Benefit on 101 octane fuel? - Mustang Evolution
Old 11-26-2015, 12:02 PM   #1
grabber12's Avatar
I live in California so my tune is set up for 91 octane. There's a local gas station that sells 101 octane at the pump. Is there a benefit in running 101? Would that require an entirely separate tune? I'm assuming it does.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 11-26-2015, 12:09 PM   #2
I would ask your tuner, but it would be my guess that a 91 octane tune may be preset to advance the timing only as far as 91 octane would allow.
If there IS any ceiling in your tune that allows for additional timing when allowed, your tuner would have to be the one to tell you that, I think.
Guard 5.0 is online now   Reply With Quote
Old 11-26-2015, 12:12 PM   #3
Rapinator126's Avatar
Will not do anything unless retuned to run that fuel.
🍼and 🌽 fed coyote.
Old 11-26-2015, 12:13 PM   #4
scott_0's Avatar
not beneficial at all, will actually cost you power, higher octane fuel burns at a slower rate, which is only useful when running more timing, boost, or nitrous
Old 11-26-2015, 01:55 PM   #5
grabber12's Avatar
Ok I figured. Thanks guys
Sent from my SM-G920V using Mustang Evolution mobile app
Old 11-27-2015, 01:31 PM   #6
olerodder's Avatar
Region: Oregon
When I was trying to have AED tune my 14 I did some data logging and although at partial throttle...from 2000rpm to 5000rpm with a slow and steady pedal...I was getting no knock. At WOT from 3000 to redline I was getting knock. I was running 91 octane with the can'd 91 tune....switched to Costco 92 octane and after a one tank no more knock. Before I used the the Costco 92 I used 5 gallons VP unleaded and the data log also showed no more knock....the VP wasn't cheap!
Have you data logged your current tune and is there any knock...if there isn't I could no used in using the 101 unless you reset your tune for the higher octane..like everyone else mentioned.
Old 12-02-2015, 12:26 AM   #7
grabber12's Avatar
Mike roush data logged my car. I would think he tuned it to remove any knock if he detected anything.
Old 12-02-2015, 09:04 AM   #8
olerodder's Avatar
Region: Oregon
And when you have a higher compression ratio...........
93 OCTANE vs 91 OCTANE TUNE bradtaylornator 2011-2014 Mustang GT 20 12-26-2015 08:07 AM
Fuel Addictive and Fuel Octane Question dseg 2011-2014 Mustang GT 15 07-18-2014 05:07 PM
Ford, Toyota Benefit from Cash For Clunkers, GM and Chrysler Fail OsirisGuy General Mustang Discussion 1 09-03-2009 01:29 PM
Red Cross Benefit Car Show KrazyPony Pictures and Videos 4 10-08-2007 03:32 PM
What else could I benefit from? Moose9648? Pre-2005 V6 Mustang 16 10-10-2004 12:02 PM
10:44 PM
