F'n steering shaft alignment after header install - Mustang Evolution
Old 01-16-2016, 06:36 AM   #1
hobo1's Avatar
Folks, could really use some help here. I know that very few would have exprienced this, but maybe you can think of a creative way to help me rebound.
Installing BBK tuned-length headers this weekend. Memorized the videos and am slowed up by stuck exh collector nuts at the cats. PB & heat so far.
Anyway, to get the steering shaft out, I had to release the steering from locked position because the upper shaft nut was UNDER the shaft - no can reach. I carefully turned the wheel until I could access the bolt and removed it. Then I pulled up on the shaft from under the dash and damn! The steering wheel floated back to some default position, thus killing the wheel-to-steering wheel alignment.
When I put things back together, am I just going to have to guess where the alignment is, get the car on the road and see where the wheel-to-steering position is, then start the process of loosen, adjust, retest?
It must be important to keep this alignment because they say to mark with paint pen - I didn't get the chance. And the wheel is no longer locked. Bill with CJPP says to be careful about a spring in there, too, so I'm worried about risk to that as I work through this.
BTW, I chose 304 stainless BBK tuned length -- I plan to move to a SC and also replace clutch, so no LTH for me.
hobo1 is offline   Reply With Quote
Old 02-20-2016, 01:13 PM   #2
hobo1's Avatar
Answered. I completed the BBK tuned length installation. 304 stainless. They stopped making those. Wrapped them in titanium wrap.
The steering column knuckles have receivers that are keyed so I could go wrong. I did need to turn the wheel a bit to get to the top nut, so lining that up again took maybe 2-3 small changes before the joint would slip on. Drove it - all straight as it was when I began.
THe worst thing about the BBK tuned length install was the driver's side collector flange nut that nearly touches the O2 bung/sensor - no way to get wrench in there. I cut open a 5/8 box end wrench and inched it to flush, then got a few very slight turns with an open end wrench to get maybe 30ft-lb. I'm going to get a crows foot open wrench and retighten along with header bolts in ~300 miles.
Old 02-20-2016, 02:30 PM   #3
scott_0's Avatar
good to see you got it squared away man! when you say "tuned length" do you mean shorties? I know you won't want to hear it, but I wouldn't have wort through the headache of that install for shorty headers
Sent from my S6 using tapatalk
Old 02-20-2016, 04:48 PM   #4
hobo1's Avatar
I know. I put a lot of thought into it. I will want to upgrade my clutch and will not want to remove long tubes to do that. Also, I want the increased torque gain that I might see over long tubes, after adding a super charger - not looking for top end. I had the money, had the time and for me it was about setting up best for future mods I have planned. Point well-taken.
Old 02-22-2016, 01:43 PM   #5
You dont need to remove longtubes when removing tranny? Ive had mine out a couple times and no problems with headers.
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 02-22-2016, 02:53 PM   #6
hobo1's Avatar
and brianw64 has quite a build on his hands, I see in his sig. Gives me ideas for my next upgrades.
Thanks for the comments. Maybe they'll help the next guy.
I sure as heck ain't swappin them out for LT! PIAX5
Old 02-22-2016, 05:37 PM   #7
I havent updated my sig. in a couple yrs, my car is a totally different animal now, and I wasnt being a smart a** I was only saying that you dont need to remove the LT'S to remove the tranny, adding LT'S was still the single most hp gainer of all my mods. switching to e85 is right there with it tho...
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 11:57 AM
02 sensor problems after header install Jon Al 2005-2010 Mustang GT 20 02-22-2015 08:29 PM
02 sensor problems after header install Jon Al General Mustang Discussion 0 02-20-2015 10:00 AM
Anyone Install Aluminum Drive Shaft (After) LCA Relocation Brackets? 2013fiveO 2011-2014 Mustang GT 3 01-11-2014 07:50 PM
Sterring shaft hitting header Chris01 1979-1995 Mustang GT 6 09-21-2011 10:01 PM
07:53 PM
