285/35 or 305/35 with sportlines - Mustang Evolution
Old 02-18-2016, 03:32 PM   #1
Fax22's Avatar
I am planning on getting 20x8.5/10 wheels for my car but was wondering with how aggressive the sportline drop is if a 305 width tire on a 10 wide wheel would cause some rubbing problems. I know 285 should be fine but I will take more rubber on the ground if i can.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Fax22 is offline   Reply With Quote
Old 02-18-2016, 05:00 PM   #2
Diehard's Avatar
May just depend on offset.
You should ask this guy, who is on this forum.
Originally Posted by LuisBlackGT
I'm lowered 1.5 with 305/35/20, no rubbing at all with +48 offset
I believe he has 305/30/20 now.
Old 02-19-2016, 11:16 AM   #3
VADER50's Avatar
I have the wrong off set and my 305s rub every so often when I just the right bump on the freeway.
2013 Mustang 5.0 with Boost N Things on E85
VADER50 is offline   Reply With Quote
Old 02-19-2016, 11:35 AM   #4
Sterlingbeast5.0's Avatar
I was told by a couple places not to go 305. I actually have 295 30 20 in the rear
Old 02-19-2016, 12:36 PM   #5
Fax22's Avatar
Ya the offset I would have is +45 so 305 might be pushing it
Old 02-19-2016, 08:49 PM   #6
The_Chech's Avatar
305/35/20 with the tire tucking with a 20x10 with +45 offset if this helps any. Also lowered maybe a good 2.5"+ or so
Name:	ImageUploadedByMustang Evolution1455940096.892406.jpg
2011 Kona Blue Gt
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-20-2016, 02:22 AM   #7
Fax22's Avatar
No rubbing over bumps?
Old 02-20-2016, 10:51 AM   #8
olerodder's Avatar
Region: Oregon
Although I had the OE GT500 wheels which are around .55 offset I ran the stock 285/35/20's and with the Sportlines I could have gone to a 295/35/20 but not any more.
Name:	2015-04-11 12.52.16.jpg
ID:	197265   Click image for larger version
Name:	2015-04-29 10.05.26 (640x291).jpg
Old 02-20-2016, 11:04 AM   #9
Diehard's Avatar
Yeah, 55mm offset is pretty high, pushing the tire inboard. I'll bet a 45 offset would allow a wider setup.
A 10mm difference in offset would equate to about a difference of 20mm in tire width.
Old 02-20-2016, 11:07 AM   #10
Fax22's Avatar
MMD 551C Charcoal Mustang Wheel - 20x10 100260 (05-14 All) - Free Shipping
^^^^^Wheels in question if anyone needs a better reference.
Old 02-20-2016, 11:42 AM   #11
Diehard's Avatar
BTW...305/35 seems to pushing it a bit for a 10" although it obviously works for The_Chech.
Also noticed makes for a 28.4" dia tire, which is taller then most.
Old 02-20-2016, 12:04 PM   #12
Fax22's Avatar
It seem like 285 or 295 is the way to go if I want to play it safe. Anything is better than the 245 P-Zero's on there now.
Old 02-20-2016, 02:53 PM   #13
olerodder's Avatar
Region: Oregon
With these wheels I could have added another 1-1/2" making them 11" wide without impacting anything except relocating the sway bar. I had planned on adding 2" on my TrakPak wheels which had an offset of 48mm...they still would have cleared although 19 tires are somewhat limited in anything bigger than 285's.
Old 02-21-2016, 06:57 AM   #14
GT CS's Avatar
I just bought 20 X 10 Niche Lucerne Black Chrome rims () with a 40 mm offset for the rear.
I plan on using 295 35's.
Any thoughts on potential clearance issues would be greatly appreciated!
GT CS is offline   Reply With Quote
Old 02-21-2016, 08:08 AM   #15
The_Chech's Avatar
I only had slight rubbing when hitting a huge pot hole or the car goes down a big hill under high speed causing the car to squat really hard. It never did any thing to the tire or fender well. You could hardly tell the tire even made contact in side the fender.
2011 Kona Blue Gt
285/40R18 VS 285/35R18 square set up M3hunter Mustang Wheels & Tires 8 05-14-2014 08:43 PM
285 35 or 285 40 JRT Mustang Wheels & Tires 20 04-18-2014 08:18 PM
Eibach sportlines or ford b springs? 98vertgt 1996-2004 Mustang GT 7 04-26-2013 04:27 PM
285,295,305 or 315 for 18x10 rims?? 1hotv6 1996-2004 Mustang GT 21 09-21-2012 10:21 AM
Pic Request: 10+ Eibach Sportlines.. CYCLON37 Pictures and Videos 15 04-19-2012 06:19 AM
01:37 PM
