How many miles on your stock brembo pads (per set)? - Mustang Evolution
Old 12-29-2015, 10:55 AM   #1
Region: New Mexico
Hello everyone, i know this alp depends on a thousand plus variables but I'm just curious, how many miles have y'all gotten (per set)on your brembo beagles before replacement is needed.
Next is, what'd you use to replace them? I absolutely hate the beale didst they expel!
Thanks
Slim
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 12-29-2015, 11:09 AM   #2
In a couple years of city driving they were about 1/2 worn up front. Watch it, the rears will wear out before the fronts do. They are small and the TC and SC are regularly interfering without throwing up a light on the dash.
Old 12-29-2015, 11:21 AM   #3
Region: New Mexico
I ask because i am 1.5 years in at roughly 33k miles and need new pads, maybe rotors. I know they perform well but i guess i was thinking 33k is a fairly short life span.
I didn't think i was hard on my breaks but that's why I'm asking y'all how yours went.
Old 12-29-2015, 12:16 PM   #4
The BBP pads combine good bite with an aggressive compound that eats rotors quick, too (as well as producing an unbelievable mount of dust). There is no point in machining a rotor on a modern car, as there isn't much meat on them because materials are better and the manufacturers are trying to keep unsprung weight down. Just replace them, they aren't that expensive anyway.
Old 12-30-2015, 12:31 PM   #5
olerodder's Avatar
Region: Oregon
Although my 14 TrakPak is gone it had 11k miles and was only 30% gone. I did switch to the GT500 rear rotors and stock pads at 6k miles and they hardly showed any wear.
I have had OE disc brake rotors turned on my 2010 Dodge Ram pickup, my wifes 2009 Toyota Venza, son-in-laws 2012 Nissian Altima....the list goes on. I wouldn't buy rotors unless they can't be turned....it's a waste of money as far as I'm concerned. Spending $20 per rotor is a lot less expensive than $100 per rotor for new........IMHO
I really never got that much brake dust off the Brembo brakes.....maybe because I washed the car often...........never had an issue with the rears either.
Old 12-30-2015, 12:43 PM   #6
Cutting rotors means cutting the thermal mass that makes them work.
Old 12-30-2015, 12:52 PM   #7
olerodder's Avatar
Region: Oregon
How much thermal mass do you loose by turning the rotors 0.010"?
Old 12-30-2015, 02:24 PM   #8
Koryak's Avatar
If you want rotors to really last pay a few dollars extra for cryogenic treating. I got some (Stop Tech) for an import that is really hard on brake parts. With ceramic pads the rotors still had machining crosshatch after 3000 miles of stop & go! Freaked me out but the brakes were working fine both cold & hot with no change in pedal pressure from OEM.
Koryak is offline   Reply With Quote
Old 12-30-2015, 02:49 PM   #9
Region: New Mexico
I know a Ford Ranger is MUCH different but using a similar combo i have about 135k on that set. No bs'ing!
Needless to say i was going to get something similar for sure. ..
Old 12-30-2015, 04:42 PM   #10
A lot of thermal mass. You have used rotors alreadly worn down, then you add the cut to that. Modern rotors don't have a lot of extra meat in them, for the reasons I outlined before.
Thermal mass, for those that don't know, is a measure of the ability of the rotor of drum to turn kinetic energy into heat, without its properties changing or becoming distorted.
Old 12-30-2015, 04:53 PM   #11
oxford5pointoh's Avatar
That's why there are minimum specs. You are not going to notice anything if it's done within spec.
Old 12-30-2015, 05:11 PM   #12
olerodder's Avatar
Region: Oregon
As Oxford mentioned, every OEM rotor is mandated to put the minimum required thickness stamped into the rotor and no brake shop will turn a disc/drum below that. Having to buy new rotors every time you replace the pads is a myth....one that brake manufactures like to perpetuate.
With that said the amount of normal wear plus 0.002" is where they would turn the rotor down to....in most cases it will not be more than 0.015/0.020" total after turning....which equates to such a small percentage of thermal mass loss that it would be negligible and I doubt you could notice any difference in normal driving.
When I was drag racing I used lightweight solid discs and would change them every two seasons along with the pads......in SCCA racing we would usually change pads every 3rd/4th race weekend and turn the discs until they got below the minimum thickness.
Old 12-31-2015, 08:33 AM   #13
Region: New Mexico
So the dealer just called and said new stock (Brembo) pads were 620 alone, plus turning the rotors, plus labor. Came out to $1500-$1600 for just a break job? Does this sound right? This sound crazy to me! I bought a service contract so I'm not to worried, it just seems ludicrous.
The funny part was the contract was bought for $1500 and included 10 oil changes, the above mentioned break job, and a tranny service. Apparently the lady charged me for the wrong one. That lady screwed up on so much i basically bought the car for half off, it was a hell of a deal!
Old 12-31-2015, 08:35 AM   #14
Region: New Mexico
Double post, sorry.
Old 12-31-2015, 09:44 AM   #15
Diehard's Avatar
Ridiculous!
Old 12-31-2015, 10:44 AM   #16
Koryak's Avatar
So the dealer just called and said new stock (Brembo) pads were 620 alone, plus turning the rotors, plus labor. Came out to $1500-$1600 for just a break job? Does this sound right? <snip>
I did some research for my Brembo TP and found the pads are sourced by Ford from an American company that also made pads for the modern Boss 302. I tried contacting them but got no reply on the compound specifics. $620 for a set seems really high unless they have some very special compound.
