UCA Adjustment Help - Mustang Evolution
Old 03-02-2016, 04:50 PM   #1
Fax22's Avatar
UCA Adjustment Help
I am getting a RTR UCA and bracket this weekend, and although I'm sure its out there, I couldn't seem to find any good sources on how the adjustment should be done. I am currently lowered on Eibach Sportline spirngs, which is pretty low. I know I need a measuring tool and I need to use the drive shaft angle on both sides to figure out the angle.
My 2 main questions are:
What measurement I need to get to be within a good specification?
What is the best tool to use when measuring?
Thanks in advance!
Fax22 is offline   Reply With Quote
Old 03-02-2016, 06:14 PM   #2
Grimkreg's Avatar
I forgot the degrees, but when I did mine I made sure to get it the same length as the one I took off and it ended up coming out to same spec when a shop measured mine. I think there is also a little bit of play in degree depending on what style of racing/driving you prefer.
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
Grimkreg is offline   Reply With Quote
Old 03-02-2016, 07:59 PM   #3
2013_DIB_GTCS's Avatar
I believe -2 degrees is where you want to be. Go search cj pony parts YouTube. They have a good video of setting pinion angle. I believe there are a few other videos on YouTube of pinion angle too.
2013_DIB_GTCS is offline   Reply With Quote
Old 03-02-2016, 08:08 PM   #4
Diehard's Avatar
Here's some stuff to look at
https://www.iedls.com/asp/admin/getF...&TID=28&FN=PDF
http://www.iedls.com/asp/admin/getFi...&TID=28&FN=PDF
PINION ANGLE DISCUSSIONS.docx
Old 03-02-2016, 09:40 PM   #5
Fax22's Avatar
Those links actually do help a lot. I also watched a couple videos on youtube about it that helped out. Thanks guys.
Old 03-03-2016, 08:31 AM   #6
-2 is MAX you want on a street driven 3 link car. any more puts the pinion bearing and/or seal at risk. I set mine at 1.9 using a simple angle finder app on my smartphone and a similar process to what is illustrated above. I used the rear half of the DS for my measure of DS angle, as that is what matters with a 2 piece shaft, not the transmission's position; then the pinion flange for the rear end's measure.
It's easy when you are able to conceptualize what you are looking at.
Old 03-03-2016, 09:40 AM   #7
Fax22's Avatar
Yes now that I am seeing the pictures it extremely easy to comprehend. I picked up a magnetic protractor today for 5$ but ill probably double check it with an app to see if there is any error. I am installing Saturday so I will let you guys know how it goes.
For Sale: BMR Rear suspension UCA, UCA mount, LCA, Brackets, PHB MOOSEDAWG29 Mustang Parts for Sale and Wanted 11 10-23-2015 02:14 PM
UCA Help Schram1 2011-2014 V6 Mustang 4 11-21-2013 09:15 AM
UCA Help 2013fiveO 2011-2014 Mustang GT 18 06-23-2013 08:17 PM
Worm shaft adjustment help 99redgt 1996-2004 Mustang GT 1 09-13-2012 05:40 AM
04:07 PM
