Help!!! Loud Tick after oil change!!! 2012(GT) - Mustang Evolution
Old 12-17-2015, 02:09 AM   #1
I've just replaced my oil yesterday with Pennzoil 5w-20 and a bosch oil filter. after work today on the way home near the end of my trip i noticed a loud tick sound coming from the engine bay. I also noticed the tick increase with an increase in rpm's, sounds like it is coming from the drivers side 2nd cylinder but im not sure of the source. please any advice or suggestions would be greatly appreciated. 49,321 mi.
5.0 Sally is offline   Reply With Quote
Old 12-17-2015, 02:19 AM   #2
If its any help i did change brand of filters? im so paranoid that i believe that could be a cause. and its a loud tick not like the other quite ticks that come along with the Coyote.
Old 12-18-2015, 05:30 PM   #3
Go back and replace the filter and oil with the motorcraft stuff. I've had two of these cars and they stay tick free on that, as far as my limited data set tells me they do.
Old 12-19-2015, 08:03 AM   #4
blackie's Avatar
Make sure to check the dipstick. Some people dont realize these cars hold 8 quarts. Check for any leaks , loose filter or pan bolt.
I have done all my oil changes with brands other tha Motorcraft and had no issues.
blackie is offline   Reply With Quote
Old 12-19-2015, 09:02 AM   #5
The Coyote engine is famous (or infamous!) for developing a tick right after an oil change. For the most part, it does not seem serious and sometimes goes away in a few thousand miles or after the next oil change.
Google "5.0 tick after oil change" and you will see what I mean. There is a LOT of information and many posts about this here as well.
Old 12-19-2015, 09:35 AM   #6
oxford5pointoh's Avatar
This is why I prefill my oil filter with nearly a quart of oil prior to putting it on. I believe the time it takes to fill the filter is to blame for this tick. I use amsoil and have changed 3 times and have never experienced the tick
Old 12-19-2015, 04:03 PM   #7
scurfie's Avatar
No tick with Mobil1
scurfie is offline   Reply With Quote
Old 12-26-2015, 09:46 AM   #8
UrMaster's Avatar
It'll go away in a thousand miles or 2
Sent from my SM-G928V using Mustang Evolution mobile app
2011 GT Premium A6 glass roof.
Dynatech LT's, OR-X, Kooks Axle-back, Circle D 5c, Boss IM, BBK 85mm TB, JLT CAI, BMR LCA's, adj UCA & Panhard,Strange 10 way struts, 331 gears tuned by AED.
UrMaster is offline   Reply With Quote
Old 12-28-2015, 07:30 PM   #9
d1984's Avatar
My car had the tick after every oil change with 5w-20 motorcraft and a motorcraft filter. Last week I changed the oil and used Pennzoil Ultra 5w-30 synthetic and an STP extended life filter (Autozone had a package deal). Tick is gone. Of course before this I just went to the dealer for oil changes, and I'm not sure if they primed the filter. I did, and it took a lot of oil so maybe that's the cause. I remember with my old BMW 540i, if I didn't prime the filter it had a nasty rattle on the first startup.
d1984 is offline   Reply With Quote
Old 12-28-2015, 08:26 PM   #10
scurfie's Avatar
If you do your own oil changes you should prime the filter. But you don't have to.
Old 12-31-2015, 10:56 AM   #11
94gtconvert's Avatar
That happens to me every single time I do an oil change. It goes away after a few hundred miles. Don't let it bother you. I know it's annoying, but for some reason the 5.0's with fresh thin oil make that noise.
94gtconvert is offline   Reply With Quote
Engine ticking after oil change?? Eric5oh 2011-2014 Mustang GT 18 10-09-2015 10:00 PM
Well i guess i got the famous oil change tick... Jstorm 2011-2014 Mustang GT 26 03-14-2015 06:20 PM
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
TICK TICK TICK Mustangman705 1996-2004 Mustang GT 13 09-21-2013 06:30 AM
Car shakes after oil change on a 1966 Mustang? Vaiveahtoish Classic Mustangs 2 12-11-2011 04:16 PM
03:14 PM
