AFR change at idle - Mustang Evolution
Old 01-29-2016, 10:07 PM   #1
ILLY's Avatar
AFR change at idle
I've notice that at idle after the car has warmed up the air fuel ratio moves from 13.5 to 15.5. The rpm drops and comes back up too. The rpm moves probably between 550-800. Feel like the car is about to die.
Car has the following mods; boss302 intake, jlt Cai, long tube headers with off road x pipe, tuned by AED. I installed all these mods at the same time. Didn't have this problem before when it was stock.
The car has a normal tune, not the ghost cam tune. Any suggestions are appreciated.
ILLY is offline   Reply With Quote
Old 01-30-2016, 06:46 AM   #2
Robostang's Avatar
Since it started when you installed the mods, I would check the intake and CAI installation. A vacuum/air leak in those areas could cause that problem.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 01-30-2016, 07:18 AM   #3
DallasStang77's Avatar
Yup probably a vacuum leak. When I installed the Boss manifold my mustang, the intake pipe was loose cuz as I was tightening it the coupling slipped off because it was not seated properly and was angled off. So when the engine started I guess it popped off.
Rough idle. I set it right and it was normal. Doubt it's the tune but you never know. They might have missed something.
1.) Check all points for vacuum leaks
2.) If still rough do a data log without WOT and very light normal driving and send it to tuner
Good luck
Old 01-30-2016, 08:18 AM   #4
Very likely post MAF vac leak, either in the intake pipe, tb or in the manifold install. A quick datalog of STFT will confirm this. These cars will still run with quite considerable leakage. The leaks can be tricky to find sometime bc of this. On an old car you could just propane the joints and get an immediate idle bump when you hit the leak. Not as easy with a fully closed loop modern car
Old 01-30-2016, 10:19 AM   #5
utm18's Avatar
Send Shaun some datalogs.
utm18 is offline   Reply With Quote
Old 01-30-2016, 10:59 AM   #6
ILLY's Avatar
I did send Shaun a datalog and he said that I might have an issue with the Evap system because the fuel at idle changes by 14%. I'll check again for vacuum leaks.
AFR's on the way what's everyone's favorite intake? JayKranz 1979-1995 Mustang GT 82 10-14-2012 06:09 PM
Where are afr heads casted at 2300turboford General Car Discussion 0 10-13-2012 02:09 PM
Afr heads, pushrod & rocker arm requirements Fischerwilson 1979-1995 Mustang GT 2 10-01-2012 06:55 AM
AFR 165s captain78 1979-1995 Mustang GT 34 05-09-2012 02:17 PM
Windsor sr (ported) vs afr 185s 93stroker331 1979-1995 Mustang GT 17 06-03-2011 06:57 PM
04:10 PM
