Power loss revisit - Mustang Evolution
Old 03-06-2016, 02:54 PM   #1
Power loss revisit
So I am revisiting my power loss on my VMP kit. Initially, after VMP looked through my datalogs, the conclusion was spark plug blow out causing the loss as well as potentially running out of fuel.
So I have swapped the Iridium plugs I had gapped at 0.028 to TR-6 also gapped at 0.028. I have also installed a Roush Fuel Pump Voltage Regulator.
I had it dynoed locally a couple of times, and according to the local tuner there is nothing he can see in the data as the power falls off ~5800 RPM (see attached) Throttle blade angle is being commanded, AFR is fine, boost is not falling off, IATs, Cylinder head temp, Fuel pump duty cycle, etc. all look kosher.
He didn't want to tune it if the tune was not the problem. One thing he did say that I should look at is the cats. A couple of months when trying to remote tune on the street, the CEL flashed indicating a misfire and that may have damaged the cats.
Would a partially collapsed/damaged cat be a culprit? Other leaks?
I really am at a loss at this point and frankly I am getting annoyed at throwing money at the problem. But that's life, amiright?
I am sending the data to VMP as well, but *any* opinions would help me.
FirstGeneration is offline   Reply With Quote
Old 03-06-2016, 03:50 PM   #2
Could be, definitely but, you shouldn't rule out engine damage as well. It would be good at least to do a compression test to verify you're solid there.
Old 03-07-2016, 12:09 PM   #3
"Engine damage" - the stuff of nightmares.
I am having the cats cut out tomorrow and having a pipe installed in their place as a trial-and-error. If that helps, I will just go take off the stock headers and get a pair of Kooks.
If that doesn't do anything, then I will work with my mechanic for a compression test.
If engine damage is a possibility, would it only show up at high RPM?
Old 03-07-2016, 12:59 PM   #4
Stuff like a soft valve spring, a cracked ring land or lifted head will be more noticeable at high load and rpm, yes.
No reason for panic, just eliminate it as a possibility.
93 POWER LOSS jcori3 1979-1995 Mustang GT 17 09-19-2006 06:41 AM
oil change. alignment. loss of power Dark02Pony Pre-2005 V6 Mustang 19 10-21-2005 10:39 PM
Revisit!!! Ugliest stang pic Danger Dude The Bar 32 04-02-2005 05:39 AM
Temporary Power Loss, Idiot Light BlueDonkey Pre-2005 V6 Mustang 6 11-04-2003 11:37 PM
power loss? 6erstang Pre-2005 V6 Mustang 7 09-03-2003 09:39 AM
04:53 AM
