What brand O/R H-pipe should I get? - Mustang Evolution
Old 01-23-2016, 05:41 PM   #1
Red_Menace11's Avatar
Been looking at Pypes and JBA but they both seem to have fitment issues. Not interested in an X-pipe not a fan of rasp. I want one where the Cat deletes are separate not attached because I plan on just replacing the H pipe first then the Cats if I want more sound after that....What do you guys use?
Thanks
Red_Menace11 is offline   Reply With Quote
Old 01-23-2016, 05:57 PM   #2
I believe SLP makes a pipe like that.
Also an X pipe is not raspy with a good set of straight thru mufflers especially with cats on it.
Old 01-24-2016, 12:29 PM   #3
Grimkreg's Avatar
I don't mean to go against what you said about no x pipe, but have you heard it in person? I was against it and wanted the old school h pipe sound until I heard an xpipe and now i'm glad I went with an x. Really sounds great especially getting on the highway right by an overpass
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Grimkreg is offline   Reply With Quote
Old 01-25-2016, 01:38 PM   #4
noldevin's Avatar
On my Pypes O/R H the cat deletes were separate pieces.
I can't speak for fitment issues because we hacked them up to weld in "cats"
noldevin is offline   Reply With Quote
Old 01-26-2016, 11:25 PM   #5
I got the pypes H pipe, fitment wasn't an issue except the leaks from the cat delete pipes and the H pipe so ended up welding it. If you get the Pypes you will most likely need to weld the cat delete pipes to the H.
visback is offline   Reply With Quote
Old 01-27-2016, 06:26 AM   #6
I have Pypes O/R-H as well. As mentioned above, it comes in two separated pieces like you're wanting. As far as fitment goes, I've always heard that there are issues, but, it's nothing big enough to keep anyone from getting them installed. Personal advice, get it welded.
And you'll need a tune once you take those cats off. Coming from someone who's had both X and H, both sound great. I just liked the note of the H better than the X.
Hope you find what you're looking for bro.
RobGT14 is offline   Reply With Quote
Old 01-27-2016, 08:17 AM   #7
thelastsumurai's Avatar
Had both the X pipe and H pipe on my 2011. Going through a Heartthrob 3" system with Outlaws. Combo sounded juvenile loud with a headspliting drone. Put my GT500 Muffs back on sounded better, Put H pipes on it sounded great. Was told by everyone at Fri nite meet that that combo sounded best, deep and muscular. Sold X pipe to one of the kids, he loves it. Still have the outlaws in my attic, if anyone is interested
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 01-27-2016, 08:54 AM   #8
Was your H pipe an off road version?
Old 01-27-2016, 08:57 AM   #9
Yeah I think I would get it welded for peace of mind, it's just tempting to bolt it on due to that I have a lift I can use
Old 01-27-2016, 09:03 AM   #10
Both my X and H pipes were catted.
Old 01-28-2016, 12:30 AM   #11
Compstall's Avatar
Use a steel sleeve-style clamp from Napa. Fold up some aluminum foil and wrap the joint first, then slide the sleeve over and clamp it down. Been that way for 4 years on my car.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 01-28-2016, 01:44 PM   #12
If you are going to have swappable parts of your mid pipe. V band clamps or have run with leaks or impossible to get apart.
Old 01-28-2016, 02:07 PM   #13
alecas447's Avatar
Mac
Mac o/r H pipe. Flow master super 44s. Accufab 70mm throttle body. Pro comp intake manifold. MSD coils
alecas447 is offline   Reply With Quote
Old 01-28-2016, 02:11 PM   #14
If you are a 04-down then UPR (VRS) and it isn't even close.
Old 02-05-2016, 10:51 AM   #15
utm18's Avatar
I've have a lethal off road H, welds are good and no fitment issues.
utm18 is offline   Reply With Quote
Old 02-06-2016, 11:21 AM   #16
same here
demas is offline   Reply With Quote
Old 02-06-2016, 05:11 PM   #17
Did you have them welded in or just bolted on?
Old 02-06-2016, 05:58 PM   #18
utm18's Avatar
Bolted.
Old 02-07-2016, 01:51 PM   #19
Hodor's Avatar
For those of you that have the off-road pipes welded to the X/H pipe - did you have the shop weld them together while they were on or off the car? I want to get mine welded too, but don't want to have to pull them off if I can help it.
2012 GT Premium, Brembo Package, M6
VMP Gen II S/C & Tune, GT500 Axle-Backs/Spoiler/Strut Mounts
Steeda Sports/Shocks/Struts, J&M PHB, GT/CS Chin, MMD Fog Deletes
Hodor is offline   Reply With Quote
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
What brand of LCA's should I get BeastGT 2011-2014 Mustang GT 61 09-10-2014 08:40 PM
Brand new to Mustangs, brand new to the ME SSVi New Member Introductions & Greetings 5 05-30-2014 06:01 AM
Brand new Auto Meter Phantom oil pressure brand new 0-100psi fast64 Mustang Parts for Sale and Wanted 0 07-26-2005 07:19 PM
09:25 PM
