Dyno Results - Mustang Evolution
Old 12-29-2015, 08:31 AM   #1
ILLY's Avatar
Dyno Results
So after installing bolt ons to the car I decided to dyno it.
Mods are: boss302 manifold, jlt cai, bbk long tube headers, off road x pipe. Tuned by Shaun at AED
Car made 401whp at 7300 rpm on a mustang dyno. Tech said that its about 461whp on a dyno jet.
I know I can rev much higher and I plan to, but didn't wanna push the car right after installing this stuff.
What do you guys think of these results?
ILLY is offline   Reply With Quote
Old 12-29-2015, 09:22 AM   #2
Diehard's Avatar
I think you have to dyno before and after installing bolt ons, with the same dyno, to see the difference. Anything else is speculation.
Old 12-29-2015, 09:39 AM   #3
No catback?
Old 12-29-2015, 10:48 AM   #4
I'd say OPGs are a good investment if you are going to raise the rev limiter on these engines.
Got the dyno chart? Post it
Old 12-29-2015, 11:26 AM   #5
ILLY's Avatar
The car was bone stock before so I didn't dyno it before installing the mods.
It also has Roush axle back with stock over axle pipes.
Unfortunately I didn't take a picture of the chart but it did look really good. Solid hp incline without any drops
Old 12-29-2015, 09:02 PM   #6
Get rid of the stock overaxle pipes. Longtubes and a good mid pipe and then try to squeeze it all through those small pipes is counterproductive.
Old 12-29-2015, 09:52 PM   #7
RJ13GT's Avatar
The stock over axles arent a restriction. I wouldnt waste the money or effort in replacing them.
Sent from my SCH-I545 using Tapatalk
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 12-29-2015, 10:01 PM   #8
Rapinator126's Avatar
Dyno Results
461 on a dyno jet lmfao ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
Most tuners will tell you this Bc a dyno jet reads higher. Truth be told though when a dyno is calibrated correctly with a true SAE reading they will not be far off.
Also if your power peaked at 7300 with the boss it's 1 of 2 things.
1- cam timing needs adjustment
2- ( one I'm betting on ) the BBK headers are equal or worse than the stock ones, and are restricting flow up high. Same thing will happen with stock manifolds
๐Ÿผand ๐ŸŒฝ fed coyote.
---------- Post added at 11:01 PM ---------- Previous post was at 11:01 PM ----------
Actually they are
Old 12-29-2015, 10:04 PM   #9
RJ13GT's Avatar
Actually they are
They support plenty of power. Why dont catback systems yield any real gains while they change out the overaxle pipes?
Old 12-29-2015, 10:10 PM   #10
They do yield gains actually. All depends on the setup you have,
Just as anything else does. Can't go off all the baby cars that people have.
Old 12-29-2015, 10:16 PM   #11
RJ13GT's Avatar
Yeah but on a near stock bolt on cars like we are talking about here... the stock overaxles will be more of a waste of money to bother with. Bigger builds like you are used to might have a benefit from a larger diameter pipe but we are talking about near stockish cars here.
Old 12-30-2015, 05:57 AM   #12
461 on a dyno jet lmfao ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚ํ ฝํธ‚
ํ ผํฝผand ํ ผํผฝ fed coyote.
Actually they are
I was going to mention the BBK longtubes too but I always get accused of bashing cheaper headers and people "arent' going to pay $1200 for ****ing headers" when I tell them to look at Kooks or Dynatech or something. Whatevs.
These
https://www.afcodynapro.com/DYNATECH/634063936
Little cheaper than the Kooks and every bit as good quality. Fully equal primaries and way better craftsmanship/performance than the BBK.
Old 12-30-2015, 07:35 AM   #13
ILLY's Avatar
Dyno Results
Actually they are
I didn't peak at 7300. Since everything was fairly new I decided not to rev the car any higher. The power kept increasing but we stopped the pull.
