Issue with lowering... advice needed... - Mustang Evolution
Old 03-08-2016, 04:47 PM   #1
Last year I lowered my car with SR lowering springs, J&M caster/camber plates, and koni orange shocks.
It lowered the car a bit all around and looked good. Performance-wise the car handled much much better than stock. The only issue is the ride quality went away entirely. The ride became jarring over anything but smooth roads.
So this week I finally got around to installing some BMR street springs on the front (I haven't gotten around to the rear yet). The ride is already greatly improved (although it doesn't handle as well as it used to).
The only problem is the car seems to have dropped much more than expected in the front. The BMR springs were advertised for 1-1.5 inches of drop yet my front looks slammed now. At the alignment shop today the best they could do was -1.5 camber on both sides of the front. While with the SR springs I was around -1.0.
Any ideas what could have caused this? Could this be a case of bad springs?
I noticed the shop that did the install - when using their spring compressor - compressed the spring and the strut mount (caster/camber plates) all together. Instead of just compressing the spring. Could that have crushed the strut mount?
Here's the before picture:
Here's after the new spring install on the front:
Edd2016 is offline   Reply With Quote
Old 03-09-2016, 10:35 AM   #2
Never mind... I installed the rear springs this morning and everything is back in balance now.
Apparently the BMR street springs drop the car a lot more than the expected 1-1.5 inches. Regardless, the car rides much better than with the SR springs. So I can't complain.
Here's a picture:
Old 03-09-2016, 10:41 AM   #3
Jbone007's Avatar
Did that also correct the alignment issue or have you had a chance to have it checked again, but it does look nice
Jbone007 is offline   Reply With Quote
Old 03-09-2016, 07:53 PM   #4
I figured I'd wait a week or so for the springs to settle before heading back to the alignment shop. I suspect there wont be any issue getting it back into alignment.
The pictures don't do it justice... the wheels looks really pinched under the front fenders before installing the rears this morning. Before my alignment yesterday it was -3 degrees on both side and looked like one of those import stance cars.
help needed for gas issue romeshs1983 2011-2014 V6 Mustang 90 11-13-2013 09:42 AM
lowering springs- what else 'needed'?! imhooked 1996-2004 Mustang GT 15 03-06-2013 11:23 AM
What all is needed for lowering? Jgill1992 2005-2010 Mustang GT 10 06-24-2012 02:08 PM
Xmission issue or clutch adjustment needed Nicks86GT 1979-1995 Mustang GT 10 04-06-2012 10:40 AM
Panhard bar needed for lowering? mcvicar04 1996-2004 Mustang GT 3 12-20-2011 08:47 AM
05:56 PM
