Leaky Breather Valves - Mustang Evolution
Old 03-04-2016, 07:51 PM   #1
5pointYoBro's Avatar
Why do these cars get the leaky breather valves??
I had an expansion tank on my old car, and am considering getting another.
Should I get the valve replaced too? Its all gunked up with oil
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 03-05-2016, 01:15 PM   #2
It's not an "expansion tank" that's for the cooling system. You mean an oil separator.
I think you'd rather have these "leaky" valves than the engine sealed up tight and be blowing crankcase gases past your rings and/or out of every gasket. These are supposed to leak to relieve crankcase pressure. Taking them out and cleaning them up does no harm but is rarely needed if you change your oil regularly.
Old 03-06-2016, 11:00 AM   #3
Nahh I'm talking about the valve on the top of the rear axle. It's on the passenger side
Old 03-06-2016, 12:53 PM   #4
Robostang's Avatar
I replaced my diff cover with the finned cover and while I was at it, I moved the vent to the top of the cover. Problem solved.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 03-06-2016, 01:08 PM   #5
OIC, well, Ford has a cheap fix in the form of an extended hose and turkey baster thing to catch this stuff. Steep ratio gearsets encounter this more due to the greater pumping action.
Old 03-14-2016, 09:32 PM   #6
Robostang: Is it the steeda diff cover??? And how do you plug up the original breather valve?? or do you just leave it as is?
leaky afr heads Leo92lx 1979-1995 Mustang GT 6 02-04-2013 08:56 PM
1996 GT Leaky gas tank? BILLFORD01 1996-2004 Mustang GT 4 08-13-2009 07:59 AM
leaky manifolds dshultz88 Pre-2005 V6 Mustang 1 10-19-2007 07:29 AM
Leaky top flyinggodiva New Member Introductions & Greetings 18 03-26-2007 12:40 PM
09:08 AM
