Best brake/clutch fluid for DD Brembo 5.0 - Mustang Evolution
Old 12-08-2015, 02:47 PM   #1
Jvibe92's Avatar
What's you guys recommendations. Someone here said to go with mogul 5.1
It is a DD and drag car. Mostly DD. Looking to get away with flushing no less than 1 1/2 to every 2 years preferably.
Is amsoil any good for dot 3 or 4?
Jvibe92 is offline   Reply With Quote
Old 12-08-2015, 07:47 PM   #2
Redonblackpony's Avatar
Motul is one of the best fluids available. I use the dot 4 600. Overkill for street use but great for the trackClick image for larger version
Name:	ImageUploadedByMustang Evolution1449629213.943884.jpg
ID:	194572 around $16 -$20 a pint
Redonblackpony is offline   Reply With Quote
Old 12-08-2015, 10:49 PM   #3
94gtconvert's Avatar
There's something even better ^. This is the newest brake fluid that is safe to run as a DD application. I personally run this and am so happy with it. It's great for the track and safe for daily driving. Only thing is you need to re flush it every 2 years which I do regardless. I seriously recommend dot 5.1, if you don't believe me do a quick search on it.
Name:	ImageUploadedByMustang Evolution1449640147.924585.jpg
94gtconvert is offline   Reply With Quote
Old 12-09-2015, 12:31 AM   #4
Jvibe92's Avatar
Yeah. People here swear by motul 5.1. Only reason I thought amsoil is cause I have amsoil elsewhere in the car
Old 12-09-2015, 07:43 AM   #5
Voltwings's Avatar
I've raced both the amsoil and Motul 600. Amsoil makes great oils, but that brake fluid is sub par, of the two i would take the motul.
Old 12-09-2015, 10:51 AM   #6
Definitely go with the 5.1, you won't regret it
Old 12-09-2015, 11:08 AM   #7
olerodder's Avatar
Region: Oregon
I always thought Ford Engineering had a fight with the "Bean Counters" and lost. I've built a few hot rods with hydraulic clutches mainly because of space constraints........but have never shared the brake and clutch fluid....I just think it's a bad design. A number of people using their car on hard track sessions with Brembo's have complained about the clutch becoming spongy and soft....even when I did a couple of spirited runs over the Cascades I noticed this...so I changed to....not too expensive and only takes 30 minutes to install....also got rid of that "sound tube"....I thought it was a good bang for the buck.
Name:	2015-09-18 08.52.02.jpg
Old 12-09-2015, 11:29 AM   #8
Hmmm.... How much was this exactly? Looks like a great idea.
Old 12-09-2015, 11:39 AM   #9
olerodder's Avatar
Region: Oregon
Shelby Mustang Iso-Clutch Remote Reservoir Kit SHEL031 (10-14 All) - Free Shipping
Old 12-09-2015, 04:02 PM   #10
That kit is way too much. You can buy a remote reservoir from any aftermarket brake company for a lot less. If you go to SVTperformance there is a thread of one from a factory gto. If you don't want to plug fitting on brake reservoir after removing line, order ford reservoir 9r3z-2k478-b. And it wouldn't hurt to replace plastic clutch line at same time. Also, another good option for brake fluid for a dd is Castrol Performance Dot 4, good wet and dry boiling points and very low moisture absorbtion.
Cobrakit is offline   Reply With Quote
Old 12-09-2015, 04:45 PM   #11
Honestly for dd and drag racing, I don't se the need for a fluid upgrade, the only time you need a better fluid are road courses where you have repeated heavy braking for 20 min+ sessions that can actually boil the stock fluid. I have the ATE amber fluid from tire rack and its held up great for two yrs of road course, autocross and mtn road diving, nevr let me down .
rwheels is offline   Reply With Quote
Old 12-09-2015, 07:21 PM   #12
Beviking's Avatar
+1 on that looking like a great idea olerodder! Needed or not, that's flipping cool!
Beviking is offline   Reply With Quote
Old 12-09-2015, 10:49 PM   #13
Jvibe92's Avatar
Doing mainly for clutch reasons too
Random question.
What do you clean powercoat with? I think I messed up. I used brake cleaner and sticky stuff was coming off -__-
Old 12-10-2015, 08:05 AM   #14
olerodder's Avatar
Region: Oregon
Warm water and soap....although I used Simple Green sometimes. Never use harsh chemicals...........
You did screw up because you have started to remove the top layer.
What was powder coated?
Old 12-10-2015, 10:07 AM   #15
Jvibe92's Avatar
Ugh. Yeah. He said he'd redo it without charging me. I powdercoated my brembos
DOT4 Brake Fluid=Clutch Fix Charlie_santos 2011-2014 Mustang GT 36 02-18-2016 11:03 AM
To Brembo or not to Brembo (13 GT?) MustangCPA General Mustang Discussion 14 03-20-2015 09:21 AM
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
04:43 AM
