BBK Throttle Body - Mustang Evolution
Old 12-24-2015, 02:50 AM   #1
BBK Throttle Body
I was looking to upgrade my throttle body and didn't know which one I should get. I hear mixed thoughts on both 85mm and 90mm BBK. I don't plan on going force induction soon. I would like you guys thoughts on which one is better. If you have either one of these what are the pros and cons. Thanks. Info is greatly appreciated.
2013BlackBeast is offline   Reply With Quote
Old 12-24-2015, 10:32 AM   #2
grabber12's Avatar
Most will tell you they are a waste of money and if your going to stay N/A then go with the 85mm. I wanted to get one but after researching some guys only gain 1-3 HP. I guess if money isn't an issue then grab one and gain your 3HP and call it a day. After all 3 is better then 0.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 12-24-2015, 02:22 PM   #3
Rosariors3's Avatar
What if someone had a blower than is it worth it?
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 12-24-2015, 03:41 PM   #4
grabber12's Avatar
With a blower the 90mm will be the way to go. Im not sure as to the increase in HP it will give when a blower is added. Do a search and see what you find. I searched on this topic when I wanted just the 85mm T body and most of the advice was to not buy one. Its kinda like buying a CAI for these cars, There is little gain for the money. But like said little gain is better then no gain and if money isn't an issue then buy it.
Old 12-24-2015, 04:30 PM   #5
ILLY's Avatar
How about change in throttle response? Did you guys see any improvement with an aftermarket throttle body.
I've got boss manifold and long tubes, I'm really considering a 90mm throttle body.
ILLY is offline   Reply With Quote
Old 12-24-2015, 05:59 PM   #6
thelastsumurai's Avatar
Sub
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 12-24-2015, 10:45 PM   #7
I got a Vmp supercharger and they go with at 130mm tb
Sent from my SM-N920T using Mustang Evolution mobile app
chefron50 is offline   Reply With Quote
Old 12-24-2015, 10:55 PM   #8
Rapinator126's Avatar
A lot of research needs to be done. And a lot of F up assumptions in here also.
🍼and 🌽 fed coyote.
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
Why a 90mm
🍼and 🌽 fed coyote.
Old 12-25-2015, 10:02 AM   #9
grabber12's Avatar
Buy it, Dyno and hit the track and let us all know how it does. I think it will help. 5HP is 5HP you didn't have before the install so JUST DO IT! 85mm
Old 12-25-2015, 12:13 PM   #10
A 90mm throttle body is useless when the inlet opening of the intake manifold is less then 90mm. I believe the boss intake manifold inlet opening is around 85mm. so even if you try to put on a bigger TB, the intake manifold is only going to accept whatever amount of air 85mm is going to allow, think of it as kind of a choke point.
2012 GT Ignot Silver
Evolution5.0 is offline   Reply With Quote
Old 12-25-2015, 01:58 PM   #11
How about porting the intake
Old 12-25-2015, 02:27 PM   #12
That's what needs to be done to run the 90mm. Out of all the throttle body's the only one that has shown gains is the acufab
🍼and 🌽 fed coyote.
Old 12-25-2015, 05:33 PM   #13
Running a different throttle body would require a retune to get the most out of it. What you'll get will probably not be much, if anything at all *WITHOUT* a power adder. On a mostly stock N/A setup its pointless. This is because as others have mentioned the inefficiencies in the intake and exhaust systems will restrict airflow to a greater degree than the throttle body. So the best thing would be to improve those systems instead of the throttle body. Unless you go with a supercharger or somthing of the sort. Then you will want to improve airflow all around as you will see better/ more gains there than if you were N/A
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Old 12-26-2015, 11:08 AM   #14
ILLY's Avatar
🍼and 🌽 fed coyote.
Why a 90mm
🍼and 🌽 fed coyote.
Because I don't know if a 85 mm would be a noticeable improvement over the stock 80 mm.
Old 12-26-2015, 11:14 AM   #15
Well a 90mm is 100% pointless unless you have a boss manifold with a lot of porting and cleanup done to it.
Research a lot of it.
🍼and 🌽 fed coyote.
