Rear axle is not square to the frame - Mustang Evolution
Old 12-03-2015, 10:14 AM   #1
I have a 2013 GT and I tried adding some new wheels last night at Discount Tire. I was putting on KMC 685's 20x10.5 in the rear and when they were installed the drivers side wheel stuck out from the body of my car about 1/2inch further than the passenger side. We thought maybe the backspacing on the wheel was different but everything was the same. I then had a body shop look at it and there was no body work that was done to it so they said it had to be a frame issue. I went home and measured from the rear frame to the outside brake rotor and there was a half inch difference between the driver side and passenger. I called a frame shop and they said that this is typical on mustangs and that the rear axle is not always square to the frame. They said I should get a adjustable panhard bar and that would correct the issue. Anyone else have any issues like this?
The car has not been in any major accidents that I know of. I bought it used in February of this year and it had a clean car fax report.
jclement is offline   Reply With Quote
Old 12-03-2015, 10:19 AM   #2
Strange Mud's Avatar
the PH bar will correct the problem. Was the car lowered? Normally when you lower it you need an adj PH bar to correct it, but not everyone does.
Old 12-03-2015, 10:23 AM   #3
jande063's Avatar
Yes, this is a normal issue, especially for the '13 and '14. My first '14 came from the factory with a major twist in the unibody and front subframe, to the tune of 6.5 degree of cross caster. According to a friend on the engineering team, they had whole batches of cars come out like that, but the problem was corrected for the later '14 cars. An adjustable panhard bar will fix that.
Plus one on adjustment being required if the car was lowered.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 12-03-2015, 10:24 AM   #4
I don't think it was lowered. Everything on it seemed stock to me and the wheel gap look normal like other mustangs. If wasn't lowered would the panhard bar still be the best way to fix the problem?
Old 12-03-2015, 10:25 AM   #5
ok thanks. I've been a ford man all my life but you would think that when you pay 40k for a car they would get it right!
Old 12-03-2015, 10:30 AM   #6
Originally Posted by jclement View Post
ok thanks. I've been a ford man all my life but you would like to think that when you pay 40k for a car they would get it right!
fixed that for ya.....
Welcome to Mevo.
Old 12-03-2015, 10:33 AM   #7
jande063's Avatar
They stamped out over 80,000 mustangs in your year. A few mistakes are sure to slip by QC. This is a relatively tame issue compared to what some of us have had to deal with.
Old 12-03-2015, 10:38 AM   #8
Still love the car though ! Just frustrating!
Old 12-03-2015, 10:47 AM   #9
I'm not sure if I am allowed to switch topics in this thread but what tire size would you guys recommend for that kmc 685 20x10.5. I had 305/35's on it last night and they seemed to bulge over the rim a bit and with that 1/2 inch extension problem they made my stang look like a 4x4. Would 285/35 be a good size on that rim for the rear? I have 255/35 up front.
Old 12-03-2015, 11:11 AM   #10
ILLY's Avatar
Panhard bar will fix that. Remember that even stock springs will soften with time me the car will be lower. Get a BMR panhard bar and you will also feel a better suspension.
ILLY is offline   Reply With Quote
Old 12-03-2015, 06:25 PM   #11
WJBertrand's Avatar
Sounds like it was off-center rather than out of square?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 12-03-2015, 10:18 PM   #12
tsidewayz's Avatar
I personally prefer a slight bulge over the wheel but then again, I'm a bit old school. Ran Dunlop GT Qualifiers' on everything back in "the day". Plus an added bit of protection from the accidental curbing.
tsidewayz is offline   Reply With Quote
Old 12-06-2015, 11:08 AM   #13
Beviking's Avatar
That's what I thought.
Beviking is offline   Reply With Quote
Old 12-06-2015, 11:30 AM   #14
I haven't seen one that didn't have some of this. It doesn't matter, as long as the thrust lines are parallel front to rear, the car will not be affected by this at all. If it irritates, as said, and adjustable Panhard will pull it in a bit.
Old 12-07-2015, 04:52 PM   #15
RJ13GT's Avatar
Mine is a bit off center too. You notice it when you go with wider wheels and tires.
Sent from my SCH-I545 using Tapatalk
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 12-07-2015, 07:03 PM   #16
tj@steeda's Avatar
We have an option for you:
Steeda 2005-14 Mustang Street Adjustable Panhard Bar - Made in the USA 555-2551-A | Free Shipping!
finally have the rear tires centered. easy install,easy to adjust.
- See more at: Steeda 2005-14 Mustang Street Adjustable Panhard Bar - Made in the USA 555-2551-A | Free Shipping!
WEIGHT REDUCTION MODIFICATION, TOO
This helps to not only re-align the rear of your car, but also reduces unnecessary weight! And we all know that less weight results in faster acceleration!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 12-07-2015, 07:56 PM   #17
Diehard's Avatar
Originally Posted by tj@steeda View Post
How much adjustment is available in this Steeda panhard bar?
Old 12-08-2015, 11:14 AM   #18
WJBertrand's Avatar
An adjustable pan hard rod will center the axle at the resting / parked position but when the suspension travels up and down while driving or if you change the load in the car, the axle will sill move back and forth from centered.
-Jeff-
Ventura, CA
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 12:14 PM
18x10 square setup Jayday20 Mustang Wheels & Tires 21 10-04-2013 09:31 AM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
Roush square tip exhaust TheHulk305 2011-2014 V6 Mustang 8 03-01-2013 05:20 PM
Square or Round? Black_Stang Mustang Paint, Appearance & Detailing 14 04-06-2011 10:13 AM
08:08 PM
