Question on my 2013 GT - Mustang Evolution
Old 01-26-2016, 06:45 PM   #1
Senior Member
rlma84's Avatar
Being mustang owner few month now and not much experience with mustangs before.
When I'm at a red light at idle. I noticed a slight change on the rpms feels like dropping can't really see it its more like a feel kind of deal and hear a slight change on the sound hard to explain really have to be looking for it to notice it feels like if the car where going to stall but not as bad. It's this normal? Haven't driven any other mustangs so can't really tell if is normal
Sent from my SAMSUNG-SM-N920A using Tapatalk
rlma84 is offline   Reply With Quote
Old 01-26-2016, 06:55 PM   #2
You have a tachometer.........is the needle bouncing up and down? If not, then you just may be feeling the result of a pretty aggresive cam.
If your engine IS varying any significant rpm at idle, then no, that is not normal and needs addressing.
Guard 5.0 is online now   Reply With Quote
Old 01-26-2016, 06:58 PM   #3
Senior Member
rlma84's Avatar
No needle won't shake or move when it happens it's so slight it can only be felt or heard and it last for like half second. Feels like a slight drop
Old 01-26-2016, 07:02 PM   #4
Senior Member
rlma84's Avatar
Also it doesn't do it constantly it happens maybe once or twice at Red light not at every stop that's why I was wondering if any other mustang owner have felt it might even be normal and I'm just being paranoid lol
Old 01-26-2016, 08:09 PM   #5
Diehard's Avatar
It's not abnormal. Probably just the ECU making a minor adjustment for who-knows-what?
Old 01-27-2016, 12:23 AM   #6
It is normal, Ford mentions this in the cars manual too.
visback is offline   Reply With Quote
Old 01-27-2016, 12:26 AM   #7
Renuco612's Avatar
Yeah I get it too. It's normal. It doesn't happen on every red light. It happens less then a second.
Renuco612 is offline   Reply With Quote
Old 01-27-2016, 05:34 AM   #8
Senior Member
rlma84's Avatar
Alright thanks
Old 01-27-2016, 05:39 AM   #9
Strange Mud's Avatar
I believe it is a fuel conservation trick. It tries to idle as slowly as it can w/o roughness, but it will hit the rough edge sometimes.
As already said yep, it's normal.
2012 V6 with suspension, shifting, stopping and sound mods.
Old 01-29-2016, 07:21 AM   #10
OX1
Mine has always been a bit rough at idle when cold, don't notice too much when warmed up, but I also do not typically drive in real cold weather due to salted roads.
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, 18 X 9/10 Bullits with 295/255 NT05's
OX1 is offline   Reply With Quote
Old 01-30-2016, 08:08 AM   #11
DallasStang77's Avatar
I kinda miss my stock 5.0. It was smooth as silk. Now she's like rough and loud as fawk.
But I can't say I've ever felt dips in rpm or ...... hmmmmm dunno if it actually happened or not but now after reading about it I think it happened a few times. Or maybe not.
Video maybe?
Old 01-30-2016, 10:02 AM   #12
c_rizzle's Avatar
As others have said, its the car trying to idle as low as possible to conserve fuel with out being rough. Sometimes its right at that edge, & the AC compressor kicks on & you might notice a little dip as AC compressor kicks in, etc..
If the RPM needle is not significantly moving up & down, there's nothing to be concerned about.
Its also probably more pronounced in cold weather, before the car is fully warmed up. Or if its so cold the car has trouble staying warmed up.
c_rizzle is offline   Reply With Quote
Old 02-06-2016, 12:11 AM   #13
Drago1's Avatar
I agree with c_rizzle, it is probably your compressor kicking on. Try shutting the AC system off and see if you still feel it. If it really makes you crazy you can always by a SCT tuner and then you can adjust your idle. I think it is programmed from the factory at 600rpm. I know I have mine set now at 700 and I like it better.
Drago1 is offline   Reply With Quote
Old 02-06-2016, 04:31 AM   #14
Quick question... What's an AC?????
Old 02-06-2016, 06:49 AM   #15
RWSRWS's Avatar
Generally speaking, 220 - 221..... whatever it takes
In your specific case, it might be the air conditioner.
RWSRWS
2013 GT Premium (auto) Crystalline,factory 19”wheels, black rocker stripe & heat extractors, redline armrests, Silverhorse windows Polk/Infinity speakers, Dynamat GT500A-bcks 1963 Studebaker Avanti R2 Factory Supercharged still own1938 Studebaker President still own 1969 Mustang Coupe, 302 Blue (sold 1978)1966 Aurora Thunderjet 2+2 Fastback - yellow w/red stripes (owned since age 9)1968 HOT WHEELS Redline Mustang 2+2 Gold - owned since age 11
RWSRWS is offline   Reply With Quote
Old 02-07-2016, 06:07 AM   #16
RWSRWS
Ohhhhh the thingy that blows cold air thru those vent thingamajigs on the dash. Got it. I should test to make sure mine works just in case the windows fail. =P
Old 02-07-2016, 03:22 PM   #17
Maybe its just the fan turning on to cool the engine off? Are you driving with A/C on?
12 GT
Borla Airraid Bama Mmd
afterdarkgt12 is offline   Reply With Quote
Old 02-09-2016, 07:13 PM   #18
c_rizzle's Avatar
Fans are electric and shouldn't effect rpms.
The A/C compressor (or alternator) put a little bit of a load on the engine belt, and at very low rpms it could cause a little dip when they kick on.
Old 02-09-2016, 08:48 PM   #19
Rosco3's Avatar
Yeah I see small dips now and then on mine. Nothing out of the normal from my car experience. Definitely if I hit the power windows it dips down but I have had that with my older cars and they did the same thing. My 98 v6 stang dropped way down on rpms at red lights. It was an automatic and if I dropped into neutral it went back up to normal idle situations, but it had a lot of miles. If it doesn't fluctuate a lot I think it's fine. But I'm no mechanic.
Ingot Silver Metallic 2013 Mustang 5.0 Premium, Flowmaster Outlaw Exhaust, Airaid CAI, JLT Oil Separator, MMD Black Zeven Wheels
Rosco3 is offline   Reply With Quote
Old 02-18-2016, 11:58 AM   #20
WJBertrand's Avatar
Mine holds a slight high idle for a few seconds when I first stop sometimes, but it's visible on the tachometer. I think this has something to do with emissions as I've had other cars that do the same thing.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 02-18-2016, 12:12 PM   #21
d1984's Avatar
I wouldn't worry about it unless you get a CEL, it runs rough/feels down on power, or it starts stalling. Maybe you can clean your MAF just to make sure, and make sure your engine air filter isn't clogged. The idle RPM can have slight changes due to various normal reasons
d1984 is offline   Reply With Quote
2013 Mustang Gt Parts! 2013 only!? FORDGT14 2011-2014 Mustang GT 10 12-09-2012 07:40 PM
MGP Caliper Covers for my 2013 GT, and 2013 tips? huhalbert 2011-2014 Mustang GT 12 10-18-2012 04:24 AM
Ford Electronics/Programming Expert? Swapping 2013 Premium Cluster to 2013 Base doofoo 2011-2014 Mustang GT 2 07-16-2012 05:29 PM
06:33 PM
