Best way to go? - Mustang Evolution
Old 11-29-2015, 07:24 PM   #1
hitmeagain's Avatar
Best way to go?
I have done lots of reading and research but still not sure what path I want to go down. I have a 14 gt base with 3.73 gears. Im not a drag guy more of a corner carver with maybe one trip down the 1/8th mile a year. I do occasianal auto x and mainly like back roads and tight technical turns. I'm interested In the boss manifold bc I hate the way the car looses all steam right before redline. I'm also thinking of doing the speed master headers (long tubes) and off road x. I know cai's are worthless so I have no interest in wasting money on that. What would you guys do? I'm thinking a tune and off road x would do wonders for the car but long tubes interest me, but i question the gains I'd get off them. In the research I've done doesn't seem to be much of a gain for the trouble of install. I'm thinking boss intake to fix the out of breath problem along with off road x and be done. I already have upper & lower control arms, h&r springs, sr performance sway bars, pan hard bar, Barton's shifter and bracket and white line trans insert and some decent tires.
hitmeagain is offline   Reply With Quote
Old 11-29-2015, 07:30 PM   #2
If there is no inspection in your state I would also get rid of the cats, upgrade your clutch and maybe some wider wheels and tires
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 11-29-2015, 07:42 PM   #3
hitmeagain's Avatar
There is an inspection but they just basically check to make sure there is no cel.
Old 11-29-2015, 09:14 PM   #4
Then I would definitely get cat deletes as a start,then get your tune
Old 11-29-2015, 11:22 PM   #5
If your looking to carve corners you should look up the vorsglag set up
cocaine5oh is offline   Reply With Quote
Old 11-30-2015, 04:01 AM   #6
Grabber Blue5.0's Avatar
It will still be a problem for you since ditching the cats will require you to have both rear o2's turned off. Then you'll fail for two N/A on the test.
Old 12-01-2015, 02:08 PM   #7
JudenInduven's Avatar
You can turn the O2 sensors off with a tune, though. Does that leave the P1000 code on there or something because of the fact that the O2's aren't reading?
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-01-2015, 02:27 PM   #8
Yes they can be turned off in the tune and that will keep the CEL from coming on but if you have emission testing you will fail. Two N/A (readiness tests) will come up and you're only allowed one.
Old 12-01-2015, 02:47 PM   #9
How interesting. I didn't think that two of 'em would come up. Glad I don't ever plan on running without cats on my car
Best way to face sub in the trunk? JHL981 Mustang Audio & Video 11 04-09-2005 07:25 PM
Whats the best way to drag? Ibanezplayer272 Pre-2005 V6 Mustang 7 12-10-2004 08:43 AM
Stock V6 please tell me the best way to go to start bit_cloud Pre-2005 V6 Mustang 25 04-28-2004 05:59 PM
Not the Best Way to get out of the Snow!!! sctalbott The Bar 11 02-25-2004 09:37 PM
the best way???? Fishers Stang Pre-2005 V6 Mustang 17 12-02-2003 06:49 AM
04:28 PM
