what you need to competently tune your car.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
setting speedo with SCT randyg 2011-2014 V6 Mustang 9 10-29-2015 05:47 AM
Snow and Wet setting in under 40 degree setting plus OE Summer Tires retiredf5 2015 Mustang GT 12 09-16-2015 11:32 PM
World spark setting stanzmustang08 2005-2010 Mustang GT 4 10-01-2014 04:16 PM
Good SCT setting? Ezra General Mustang Discussion 16 02-05-2014 12:12 AM
SCT tuner or Diablosport tuner for a 2000 Ford Mustang GT? cuinn 1996-2004 Mustang GT 1 03-20-2010 06:41 PM
05:37 AM
