Can I use E85 in my 2014 GT? - Mustang Evolution
Old 01-13-2016, 06:14 PM   #1
Devil Strider's Avatar
I passed a station today and I noticed they had E85 as well as regular unleaded. What's the difference in the two?
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 01-13-2016, 06:25 PM   #2
Grabber Blue5.0's Avatar
You would need injectors and a tune,
Old 01-13-2016, 06:40 PM   #3
Thanks. I'll pass on it for now. Doesn't look like I would benefit much from it though.
Old 01-13-2016, 06:44 PM   #4
Rapinator126's Avatar
It's a night and day difference
LSX 408 FTW
Dragging your a$$
Old 01-13-2016, 07:21 PM   #5
Jvibe92's Avatar
I have it. Made a lot in the mid range area. Almost 20tq difference all across the mid range
Jvibe92 is offline   Reply With Quote
Old 01-13-2016, 07:26 PM   #6
LSX 408 FTW
Dragging your a$$
Hmm. I'll look into it later than. Is it much better than the stock tune and injectors? I'm still on those.
Old 01-13-2016, 08:14 PM   #7
Jvibe92's Avatar
Yeah. There's more power for sure. I'm over 400tq thanks to e85. At peak it's only ~10hp but it's under the curve where you feel it. Smells so good too
Old 01-13-2016, 08:50 PM   #8
I really really REALLY wish we had E85 readily available around NJ. Problem is that we have refineries out the *** so its not economical at all to have it here vs regular petrol.
Old 01-14-2016, 03:49 AM   #9
I'm with you. I would like to run it in my mustang and my Focus ST, but it's not readily available in my area.
litfuse is offline   Reply With Quote
Old 01-14-2016, 05:51 AM   #10
Hodor's Avatar
There's a station that sells E85 about 5 miles from my house...I may have to look into this.
What size injectors would you recommend to upgrade to for E85?
2012 GT Premium, Brembo Package, M6
VMP Gen II S/C & Tune, GT500 Axle-Backs/Spoiler/Strut Mounts
Steeda Sports/Shocks/Struts, J&M PHB, GT/CS Chin, MMD Fog Deletes
Hodor is offline   Reply With Quote
Old 01-14-2016, 07:59 AM   #11
utm18's Avatar
I'll be going E85 in the spring. $280 for 47## injectors and $100 for the toon. Money well spent to run 105+ octane.
utm18 is offline   Reply With Quote
Old 01-14-2016, 11:35 AM   #12
VADER50's Avatar
It's the same here in Northern California. There's lots of refineries and very few e85 stations. I have one about 2 miles from me and the next closest is about 40 miles away.
VADER50 is offline   Reply With Quote
Old 01-14-2016, 12:19 PM   #13
Fabman's Avatar
I've been running e85 for years. In my opinion it's not worth it unless you are boosted.
Then you really reap the benefits. N/A you can get Bolt ons to easily make the small amount of power gains you will get N/A with e85. But that's just my opinion.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 01-14-2016, 12:21 PM   #14
Jvibe92's Avatar
Now I may be one of the few, but I'm actually also saving money on e85. Right now I can tank up for 22$ and I still get 280 miles or so on a tank. 300 plus if it's highway.
Old 01-14-2016, 12:28 PM   #15
If I had a few stations near me I'd switch. Problem is if you only have one and you tune for E85 and it goes out of business you are screwed.
Old 01-14-2016, 12:47 PM   #16
E85? You do know that means 15% corn based alcohol, yes? Alcohol is a terrible fuel for gasoline engines and worse for causing corrosion in fuel lines and hates aluminum; it is very corrosive. By using it you will notice a loss in power and gas mileage as well as accelerated deterioration of equipment. You can't really tune your way out of all that stuff. Where possible street clear of it. Cheaper yes, but then do you want to feed your pony hay or oats!
CaptRLD is offline   Reply With Quote
Old 01-14-2016, 01:49 PM   #17
Fabman's Avatar
Its 85 % ethanol and 15% gasoline...and it's not that bad dude, really.
Now straight up alcohol (methanol) is a different story.....that's probably what you are thinking about, but e 85 is not a big deal.
Tuned by AED
Old 01-14-2016, 02:13 PM   #18
Opps, I had it backwards in my missive . . . but that makes it worse! Gasoline has higher energy level that ethanol. A car won't even run on pure ethanol.
Old 01-14-2016, 02:30 PM   #19
Fabman's Avatar
I've been running the stuff for years, many of my buds have been much longer than that. No problems here at all. As long as you are setup for it it's no big deal.