Haven't had a problem with the bbk headers, fit and finish were perfect. They are not restricting any flow
Old 12-30-2015, 07:45 AM   #14
Jvibe92's Avatar
Over axle pipes are good for ~7hp. Most averaging closer to 4-5 issh. There's some dyno charts over on svtp showcasing it.
Jvibe92 is offline   Reply With Quote
Old 12-30-2015, 08:23 AM   #15
Oh but they are I promise.
Old 12-30-2015, 08:36 AM   #16
If that is to the wheels with just a set of overaxle pipes then that's a pretty worthwhile gain. And was that with a full longtube/midpipe in front of it or just going from axleback to catback? Because if they were just going from an axleback to a catback with the stock headers and mid pipe in place its going to be WAY more of a restriction with longtubes and aftermarket mid pipe in front of them.
The BBKs don't have equal length primaries do they? Do the Coyote BBK units have the pinch in them for the steering shaft like the 4.6L BBK longtubes do or did they actually figure it out properly for the Coyote?
Old 12-30-2015, 04:55 PM   #17
zinc03svt's Avatar
If your not lifting weights and spending 10k plus on your motors...your all driving baby cars. . Go Rappo go. Lol.
zinc03svt is offline   Reply With Quote
Old 12-30-2015, 05:38 PM   #18
That's correct they do not have equal length. Last set I saw didn't have the pinch.
Old 12-30-2015, 05:40 PM   #19
Lol see someone saw the humor in it. ๐Ÿ˜œ
Old 12-30-2015, 05:59 PM   #20
zinc03svt's Avatar
Lol. I have to pop in here occasionally to make sure the BS is flowing well.
Old 12-30-2015, 08:25 PM   #21
oxford5pointoh's Avatar
These threads crack me the hell up
Old 12-30-2015, 10:50 PM   #22
This thread is many lulz
Old 12-30-2015, 11:14 PM   #23
Jvibe92's Avatar
It was only on a full exhaust setup where it gained some power. Also you gotta remember. Just a couple hp, even 5-7 is negligible
Old 01-01-2016, 03:18 PM   #24
thelastsumurai's Avatar
The factory headers that everyone raves about are not equal length ... Why do people have to pi$$ on other peoples mods??????????
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 01-01-2016, 03:20 PM   #25
Dyno Results
The header on the coyote is called a tri-y header. So that whole "equal length " argument is out the window.
Next.............
Old 01-01-2016, 03:22 PM   #26
You know it all don't you rap. No argument just facts. They are still unequal pipes. Unequal pipes have no place in hi flo dynamics..
Old 01-01-2016, 03:30 PM   #27
It's a Fing tri-y header so of coarse it's a unequal header.
Old 01-01-2016, 03:39 PM   #28
Course*.
Unlike your coarse hands.
Old 01-01-2016, 03:49 PM   #29
Course*.
Who cares. I know I don't. I'm still #1 ๐Ÿ˜‰
Old 01-01-2016, 05:35 PM   #30
Coarse hands mean you work for a living.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 01-01-2016, 05:36 PM   #31
I was giving him a hard time about the spelling correction he gave me
Old 01-01-2016, 05:39 PM   #32
Psmith129's Avatar
I wonder if other forums are this entertaining . Where else can you learn a lot about cars and be entertained to this degree .good stuff
Psmith129 is offline   Reply With Quote
Old 01-01-2016, 05:56 PM   #33
Lol yes but still true.
Old 01-01-2016, 06:01 PM   #34
Dyno Results
Here I will put his here. My boy just picked this up $300. Real budget build. Stud it single 96mm in his sleeper truck
Name:	ImageUploadedByMustang Evolution1451696471.499927.jpg
LSX 408 FTW
Dragging your a$$
Old 01-01-2016, 07:14 PM   #35
Compstall's Avatar
LS motors up here are treated like gold, $1000 for anything worth messing with.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Dyno Results: X pipe over Y pipe Rygen Pre-2005 V6 Mustang 8 03-13-2006 05:54 PM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 09:36 AM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 07:07 AM
Air Silencer Dyno results ? drichard Pre-2005 V6 Mustang 4 10-15-2003 05:10 PM
02:18 PM
