Squeaking Noise coming from rear of car - Mustang Evolution
Old 01-03-2016, 04:23 AM   #1
Region: New Mexico
so recently I've come to notice a really bad squeaking noise coming from what sounds like the trunk, or the rear suspension somewhere. It occurs pretty much all the time when I'm driving, unless I'm on a brand new paved road. I was curious if anybody has had the same problem with their car. I just replaced my rear lower control arms so that isn't the location, just an FYI. Thanks in advance.
BlackCoyote is offline   Reply With Quote
Old 01-03-2016, 09:21 AM   #2
Did you torque everything back to spec when you finished your install?
Old 01-03-2016, 10:04 AM   #3
Greased properly.....?
If not speed dependent that would indicate brakes, look to the sway bar end links, as they are primary culprits. Shoot them with some silicone lube and if the noise goes away temporarily, there you are.
Old 01-03-2016, 10:41 AM   #4
JohnnyBob's Avatar
Had same problem with my 3.7 about a year ago. Replaced rear seat bar with and H&R bar and noise was gone.
JohnnyBob is offline   Reply With Quote
Old 01-03-2016, 12:41 PM   #5
Region: New Mexico
Might have to try that thanks, I've read the sway bar links tend to squeak a lot so hopefully that's the culprit
Old 01-03-2016, 12:49 PM   #6
Region: New Mexico
Seat bar?? What's that
Old 01-03-2016, 01:34 PM   #7
JohnnyBob's Avatar
Sorry auto correct...
It's the sway bar links that cause the issue. Took it to the dealer and quoted me $100 for the bar and about $300 labor. So I just bought the H&R bar for about $350
Old 01-03-2016, 02:47 PM   #8
Region: New Mexico
Cool thanks for the info!
Old 01-03-2016, 03:21 PM   #9
Still warranty? Ford will replace these with better parts for free. They won't hardly put up a fight for this ongoing issue.
Seriously, $400 bucks, PFO. It's a 16 dollar part each and a half hour's work max.
What I did was replace the rubber in the factory end links, even though mine were silent after Ford replaced them. I used the poly bushing rear sway bar kit from Energy suspension. That was 25 bucks and a couple hours to burn out the rubber and install the poly. Bear in mind your sway bar size when ordering. BBP, TP and PP cars have 24 mm, regular GTs have 22.
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
Insane squeaking noise coming from rear OneSlow95 1979-1995 Mustang GT 5 11-16-2014 03:00 PM
Squeaking noise coming from belts sLbxO143 1996-2004 Mustang GT 11 02-25-2013 02:08 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
05:36 AM