Old 12-31-2015, 11:54 AM   #17
olerodder's Avatar
Region: Oregon
You bought a service contract that covered brakes.....I've never heard of one that covers normal wear and tear items like brakes or was this some kind of special service contract the dealer made up?
A normal brake job on all four wheels is anywhere from $400/600 which includes turning the discs and new pads.
If I were in your shoes I'd run not walk away from that dealer....I assume it is a used car dealer and not a new car dealer..........I'd be tempted to turn them in to the Better Business Bureau.
Old 12-31-2015, 11:59 AM   #18
olerodder's Avatar
Region: Oregon
The brake pads for the Boss 302 and TrakPak are the same....ceramic. The Laguna has non-production pads that are expensive.
The Boss/Brembo pads are list for $227 and with a jobber discount you should be able to buy them for $150. Part #7R3Z-2001-A.
Old 12-31-2015, 12:33 PM   #19
You may well notice if you need to really push the brakes hard one day.
minimal spec doesn't mean ideal performance, it means the minimum still acceptable. You cut brings it close, if not already to minimum and guess what? In a couple months you are under minimum.
This is totally false economy. There is only .079" difference between the nominal thickness of new front rotors and the discard thickness. Quality BBP front rotors like Raybestos Pro Grade are about $60 on Amazon, rears as low as $25.
Old 12-31-2015, 12:47 PM   #20
You are absolutely right. YOU should buy new rotors.
Old 12-31-2015, 08:38 PM   #21
BigJay's Avatar
Anyone that is running the stock brembo pads that has not had problems with brake fade will likely never have a problem with a light resurface on the rotors. Their brake needs are moderate. For people pushing the brembos to a point fade and needing a track pad I would agree with new rotors.
If you are looking for a great street pad with little dust look at the carbotech 1590. $170.00 for the fronts
BigJay is offline   Reply With Quote
Old 01-01-2016, 06:28 AM   #22
OX1
Of the 42 vehicles I have owned, I can't say I have felt any difference in really hard braking in any of them after cutting rotors, and I've run the gambit on different types of vehicles, IMO.
I do admit, that 6 didn't have any rotors, and 3 have so little mileage, I don't know yet.
1960 Ford Thunderbird-352 *
1963 Dodge Polara-383
1965 Ford 500 302-4DR
1969 Ford Galaxie -351W 2 door
1970 Ford Galaxie -351W 2 door
1970 Camaro SS 350, 4-Spd
1970 Ford Bronco sport -302 *
1974 Ford Bronco-351W *
1972 Monte Carlo-454
1976 Ford bronco-302
1977 Ford Bronco -302
1977 Lincoln Town Car -460
1978 Ford bronco 351m/400/460 (qty 7) * =1
1979 Ford bronco 351m/400 (qty 5) *= 1
1979 Ford F250, 400, 4 spd $1700
1979 Ford F350 460/C6
1986 Mercury Capri , 5.0 5 spd *
1988 Nissan Pulsar, 5 spd
1990 Eagle Talon turbo, AWD, 5 spd
1992 Mitsu Mirage hatch, 5 spd
1994 Ford Probe, 4cyl, 5 spd
1994 Chevy Blazer -4.3/4WD/auto
1995 Ford F250 S/Cab-460/E4OD/4WD $8000 net
2003 Subaru WRX, 5 Spd
2003 Mitsu Evolution *
2005 Dodge 2500 4dr diesel/auto *
2008 Mazda6 auto
2014 Ford Mustang - V6
2014 Ford Mustang-GT /auto *
2015 Ford Fusion, 2.0 AWD *
* = currently own
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
Old 01-01-2016, 11:27 AM   #23
DallasStang77's Avatar
Just swapped out my pads like 300 miles ago.
Was worn and started squealing at 53,500 miles
I allow the engine to break before hitting the intersection at lights and stops so it helped the longevity.
Old 01-01-2016, 03:56 PM   #24
Koryak's Avatar
Originally Posted by BigJay View Post
Anyone that is running the stock brembo pads that has not had problems with brake fade will likely never have a problem with a light resurface on the rotors. Their brake needs are moderate. For people pushing the brembos to a point fade and needing a track pad I would agree with new rotors.<snip>
I agree. I measured a front Brembo caliper temperature of only 340 degrees after 10 hard braking tests from highway speeds. Zero fade and no fluid problem. The rear Ford calipers were 20 degrees cooler so Ford did a great job for street and anything but full on track hooning
how many miles per tank does ur mustang get. cheelyb09 2011-2014 V6 Mustang 121 03-29-2016 06:01 AM
How many miles is too many to add a supercharger? Joe Dirt 222 2005-2010 Mustang GT 11 02-03-2015 12:06 AM
$738.47 per Brembo rim... Rynarok Mustang Wheels & Tires 22 09-16-2013 07:16 AM
Can i install a miles per hour gauge from am mucle over the km per hour? 94gtconvert 1979-1995 Mustang GT 5 06-04-2013 07:08 AM
chewed out bc of miles per gal shsfresh87 General Mustang Discussion 3 03-17-2012 08:52 AM
07:47 AM