Old 12-26-2015, 12:26 PM   #16
ILLY's Avatar
🍼and 🌽 fed coyote.
I do have a boss manifold, just not ported. Also have long tubes with off road x pipe. Still trying to figure out if I will benefit from it with my setup. I want a better throttle response more than hp.
Old 12-26-2015, 12:29 PM   #17
BBK Throttle Body
Won't do anything for your. Your car wont benefit from it, unless you have a legit NA build. Spend the money elsewhere.
🍼and 🌽 fed coyote.
Old 12-26-2015, 01:22 PM   #18
I know everyone will disagree but I put on the 85mm and I agree it's probably not worth the money but the car runs so much better with it, a lot better throttle response and smoother accelerating, I'm not so worried about the hp gain as I was the overall better feel of the car, and you will notice it the minute you start your car, a lot of people on here comment on mods that they don't have...
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 12-26-2015, 01:35 PM   #19
^ lol at the people who get the "it works" mindset after a useless mod.
🍼and 🌽 fed coyote.
Old 12-26-2015, 01:38 PM   #20
Say what you will
Old 12-26-2015, 01:39 PM   #21
Originally Posted by brianw64 View Post
Say what you will
Only mod and build these cars for people on the daily. As well as mine. I will put anything on someone's car if they pay for it.
🍼and 🌽 fed coyote.
Old 12-26-2015, 03:07 PM   #22
natestang07's Avatar
So I can bring my car down for a Cummins swap?
Old 12-26-2015, 03:33 PM   #23
I'll do it. Let's do a 12v swap though.
🍼and 🌽 fed coyote.
Old 12-26-2015, 03:39 PM   #24
BBK Throttle Body
Old 12-26-2015, 07:07 PM   #25
🍼and 🌽 fed coyote.
This is it. The above has been repeated a few times in this thread. If you really want to get a larger throttle body OP, fine then do it. It does not change the fact that it will do nothing for your current setup. You can spend your money and do what you want. I would re-iterate that it is a waste of money, and it will cost you more time and money to get the same, or close to OEM drivability. Because you are not going to have access to all the data that would need to be entered into SCT/HP/ your tuner of choice. So to recap, spend money on a TB (on your current setup which is mostly stock) is a complete waste when evaluated for performance. It becomes neutral, or even negligible after lots of tuning when evaluated for performance. Net, you are out money for the TB + time AND money for tuning the car for basically factory drivability.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 12-28-2015, 10:18 AM   #26
grabber12's Avatar
Let me do it >>>>> When a manufacturer states that a part gives 10-15HP its very misleading for the consumer. Im guilty of buying into the hype myself. But even more misleading is forums like this at times. For example some will say they gained power and ET and some will say it did nothing. The manufacturer fails to explain how they get the power from there parts most of the time. Im sure with this BBK TB the test car had supporting mods and then a retune for he TB and that's how they got a gain. So installing it and doing nothing else, more then likely will give nothing. Then we have the placebo effect aka "butt dyno" where people think the car gained but have zero proff, where there car idle raised by 100rpm and they says it runs smoother. We need more well written write ups with installs and dyno numbers or ET's before and after. But we don't we have word of mouth. SO......... if you can find a TB for cheap then buy it and set it aside until you get some other mods and then toss it on but IMO its a lot of money for 5HP. Ive been in the market for one but cant find it cheap enough.
BBK 73mm Throttle body or BBK Shorty Headers 1Mustang805 2011-2014 V6 Mustang 17 09-09-2015 03:57 PM
JLT CAI with Steeda spacer, or BBK CAI and BBK throttle body? Aventador97 2005-2010 V6 Mustang 11 02-26-2014 03:12 PM
BBk Headers, and Throttle body... Fast93Coupe 1979-1995 Mustang GT 18 09-16-2006 12:25 AM
BBK Throttle Body and Cold Air Kit rbwheeler 2005-2010 Mustang GT 21 06-20-2006 06:47 PM
$150 For Sale NEW BBK 70mm throttle body for 3.8L V6 2001-2003 bumlebee Mustang Parts for Sale and Wanted 2 07-31-2004 09:54 AM
01:03 AM
