14 GT squeak - Mustang Evolution
Old 12-09-2015, 08:58 AM   #1
primemover's Avatar
14 GT squeak
I'm getting a squeak from the rear end area of the car when I take off in first. If I baby it I don't get a squeak but if I take off normal or a little spirited I get the squeak. I have the manual trans. No squeaks when I pass over bumps etc. any ideas?
2014 GT brembo package manual trans. 3.55 gears
Roush axle backs
Bama v2 performance tune.
primemover is offline   Reply With Quote
Old 12-11-2015, 10:49 PM   #2
Senior Member
Otroo's Avatar
We had a similar problem with my wife's '14 and Ford replaced the lower control arms and put new bushings in the sway bars under warranty. I have read of several other complaints about the same problem and pretty much the same fix. I would take it in to get fixed under warranty.
Otroo is offline   Reply With Quote
Old 12-12-2015, 05:20 PM   #3
primemover's Avatar
Now that you mention it after I installed my new LCAs I quit having the squeak over bumps problem. Now it's just squeak on accelerate. I'll probably just buy some aftermarket polyurethane sway bar bushings and install them myself. Thanks.
Roush axle backs
Old 12-13-2015, 08:39 AM   #4
Do you have aftermarket poly lcas? maybe greasing time. The rear sway bar end links are notorious on these cars but, they usually create clunking. Ford will generally replace them with better ones under warranty without too much fuss, or you can cure the problem yourself for as little as 25 bucks by replacing the rubber with poly bushings from Energy Suspension. Ol' torchy gets the bushings out pretty quick.
Old 12-13-2015, 12:15 PM   #5
primemover's Avatar
Yes after market poly LCAs. But I just put em on like a month ago. I'll try greasing them again. The problem did go away for awhile after I put them on.
Roush axle backs
Old 12-13-2015, 08:19 PM   #6
Don't overdo it and hydraulic the bushing. Every once in a while with poly, it's good to undo the bolts and grease the metal-poly interface.
Strut Squeak greenpony02 Pre-2005 V6 Mustang 14 03-09-2010 01:21 PM
Rear Axel Squeak a3705872 Pre-2005 V6 Mustang 2 11-19-2009 07:36 PM
squeak noise from front of engine. Blkness General Mustang Discussion 3 09-14-2009 08:29 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
03:57 AM
