Speed vs RPM for 3.73 gears on a MT-82 - Mustang Evolution
Old 01-07-2016, 05:00 PM   #1
Jvibe92's Avatar
What are some common numbers for speed vs rpm? I feel like my speedos off after retuning
Jvibe92 is offline   Reply With Quote
Old 01-07-2016, 06:43 PM   #2
Rosariors3's Avatar
I58mph at 7rpm
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 01-07-2016, 07:35 PM   #3
Diehard's Avatar
Need to know your tire size, trans. gear and final drive ratio.
For example:
tire = 27" dia
6th gear = 0.65
rear end = 3.73
At RPM = 2000
Speed would = approx. 66 mph
Old 01-07-2016, 07:46 PM   #4
Jvibe92's Avatar
Tire size is 26.97in
Gear is 3.73
@2k rpm my car is showing a hair over 70?
Old 01-07-2016, 07:59 PM   #5
Diehard's Avatar
Gear is 3.73
I use this online calculator.
Speedometer, Gear Ratio, and Tire Size Calculator
Assuming it's fairly accurate, to be within the recommended 3% error range, you should be seeing between 64 and 68 MPH.
EDIT: My experience has been, it's kind of tough to distinguish exactly when you're at an exact RPM and a specific MPH.
Old 01-07-2016, 10:14 PM   #6
Senior Member
Spartanator's Avatar
Do you have a speedometer app on your phone?
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 01-07-2016, 10:52 PM   #7
Jvibe92's Avatar
No. How accurate are they? I'm assuming is need an obd2 dongle to use it?
Old 01-08-2016, 04:32 AM   #8
Strange Mud's Avatar
I've used my GPS to compare #'s. With 3.73's that does sound like it's reading slow
Old 01-08-2016, 11:26 AM   #9
Senior Member
Just an app. No dongles.
It will run off the phones gps, doesn't connect to he car in anyway. Mine is within 1mph. My Escort 9500ix is usually 0-2 mph off.
MT-82 hate.
Old 01-08-2016, 02:47 PM   #10
Diehard's Avatar
Yeah but what are you assuming is the correct one of the three?
The car's speedometer is only required to be within plus/minus 2.5% (from the factory) by federal law. So that's plus/minus 1.5 MPH at 60 mph.
Old 01-08-2016, 11:01 PM   #11
C013RA's Avatar
I had a Diablosport Predator tuner, for my old Mustang, and you would look up the tires revolutions per mile, and put that into the programmer along with your rear gear ratio to set up your speedometer if that's what you are trying to do. Do you have a tuner?
Had 6 Mustangs. I now have a 2016 GT350. I don't see myself getting anything else now. Only mods are a resonator delete, and a GT350R wing. I love the power, and the handling. Prior to that I had a 2015 Performance Pack GT with the MT82 and a lot of mods, a 2012 GT/CS with the 6R80. To me that was a mistake. Only Mustang I ever had with an auto. Before that a 2001 Premuim GT with lots of mods. Before that a 2000 V6 My 1st Mustang mistake. Should have stuck with V8's. Before that a 1965 convertible also with a lot of mods.
C013RA is offline   Reply With Quote
Speed versus RPM calculator RBK 2011-2014 V6 Mustang 1 06-13-2015 01:06 PM
4.10 Gear Speed/RPM Video svtlx 1996-2004 Mustang GT 63 03-02-2014 10:16 AM
All Years: 4.10 Gear Speed/RPM Video ColeJohnson Mustang DIY and Technical 0 09-23-2011 11:29 AM
what rpm are you running with your gears stang_gang 2005-2010 Mustang GT 11 04-23-2008 07:07 AM
What Rpm with 3.73 gears at 80 mph? microflight 1996-2004 Mustang GT 14 12-28-2007 01:31 PM
03:46 PM