Tuned by AED
Old 01-14-2016, 02:40 PM   #20
2011 Kona Blue's Avatar
No E85 in Maryland near me or Delaware. Never seen E85 in Maryland or Delaware anywhere. I do have access to 100 octane Aviation fuel
Non 🍼and non 🌽fed. I $uck!
Old 01-14-2016, 03:27 PM   #21
Jvibe92's Avatar
A lot of misinformation. Only thing true about what you said is a loss in MPG. That of course is due to the efficiency of ethanol vs methanol causing you to use 30% more ethanol.
Old 01-14-2016, 03:35 PM   #22
I think you need to do more research on E85.
Old 01-14-2016, 03:56 PM   #23
Hodor's Avatar
So, 47#'s are the recommended injectors then?
Now let me ask this: If I were to upgrade to 47# injectors to run E85, would those same 47# injectors work if I were to later install a Vortech V3-Si or Procharger P-1SC-1 tuner kit with a 93 octane tune?
Old 01-14-2016, 04:00 PM   #24
Fabman's Avatar
ID 1000's are the injector of choice.....especially if you are going FI.
Tuned by AED
Old 01-14-2016, 04:04 PM   #25
Hodor's Avatar
Would 47# injectors be adequate to handle the fuel need for the basic Vortech or Procharger kits though?
Old 01-14-2016, 04:37 PM   #26
Fabman's Avatar
I doubt it.....but I'm not a tuner.
Tuned by AED
Old 01-14-2016, 04:39 PM   #27
Nope, not with e85
LSX 408 FTW
Dragging your a$$
Old 01-14-2016, 04:50 PM   #28
Hodor's Avatar
Nope, not with e85
What about with a 93 octane tune?
Old 01-14-2016, 04:57 PM   #29
Fabman's Avatar
Pick your blower and use the injectors they recommend.
If your going FI and also going to e85 just go right for the ID 1000's and save yourself the trouble of doing this twice. Those are the smoothest operating injectors and will have enough capacity to do whatever you want. Your tuner will thank you for it.
Tuned by AED
Old 01-14-2016, 07:17 PM   #30
Waylap1's Avatar
Region: New Hampshire
I will never run E85.
I worked for a large Leo agency near a Ford test track and facility..they GAVE us free police vehicles that only used E85 to test. They were junk and crushed after 6-12 months from the corrosion issues and whatever else that crap eats in the fuel delivery process from the tank to the boom in the motor. Of course, they used this knowledge from our test cars to make them "marketable" but still..... They were absolute garbage to drive and keep running like a new car should run.
These motors were designed and purpose built to burn good old dinosaur guts refined down to sweet smellin gasojuice.
The E85 "flex fuel" labels and tweaks to current vehicles is just added low cost or slightly modified fuel system components to be able to "safely" "also" use E85 and gasoline in the same engine.
I would much rather use E85 or whatever else non gasoline in a motor built and designed just for that fuel.
Waylap1 is offline   Reply With Quote
Old 01-14-2016, 07:20 PM   #31
Take a motor ran on e85 for a 5,000 miles and a motor ran on 93 octane for 5,000 miles, and tear them down. You will never run regular pumpgas again promise
LSX 408 FTW
Dragging your a$$
Old 01-14-2016, 07:31 PM   #32
Huge difference between a "flex fuel" car that changes its own engine parameters to run E85 or regular gasoline, and a car set up and tuned specifically for it. Flex fuel cars are designed so you can run either gasoline or E85 in them, so the engine makes its own adjustments. A car specifically set up and tuned for it, and only that specific fuel ran will be far better than one that is designed to run either.
Set it up right and put on a good tune and there will be 0, zilch, squat, nada issue. In this case with the 5.0, all you need is injectors and a tune.
Old 01-14-2016, 09:29 PM   #33
Jvibe92's Avatar
You can run 47lb injectors with 93 gas on a base tuned supercharger. If you wanna up it then you need id1000.
Old 01-14-2016, 09:34 PM   #34
Hodor's Avatar
Thanks fellas.
I did some searching and reading through the install manuals - Procharger base kits come with 50# and Vortech with 47# injectors.
Old 01-14-2016, 10:15 PM   #35
Fabman's Avatar
E85 injectors have to be much bigger.
Tuned by AED
Can i run E85 in the ecoboost? 89 5.0 stang 2015+ Mustang Ecoboost (and V6) 14 09-21-2015 07:00 AM
e85 yea or no.?. 2014 roush stage 3. liridonroushrs3 Roush Mustang 4 01-20-2015 07:22 PM
How much can i can i negotiate off base model 2014 v6 RyanV8Lee 2011-2014 V6 Mustang 62 09-29-2014 01:55 AM
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
04:21 PM
