Sway bar hitting on LCA relo brackets - Mustang Evolution
Old 11-21-2015, 01:44 PM   #1
tsidewayz's Avatar
Ok, I know that brining up this subject is like beating a dead horse.
After installing the Lakewood relo brackets both ends of the rear sway bar sit up against the relo brackets. There doesn't seem to be any clunking as descried by other with this issue. My question is, outside any annoying clunking or knocking that may be present in this situation are there any other detrimental effects rom the sway bar sitting up against the relo brackets?
Along with the relo brackets I also installed CHE lower control arms, BMR panhard bar, panhard bar relocation bracket, BMR end links (bored out the bushing to 24mm), Tokico HP rear shocks and Steeda torque box support braces.
Thanks.
tsidewayz is offline   Reply With Quote
Old 11-23-2015, 10:25 AM   #2
jande063's Avatar
If the sway bar is in contact with the lca bracket, it MAY (not for sure) cause a certain amount of bind in your rear suspension. I would want to get a real data logger and four linear potentiometers on the axle to plot it's motion to confirm that it is not binding.
My bar has a very small gap between it and both the lca brackets and the watts link frame. That said, I can only use the soft and medium settings, otherwise the geometry will cause serious bind on both objects.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 11-23-2015, 05:44 PM   #3
tsidewayz's Avatar
I'm sure there is some amount of binding going on. I was able to get the bushing clamps on it them with some effort. I don't plan on leaving it like that for long. It looks like, if I want to continue to use the Lakewood LCA relocation brackets, I'll have to get an adjustable rear sway bar.
ID:	193941   Click image for larger version
Old 11-26-2015, 11:12 AM   #4
I have the same problem. I actually found out that the brackets are creating notches in the sway bar. I'm interested in seeing what others are doing so I can get rid of the problem.
SloppyBawlz is offline   Reply With Quote
Old 11-26-2015, 11:55 AM   #5
Grabber Blue5.0's Avatar
I ran BMR lower control arms with their relocation brackets and had enough clearance although it was close. I also had sway bar relocation brackets.
Old 11-28-2015, 10:16 PM   #6
tsidewayz's Avatar
Will sway bar relocation brackets increase he clearance between the bar and the LCA relo brackets?
Old 11-29-2015, 05:28 AM   #7
Nope
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
SR LCA's with relo brackets? 2014oxstang 2011-2014 Mustang GT 19 06-29-2014 08:17 PM
Rear lower LCA's: Do I need the relo brackets? jrolivo1975 General Mustang Discussion 4 04-19-2014 04:14 PM
UMI bolt on relo brackets 5LHO Mustang Parts for Sale and Wanted 1 11-16-2012 01:39 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
» Members Mustangs
Roxie
ashpow24
GTA
Hons67
Add your Mustang
02:16 PM
