Which gaskets when installing headers? - Mustang Evolution
Old 03-08-2016, 12:03 PM   #1
nicholasmadill's Avatar
I will be installing BBK longtube headers in about a week or so, along with an off-road X pipe. The headers came with the BbK gaskets.
I've heard lots of people saying the OEM gaskets are better.
The car has about 58,000km on it, should I re use the stock gaskets, the BbK gaskets, or pick up some new OEM gaskets?
Sent from my iPhone using Mu
nicholasmadill is offline   Reply With Quote
Old 03-08-2016, 12:13 PM   #2
scott_0's Avatar
I reused the stock gaskets and header studs and nuts
Sent from my S6 using tapatalk
Old 03-08-2016, 12:25 PM   #3
Get new gaskets. OEM. If the stock attaching hardware is studs then they should hold just fine but you will want to re-torque 2-3 times after a few heat cycles each time.
Ensure you use a torque wrench and go in the correct pattern and I'm really not sure why ppl will spend $$$$$ on headers and then try to skrimp on the gasket.
Old 03-08-2016, 04:34 PM   #4
Grabber Blue5.0's Avatar
I reused my stock gaskets and hardware. No leaks.
Old 03-08-2016, 06:38 PM   #5
Ok thanks a lot guys!
Old 03-10-2016, 06:53 PM   #6
Region: New Mexico
Yeah I know some people who just use RTV but I wouldn't risk it. New headers should come with a gasket right?
BlackCoyote is offline   Reply With Quote
Old 03-10-2016, 08:41 PM   #7
Every set of new headers I've bought has.
Old 03-11-2016, 03:50 AM   #8
The OEM gaskets are better than the ones that come with the manufacturers headers.
Old 03-11-2016, 07:21 AM   #9
Diehard's Avatar
Better as in, less apt to fail? Have the ones that come with the manufacturer's headers been known to fail?
Yeah, I used the latter.
Old 03-11-2016, 09:15 AM   #10
If you were to lay them both out side by side you would see the difference. And yes there have been failures with non OEM gaskets.
Old 03-11-2016, 12:44 PM   #11
Diehard's Avatar
No need to lay them side by side as I can recall they are like night and day. OEM were 3 sheets of metal riveted together while the BBK were a single layer of some type of graphite composite.
I saved the OEM which were like brand new.
Header Gaskets / What causes blown gaskets Slow4V 1996-2004 Mustang GT 14 10-24-2014 11:52 AM
Can you use stock exhaust gaskets with aftermarket headers? ponie1992 2011-2014 V6 Mustang 6 08-12-2014 05:46 AM
Use oem gaskets on headers Jlope014 Pre-2005 V6 Mustang 0 11-19-2012 07:17 AM
Which header gaskets and bolts are best for long tube headers? FordAddict 1996-2004 Mustang GT 15 05-30-2012 11:33 AM
Headers gaskets? Prados86gt 1979-1995 Mustang GT 4 04-16-2012 07:00 PM
04:56 AM
