Shifter comparision stock, Barton, MGW, Blowfish - Mustang Evolution
Old 11-13-2015, 10:08 AM   #1
Sterlingbeast5.0's Avatar
OK, My 2013 GT was bone stock when bought. No real need to spend time on the stock shifter other than to say it is long shifts and good luck at high RPM shifts.
Went to Barton - This was a very good improvement in shift feel and is DEFINITELTY a short throw. I should include that I got the bracket when I did this. I was happy with it until I took it to the strip. Then it was still the same thing high ROM shifts were nearly impossible. Maybe it is me but going from 2 to 3 or 3-4 at 6,500 RPM was ridiculous.
Added Blowfish - I added the Blowfish racing bracket. This really took care of all of the high ROM stuff. I could shift at any RPM relatively easily and it doubles as a safety loop. When I added this I did add an aluminum shaft. Noise and vibration wass definitely up. they shifter itself would seem to rattle against the edge. I would usually keep my hand on the shifter on the highway as it could get annoying.
Bad Barton - My shifter literally snapped in half while on the road shifting into 4th. Scary a hell let me tell you. Never really in danger but it definitely freaks you out. Contacted Barton according to them there was an issue when they switched something up and they know about this? Hello, recall, email notice something please. I believe he said it affected a few hundred units. For what its worth I am shipping it back (my cost) and they are going to send a new one they aid.
MGW - WOW!! Installed for about 100-200 miles now. Smooth as silk, easy a pie to shift. Short throw (probably not *** much as Barton though). High RPM's are no problem, no rattle this thing is awesome. My car who installed said he PROBABLY could have left the Blowfish in but it rendered that useless so he took it off so I could sell it and remove unneeded weight.
If you are deciding on a shifter to get buy the MGW. hands down best. it is more but look at the product, it is replacing allot more than any other short shifter does.
pics are each part and then one of Barton snapped
ID:	193540   Click image for larger version
Name:	MGW MT-82 Race-Spec Shifter 3 4web.jpg
ID:	193542   Click image for larger version
Old 11-13-2015, 11:19 AM   #2
Psmith129's Avatar
Good to know , did you change the lines and fluid as well ?
Psmith129 is offline   Reply With Quote
Old 11-13-2015, 12:14 PM   #3
I will have to ask lol. I dont do allot of the work myelf
Old 11-13-2015, 08:17 PM   #4
Psmith129's Avatar
Oh I see , well if you find out let us know .
Old 11-13-2015, 11:42 PM   #5
Reality is if you want high rpm shifts replace the clutch, pilot bearing, throw out bearing and a braided clutch line you will be set to go
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 11-14-2015, 02:35 PM   #6
mustang8918's Avatar
Welcome to the MGW club, I love mine.
2014 GT Manual, American Muscle.
mustang8918 is offline   Reply With Quote
Old 11-14-2015, 04:54 PM   #7
shaneyusa's Avatar
Region: Idaho
The MGW is on my Mod want list. Thanks for posting your experience. Makes me that much closer to making the jump.
2014 SGM GT Premium 6MT, 401A Equip Group, Comfort Package, Glass Top, Track Package, Roush Stage 2.
Ordered 6/28/13 / Built 8/23 / Roush Mods Complete 9/27 / Delivered to Dealer 10/8 / Picked up 10/18/13
My Mods: Tint
/ Moroso Oil Separator / GT Track Key Tune / Boss Quad Exhaust / QTP Wireless Cutouts / Diode Dynamics Sequencer / GT500 Rear Rotor Upgrade / CDC Dead Pedal / STO N SHO License Braket
shaneyusa is offline   Reply With Quote
Old 11-14-2015, 05:12 PM   #8
scott_0's Avatar
the MGW race spec is a great piece! absolutely love love love mine
Old 11-15-2015, 08:07 AM   #9
I actually did all that as well. It still had issues. More about the flex because the transmission just sort of floats out there for lack of a more technical explanation.
Old 11-15-2015, 04:52 PM   #10
Noodles76's Avatar
Buying a mgw race spec within the next two months. I haven't seen one negative review of it yet.
Noodles76 is offline   Reply With Quote
Old 11-29-2015, 07:01 PM   #11
It took me forever to get mine to shift at high rpm's but now its butter, This is my set up, Ive done the braided line, pilot bearing, throw out bearing, aluminum flywheel, Exedy clutch, The next mods are what really worked, BMR tubular kmember with solid aluminum motor mounts, I bought the mgw shifter and blowfish bracket and together they work AMAZING...!!! I dont like adding weight to my car but that blowfish bracket WORKS ! All this was done before the MGW race spec shifter came out, so thats why I dont have that, but the only other thing I did was fill tranny mount with window weld to stiffen up that area too, and now there are ZERO lockouts at high rpms, this is just my list of what I had to do and it works for me.
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 11-30-2015, 09:18 AM   #12
Alerotaz's Avatar
I love my MGW (1st Gen) . I also have the Blowfish Bracket and the Trans mount bushing from White line ( I did drill the 1inch hole into it) . Car really feels crisp and tight. I don't have any issues with road vibrations either..
Alerotaz is offline   Reply With Quote
Barton Or MGW short shifter? mats96744 Mustang 101 - Tech Basics | Ask an Expert 13 07-01-2015 07:57 AM
For Sale: FS: Barton Shifter, MBRP Axle backs, Shifter Bushing 1ststang Mustang Parts for Sale and Wanted 8 03-15-2014 06:21 PM
mgw ~vs~ barton short throw shifter nculp9 2011-2014 Mustang GT 16 06-29-2013 09:09 AM
Barton shifter bracket with stock shifter 2011 2011 2011-2014 Mustang GT 5 03-11-2013 07:48 AM
MGW vs Barton Short Throw Shifter Brock23 2011-2014 Mustang GT 26 10-26-2012 04:21 PM
12:32 PM
