Nitrous Dyno Numbers Problem After 6200rpm - Mustang Evolution
Old 01-27-2016, 08:14 AM   #1
Droidman86's Avatar
I did a pull N/A and got 425/378 with the mods you see in my signature. Then did 150 shot and got 537/590.
Torque increase by 212 and horsepower by 112, hp did not gain 150+ because as you see on the graph, after 6200rpm the nitrous run starts to go up and down. Any nitrous guys here have experienced something similar, how did you fix it or any recommendations?
2012 Mustang 5.0
Steeda CAI, Boss Manifold, 3.73 Gears, E85, NX Wet 150 Shot, AED Tuned, LT Headers, Aluminum Driveshaft, Mcleod Twin Disc Clutch, KB Bap, N2MB wot box w/ window switch.
Droidman86 is offline   Reply With Quote
Old 01-27-2016, 09:17 AM   #2
LuisBlackGT's Avatar
Can you post the whole graph
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 01-27-2016, 09:30 AM   #3
Droidman86's Avatar
Green is N/A and Blue is 150 shot nitrous run.
2012 Mustang 5.0
Old 01-27-2016, 02:05 PM   #4
I'd suspect spark blowout, but difficult to tell without seeing the A/F graph. What plugs and what gap are you running?
2012 Kona Blue GT 6M 11.80 @ 116
Koni STR.t shocks/struts, Steeda springs, BMR LCA, and Panhard bar, BBK off road X-pipe, Pypes axleback, whiteline shifter/trans bushings, Bama 93r tune, JLT CAI, Barton shifter, Shaftmasters 1 piece DS, CHE axle brace, factory HID conversion, and track pack Brembo and Recaro swap
Dave M is offline   Reply With Quote
Old 01-27-2016, 02:25 PM   #5
Droidman86's Avatar
gap 035 and 1 step colder ngk NGK (6510) LTR7IX-11 Iridium IX Spark Plugs
Old 01-28-2016, 12:02 PM   #6
Those should work just fine.
Can you post the A/F graph?
Old 01-28-2016, 12:54 PM   #7
Droidman86's Avatar
ok, I checked again spark plugs.
4 were gone, the electrode was gone and it had a gap of 40-42, not 35 as I previously thought. I will try to get a/f graph as it was not provided.
2012 Mustang 5.0
Old 01-28-2016, 01:01 PM   #8
Ouch... Sounds like you may want check your timing on the bottle if you're melting plugs. I ran nitrous in my old 4.6 for years, and melted my fair share of plugs, and eventually a piston. I eventually had a flip chip with two different tunes so I could safely spray a 150 shot, but this was 10 years ago, and today you could just swap tunes with a global 4-5 degrees of timing pulled out for running the bottle.
Dumb question, but are you checking the content of your E85? Weak fuel could've caused melted plugs too.
Old 02-09-2016, 11:06 AM   #9
Droidman86's Avatar
problem was all the time, believe it or not, a very clogged vacuum line for the BOOST A PUMP. Boost a pump was not working, so changed installation to run it all the time.
2012 Mustang 5.0
Old 02-09-2016, 11:20 AM   #10
Luckily you caught the issue before you hurt the motor. I had the same issue years ago with an NOS inline pump that quit working.
Old 02-09-2016, 01:19 PM   #11
Only one way to run BAP on these cars, full on. The ECM will cap the pressure at 58 anyway. Always better to risk a couple hundred buck BAP than a 10K motor.
nitrous
GT500KR Dyno Numbers Herbstang Pictures and Videos 2 09-23-2008 11:26 AM
new dyno numbers maximus 1996-2004 Mustang GT 3 09-07-2007 03:20 AM
Here's my dyno numbers......... 12second5.0 1979-1995 Mustang GT 19 04-08-2006 10:54 PM
dyno numbers jedwards242000 Pre-2005 V6 Mustang 7 04-17-2005 03:01 PM
Dyno numbers inside from Amazon Racing.. 03redfire cobra The Bar 19 10-27-2004 05:46 PM
10:51 PM
