Cobra jet kit - Mustang Evolution
Old 03-19-2016, 02:46 AM   #1
Cobra jet kit
Where's the best place to buy the cj kit with the Oval tb?
TrpCAKirby2692 is offline   Reply With Quote
Old 03-19-2016, 10:11 AM   #2
MarkCoyote's Avatar
MarkCoyote is offline   Reply With Quote
Old 03-19-2016, 10:19 AM   #3
Tasca Ford
Old 03-19-2016, 01:27 PM   #4
10 4 thanks. Imma check it out I plan on doing that with arh longtubes off road x and idk what axle back imma go with yet
Old 03-22-2016, 06:34 AM   #5
anyone know where to get this kit with the monoblade oval tb?
Old 03-22-2016, 05:59 PM   #6
Jn2
Why do you want the mono blade TB? you are paying $500 more for it compared to the twin 60mm. Thats $500 for a 4, maybe 5whp gain over the twin 60mm. From the testing done over on SVT the gains between the different oval TB's is minimal at best, and non existent at worse. The main difference is cost.
Here is mine with the twin 60mm.
Jn2 is offline   Reply With Quote
Old 03-23-2016, 07:46 PM   #7
Famine's Avatar
Region: South Dakota
The Monoblade is worth it if you look at dynos comparing the two. I got mine for less than 555. I may be selling my entire setup soon though.
Famine is offline   Reply With Quote
Old 03-24-2016, 11:36 AM   #8
20Mustang13's Avatar
Region: Delaware
Anybody got a video of step by step installation of the Cobra intake? Like to see it
Sent from my ADR930L using Mustang Evolution mobile app
20Mustang13 is offline   Reply With Quote
Old 03-24-2016, 01:24 PM   #9
Jn2
Just watch the video on the boss manifold, all the bolts and lines are the same. Only thing it would not show is repining the throttle body.
13' Mustang GT w/Track Pack: Bottle fed CJ manifold, FRPP Intake,FRPP Monoblade TB, Speedmaster headers, Magnaflow 3" X pipe, Bassani quad tip ABs, Jn2uned, SRP Axles, MGW shifter, BMR LCA's
Old 03-27-2016, 08:57 AM   #10
Region: Delaware
Where do you relocate the purge valve and whatever hoses go on it?
Old 03-27-2016, 08:59 AM   #11
Region: Delaware
Does a hose go on. The bottom of the purge valve. Or does a hose go to the top of intake to the top of purge valve and what happens to the original purge line that went to the purge valve?
Old 03-27-2016, 09:06 AM   #12
Region: Delaware
And I have high idle anybody know
Old 03-27-2016, 12:14 PM   #13
Been thinking about the Cobra Jet, how much of a hindrance would Kooks shorty headers be over longtubes?
Old 03-27-2016, 05:09 PM   #14
MarkCoyote's Avatar
Is that oem gt500 tb?
Old 03-28-2016, 03:50 PM   #15
Famine's Avatar
How to Install a Ford Racing Cobra Jet Intake Manifold on your 2011-2014 Mustang GT | AmericanMuscle
Who is tuning the car?
Old 03-28-2016, 05:32 PM   #16
Region: Delaware
Am sent me a tune but the idle is fluctuating and then I lost the throttle. I turned off car and restarted it and it ran. It just doesn't want to idle right
Old 03-29-2016, 02:38 PM   #17
Jn2
Yes, its the OEM GT5000(twin 60mm). You can find them on CJPP for $130ish
Leave it hanging below the throttle body. you will re-use the OEM hard line and use a 3/8" hose to connect the only other port that's left open to the right port on the intake manifold.
Old 03-29-2016, 02:39 PM   #18
Jn2
Sounds like they need to work on your predicted angle tables. Either predicted angle is off or the effective area tables are off.
Either way, make sure you don't have any vacuum leaks, if not, then its either a bad TB or tune needs adjustment
Old 03-29-2016, 04:53 PM   #19
Famine's Avatar
Just call Shaun at AED and he will get your tune dialed in. I'm pretty sure that's what it is.
Cobra Jet Intake Kit...It's on! zinc03svt 2011-2014 Mustang GT 27 02-21-2016 11:54 AM
Cobra Jet Or not to Cobra Jet Jedimindtricks 2011-2014 Mustang GT 12 02-10-2013 09:10 AM
2010 Cobra Jet rickf73 General Mustang Discussion 32 04-16-2010 09:37 AM
The 2010 Cobra Jet (and a Wheelie) OsirisGuy Pictures and Videos 3 10-02-2009 01:09 PM
Job 1 FR500 Cobra Jet PureVenom General Mustang Discussion 7 01-19-2009 10:29 AM
08:42 AM
