93 vs e85 - Mustang Evolution
Old 02-21-2016, 09:12 AM   #1
MarkCoyote's Avatar
93 vs e85
Current mods 5C converter longtube headers 93 pump gas. Next mods cobra jet intake monoblade TB, driveshaft and k member. I want a 10sec N/a car and it's very few running 93. Is e85 a good switch for N/A ?
MarkCoyote is offline   Reply With Quote
Old 02-21-2016, 11:19 AM   #2
Grabber Blue5.0's Avatar
Yes it will help switching to E85. The downside though will depend on which brand of headers you have since E85 tends to kill o2 sensors rather quickly.
Old 02-21-2016, 11:22 AM   #3
The_Chech's Avatar
Which headers are on the car? Also you'll need a minimum of 47lbs injectors on the car to run E85
2011 Kona Blue Gt
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-21-2016, 07:02 PM   #4
I just switched to E85 today and the car pulls much harder and upon initial test run feels really good, You will be able to feel it in the butt dyno..
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 02-21-2016, 08:58 PM   #5
MarkCoyote's Avatar
Sorry for the delay but I have jba headers
Old 02-22-2016, 07:30 AM   #6
MarkCoyote's Avatar
Will I be ok?
Old 02-22-2016, 08:01 AM   #7
No the o2 sensors would need to be moved.
Old 02-22-2016, 08:06 AM   #8
Grimkreg's Avatar
Whats the mpg change from 93 to e85? Like if someone who did go e85 could say how many miles they got before compared to now
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Grimkreg is offline   Reply With Quote
Old 02-22-2016, 08:16 AM   #9
MarkCoyote's Avatar
Where would they need moving too
Old 02-22-2016, 08:37 AM   #10
Famine's Avatar
Region: South Dakota
Long Tube Header Fix With PICTURES! No More bad 02's!
Famine is offline   Reply With Quote
Old 02-23-2016, 09:49 AM   #11
Rickster_1823's Avatar
I dont think it is necessary to remove the O2 sensors but only locate them at an upwards angle. My theory is that Ethanol absorbs most moisture or water better than gasoline, just like any other alcohol (MTBE, ETBE).
what i would really like to know is if it is necessary to install bigger injectors when your major upgrades is just long tube headers? i dont see the bright light here.
---------- Post added at 10:49 AM ---------- Previous post was at 10:48 AM ----------
Originally Posted by Famine View Post
^^^this guy is got the right idea.
2013 5.0 DIB; Airaid, JBA LT Headers / JBA Off Road X Pipe to Cutouts; 4.10s; BBK Lower Arms; Barton Short Shifter; E85 BAMA race.
Rickster_1823 is offline   Reply With Quote
Old 02-23-2016, 12:45 PM   #12
REG
E85 Mileage
Expect a 20 - 25% decrease in fuel economy as the heat of combustion is less than gasoline, so you need more of it to produce the same amount of power. Also why you need bigger injectors. Octane rating will be higher, so you will need a tune and not all tuners are capable of working with E85.
2013 BBK Short tube, E-Force Stage 2, M/T 245/18/40 DR's, BMR LCA's, Alum D/S, Strange FRT adjustable struts
REG is offline   Reply With Quote
Old 02-23-2016, 05:44 PM   #13
Im not sure but what I have read, if you have a modded car you need injectors, longtubes are one of the biggest mods you can do to the coyote engine, so yes you need the injectors, I didnt buy a mustang for fuel mileage, and if you can gain 20 or more hp then yes its worth it, like I said earlier switching to e85 is a seat of the pants noticeable gain in hp, way better than a cold air kit or throttle body, but if you dont have access to it nearby then you shouldnt switch
E85 302fritz 1979-1995 Mustang GT 40 01-30-2011 11:06 AM
E85 testing on NA 08 Mustang GT 4.6L 3V justin00stang 1996-2004 Mustang GT 8 07-30-2008 01:49 PM
Anyone heard of E85? Dom The Bar 5 04-27-2006 12:20 PM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
11:55 PM
