Car wont stay running after download - Mustang Evolution
Old 01-28-2016, 05:46 PM   #1
tsidewayz's Avatar
Ok, I've got myself a bit of an issue.
I installed my JLT Carbon fiber CAI,
-ordered a new tune from AM for my SCT,
-checked tuner for most recent updates,
-downloaded new tunes.
-Attached battery charger to car
-turned off all lights and accessories
-Downloaded tunes and completed with no errors
Now the car wont stay running. It will start for just for a split second then die.
Downloaded stock tune and it still wont stay running. I'm waiting for a response from AM on this issue. In the mean time does anyone have any suggestions?
tsidewayz is offline   Reply With Quote
Old 01-28-2016, 06:14 PM   #2
BLKBETTY13's Avatar
Is your MAF sensor plugged in?
---------- Post added at 07:14 PM ---------- Previous post was at 07:14 PM ----------
Double check your work on your intake installation.
BLKBETTY13 is offline   Reply With Quote
Old 01-28-2016, 07:18 PM   #3
tsidewayz's Avatar
I believe it is. I checked about 5 times. The harness doesn't look damaged either.
But I will remove and reinstall it for ****s and giggles.
If it matters the car has 15K miles on it
Thanks.
Thanks.
Old 01-28-2016, 07:47 PM   #4
Ubnbit's Avatar
You had no issue before you installed the tune, I'm assuming? Bama will fix it bro. Any codes?
Old 01-28-2016, 08:03 PM   #5
tsidewayz's Avatar
Correct, I didn't have any issues prior too this download. I had been running a different tune from AM for sometime with no issues. I was back to stack for the last couple weeks waiting for the new CAI.
Old 01-28-2016, 08:05 PM   #6
Ubnbit's Avatar
You don't have a CEL?
Old 01-29-2016, 02:25 AM   #7
tsidewayz's Avatar
No CEL or codes. Checked that.
Old 01-29-2016, 03:45 AM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Is your MAF installed correctly? I've seen some people get issues after accidently installing the MAF backwards. There should be an arrow on it. Make sure it matches the flow of air.
2012 Kona Blue 3.7L V6:
Old 01-29-2016, 11:31 AM   #9
Did you try going back to the stock tune to see if you still have the issue?
2013 RedMustang is offline   Reply With Quote
Old 01-29-2016, 11:32 AM   #10
BLKBETTY13's Avatar
^ he said he did.
Old 01-29-2016, 12:58 PM   #11
Waynes World's Avatar
Region: Utah
Originally Posted by WhoDat View Post
Is your MAF installing correctly? I've seen some people get issues after accidently installing the MAF backwards. There should be an arrow on it. Make sure it matches the flow of air.
I installed mine backwards and it wouldn't stay running, I'll bet that's it?
Waynes World is offline   Reply With Quote
Old 01-29-2016, 03:38 PM   #12
Robostang's Avatar
Very easy to install backwards so don't feel bad if that it the problem.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 01-29-2016, 05:56 PM   #13
C013RA's Avatar
Could be the MAF, also very possible that there is a gap somewhere in the CAI install. Double check the throttle body, and make sure there is no gap there. Any openings especially between the MAF and the throttle body will raise hell.
Had 6 Mustangs. I now have a 2016 GT350. I don't see myself getting anything else now. Only mods are a resonator delete, and a GT350R wing. I love the power, and the handling. Prior to that I had a 2015 Performance Pack GT with the MT82 and a lot of mods, a 2012 GT/CS with the 6R80. To me that was a mistake. Only Mustang I ever had with an auto. Before that a 2001 Premuim GT with lots of mods. Before that a 2000 V6 My 1st Mustang mistake. Should have stuck with V8's. Before that a 1965 convertible also with a lot of mods.
C013RA is offline   Reply With Quote
Old 01-29-2016, 10:26 PM   #14
tsidewayz's Avatar
Well, got to thinking you guys might be right about the MAF sensor being backwards. Got home and checked.... sure enough it was. Feel like a total dweeb. But all is good now. Thanks for the insight.
Old 01-30-2016, 06:41 AM   #15
Robostang's Avatar
Like I said earlier, very easy to do. Don't beat yourself up about it. Mistakes is how we learn. Glad everything is good to go now!
Old 02-03-2016, 05:34 AM   #16
Ubnbit's Avatar
Glad you got it fixed bro. That's the main thing.
Why wont our profile pics stay??? FastFord13 ME Site Help & Announcements 5 06-06-2013 09:57 PM
car wont stay running 02StangGT 1996-2004 Mustang GT 4 01-17-2013 07:54 PM
car wont stay running 87blackonblack 1979-1995 Mustang GT 6 03-21-2012 09:51 PM
Stay on running lights uh60facilitator Mustang Paint, Appearance & Detailing 0 08-17-2011 12:19 PM
Car wont stay running Mustang1804 1996-2004 Mustang GT 5 06-17-2010 10:59 AM
05:23 PM
