Will this wheel size work? - Mustang Evolution
Old 11-29-2015, 03:23 PM   #1
Andy2013gt's Avatar
I have a 2013 gt with 235/50 18's on them. And I have found a set of 2015 gt rims front are 255/40 19 and rear are 275/40 19. Will they fit on my 13 as it or do I need to modify the car in any way?
Andy2013gt is offline   Reply With Quote
Old 11-29-2015, 03:39 PM   #2
natestang07's Avatar
They should fit depending on the offset differences between the two.
Old 11-29-2015, 03:45 PM   #3
Isn't the bolt pattern different?
Old 11-29-2015, 04:13 PM   #4
oxford5pointoh's Avatar
No they are the same dude
Op they will fit. Several threads in here where guys have done this. To nates point they are a little different on the offset but so are aftermarket wheels 99%of the time. Just make sure they will clear your brakes if you have a brembo car. If the 15 wheels are coming off a base model car they might not clear if yours is a big brake car.
And looking at what you have now doesn't sound like it will be a prob
Old 11-29-2015, 04:40 PM   #5
Andy2013gt's Avatar
I just have regular breaks. Thanks everyone.
Old 11-30-2015, 03:56 AM   #6
Grabber Blue5.0's Avatar
"brakes" not "breaks"
Old 11-30-2015, 04:14 PM   #7
Diehard's Avatar
They are not the same.
The center bore diameter of the '15's are 73.1 vs. 70.3 (hub centering rings may be recommended-?)
The 15's have 14mm studs vs. the 1/2" studs. (May require different lug nuts-?)
The 15's offset is 40mm: should pose no problem
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
97 v6 Wheel Size Kiljosh Mustang Wheels & Tires 17 11-09-2004 11:26 PM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 10:00 AM
04:40 AM
