2013 5.0 Camshafts - Mustang Evolution
Old 11-29-2015, 05:51 PM   #1
Rickster_1823's Avatar
2013 5.0 Camshafts
sorry to bug everyone about this topic again but i am a noobie with Cams. i tried searching for several posts to get some input but mostly all of them are pissing matches.
i have a few upgrades on my 5.0 and was wondering if it is worth it to get stage 3 cams. i do not care about the Lobe sound, just HP.
Upgrades:
1) Ceramic Long Tubes
2) Off Road X
3) 4.10s
Possible future updrages: (If worth it)
1) Steeda CAI (Steeda Mustang Cold Air Intake - Manual 555-3155 (11-14 GT) - Free Shipping)
2) Stage 3 Comp cams (Comp Cams Stage 3 XFI NSR Mustang Camshafts 191160 (11-14 GT) - Free Shipping)
the steeda CAI clains 44HP gain with a BAMA Tune, i think they are blowing smoke but does anyone one what will be my expected gains with the LT, CAI, Cams and BAMA Tune? and is it worth it?
labor will be done by my personnal mechanic along with my help, so no monvey issues on that end. THanks for the helo everyone.
2013 5.0 DIB; Airaid, JBA LT Headers / JBA Off Road X Pipe to Cutouts; 4.10s; BBK Lower Arms; Barton Short Shifter; E85 BAMA race.
Rickster_1823 is offline   Reply With Quote
Old 11-29-2015, 07:08 PM   #2
Rapinator126's Avatar
2013 5.0 Camshafts
...........................๐Ÿ˜• I was going to help till I saw
Is the car auto or stick?
Boss manifold or CJ will be needed to take advantage of the stage 3 comps. As well as a good valve spring ( at least the ones from the boss ) even though they are a "NSR" cam
๐Ÿผand ๐ŸŒฝ fed coyote.
Rapinator126 is online now   Reply With Quote
Old 11-29-2015, 07:33 PM   #3
I would not go with a Bama tune, there is a lot better out there
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 11-30-2015, 03:45 PM   #4
sorry about that. The car is stick.
I saw so many negative reviews on the Boss manifold due to its capacity to produce HP above 6.5 RPMs. Will the Valve springs allow me to get more RPMs? if so, than I will purchase the manifold and intake.
I had purchased the BAMA tuner due to its reliability. It is very user friendly and convenient. There are a couple of dyno shops around my area than can provide tunes. I will check them out and ask them.
Old 05-03-2016, 09:50 AM   #5
do you recomend any tuning shops in Houston?
i never upgraded to aftermarket camshafts i have no idea if comp cams are good. i am not sure if there are any better brands outthere. what will be best for the daily driver and occasional drag racing? not looking to lose power at low end either.
Old 05-04-2016, 08:08 AM   #6
Joaquin_ii's Avatar
This forum has mention before by rap and others that the comp cams are garbage. You would be better off getting custom grind
Joaquin_ii is offline   Reply With Quote
Old 05-04-2016, 09:15 AM   #7
Unless you are shooting to build an NA package capable of 8000 rpm, cams aren't really worth it on this engine. All they'll do is suck your driveability away but if you aren't able to exploit the additional rpm with better valvesprings, CJ, OPGs, etc. there is no point.
Old 05-16-2016, 08:59 PM   #8
05saleen's Avatar
I'm in the same boat, I am interested in installing cams. I want an aggressive cam, I have installed the cobra jet with twin 65mm TB, American racing long tubes, also in the process of installing nitrous outlet 150 shot with a Nano setup. Any suggestions would be great, I don't mind buying a kit with springs also!
05saleen is offline   Reply With Quote
Old 05-16-2016, 09:00 PM   #9
05saleen's Avatar
Sorry, I was referring to my 2014 Saleen.
Old 05-18-2016, 07:33 AM   #10
noldevin's Avatar
Cams are going to compound the effect a boss manifold would have. They move the power band into the higher RPMs and suck away power from your low end. Drivability should still be pretty good as long as you get cams that don't require locking out variable cam timing, and have a really good tuner working on your car.
Are they worth it? Probably only if you plan on staying NA forever or want more power than the block can handle without being re-sleeved. You'll need exhaust and an intake manifold (boss or cj) to take advantage of them, and probably an aftermarket clutch to be able to shift at the necessary RPM.
noldevin is offline   Reply With Quote
Camshafts for 2013 5.0l Rickster_1823 2011-2014 Mustang GT 3 07-27-2015 12:39 PM
2013 5.0 Camshafts Rickster_1823 2011-2014 Mustang GT 0 11-11-2014 09:28 PM
anyone install FR Camshafts? redfire 2005-2010 Mustang GT 15 10-12-2012 11:55 AM
Camshafts?! tea84 2011-2014 Mustang GT 9 02-06-2012 06:49 PM
O4 3.9 v6 mustang camshafts? Zebs5408 Pre-2005 V6 Mustang 2 10-04-2009 01:54 PM
08:30 PM
