2010 GT clicking sound when turning over - Mustang Evolution
Old 01-05-2016, 04:24 PM   #1
WNet to go start my 2010 GT haven't started it in 2 weeks it's winter. When I turned the key it only made a clicking sound and didn't Fire over the dash lights were lite up started to flash on and off. Any ideas what it could be??? Dead battery...starter??? Thanks for your help!!!!
Ckop3 is offline   Reply With Quote
Old 01-05-2016, 04:46 PM   #2
Robostang's Avatar
I'm betting on the battery. Is it the original battery?
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 01-05-2016, 04:52 PM   #3
I am thinking it probably is still the last couple times I have ran it, it's turned over harder then normal. Was thinking it was just because of the cold but now it won't turn over at all
Old 01-05-2016, 05:20 PM   #4
504gt's Avatar
Charge the battery or use some jumper cables and try again, should start up
504gt is offline   Reply With Quote
Old 01-05-2016, 06:00 PM   #5
Robostang's Avatar
Very typical behavior when a battery is at its end of life. As the above poster suggested, try jumping it with another car. If it starts the. It is most certainly the battery. Cold weather is hard on a battery.
Old 01-05-2016, 06:41 PM   #6
Diehard's Avatar
Once started again you should seriously consider a trickle charger to keep your aging battery from going dead on those constant draws, even when not in use.
Alternately try to run it for 10 -15 min every few days or so. Driving is better than just idling, if possible.
Typically a good battery could go longer between charging but sounds like yours is weak.
Old 01-06-2016, 10:50 AM   #7
Region: New Mexico
I've used a battery tender for years. Currently using the same battery tender that Harley-Davidson sells for their batteries. Charges battery to full charge, and then goes into a storage mode. Never had a failure.
rogcat1 is offline   Reply With Quote
Old 01-06-2016, 12:24 PM   #8
Strange Mud's Avatar
w/o insulting clean/tighten battery cables......but battery is my prob. guess after seeing WI in your signature.
Old 01-06-2016, 12:56 PM   #9
Time to buy a battery
Old 01-06-2016, 02:22 PM   #10
Diehard is right. I've been using a trickle charger for years. Spend a few bucks more for a good one,it will return good service for years to come. I can't believe that's the original battery from 2010. If your still driving it go down to Auto-Bone they will test it for zero.
goman is offline   Reply With Quote
Old 01-07-2016, 08:09 PM   #11
Diehard's Avatar
When I was older, I had a Grand Marquis that had the original 10 year old battery that was still strong as ever when I traded it in.
Old 01-08-2016, 04:37 AM   #12
When I was older...........
Is that because you've been older for a while?
Old 01-08-2016, 02:59 PM   #13
Diehard's Avatar
Thanks!
It's because only old people own and drive Mercury Grand Marquis's.
Now that I'm on social security, I drive Chargers, Mustangs and who knows, maybe a Camaro soon.
Clicking noise when turning 99ford 2005-2010 V6 Mustang 0 10-09-2014 11:13 PM
Not Turning Over Pearson289 Classic Mustangs 27 01-15-2014 02:51 PM
HELP!!! Whistling sound coming from the front/ engine making a clicking sound. Whitestang23 2005-2010 V6 Mustang 5 07-03-2013 04:36 PM
starter wont stop turning over car niteninja87 1979-1995 Mustang GT 7 09-15-2009 07:26 AM
How do I fix the clicking sound? twentyis1 Pre-2005 V6 Mustang 1 04-30-2007 12:21 AM
08:25 AM
