Check Engine Light W/ Codes HELP - Mustang Evolution
Old 01-15-2016, 07:39 PM   #1
Laquisha's Avatar
2013 Mustang GT 6spd Full Bolts
I took my mustang to Murillo Motorsports here in San Antonio and they didn't seem to find the problem. They checked the alternator and tried to replace the cam sensors but both didn't seem to be the problem.
Whenever I floor my car I have a loss of power and it sounds really funky, it also doesn't function properly after 4K RPMs. Here are the codes: Click image for larger version
Name:	ImageUploadedByMustang Evolution1452911888.440606.jpg
If anyone could provide information on the next steps I should take, I would appreciate the advice, thanks.
Old 01-15-2016, 07:55 PM   #2
Laquisha's Avatar
Here are the codes to save your valuable time:
Mustang P0443 Evaporative Emission System Purge Control Valve Circuit
Mustang P0010 "A" Camshaft Position Actuator Circuit
Mustang P0013 "B" Camshaft Position - Actuator Circuit
Mustang P0020 "A" Camshaft Position Actuator Circuit
Mustang P0023 "B" Camshaft Position - Actuator Circuit
Mustang P0135 O2 Sensor Heater Circuit
Mustang P0155 O2 Sensor Heater Circuit
check engine
Check engine light codes, Misfire & ignition coil. BeasGT 1996-2004 Mustang GT 5 06-01-2013 02:00 PM
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 10:12 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
07:20 AM
