Suspension Questions 2010-2014 - Mustang Evolution
Old 03-23-2016, 08:47 AM   #1
Mustang Coyote's Avatar
It's been said a thousand times "I was spinning" when it comes to a Mustang's traction.
What are the culprits of this? Is it a couple parts or the entire design of the suspension?
It SEEMS to me that Corvettes generally hook better judging from online videos? If that's so what is it about their suspension that's so vastly different than a Mustang's?
I know we aren't corvettes, I'm just wanting to build my knowledge on this because we all know power is useless if it can't be planted well.
Thanks for any info/links!
Mustang Coyote is offline   Reply With Quote
Old 03-23-2016, 09:08 AM   #2
Did you try looking here?
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Old 03-23-2016, 09:41 AM   #3
Mhmm
Old 03-23-2016, 09:45 AM   #4
Mustangs have wheelhop and spin issues due to soft rubber bushes in the rear arms. Replace the upper for wheel hop control and the lowers for ****s and giggles. As long as you aren't lowered you'll get some help here. If lowered you may need to put relocation brackets on to get your lower control arms aiming downward from the front mount to the axle.
The biggest single contributor to spin is inadequate tire size on this car. Even the Track Pack/Brembo cars only wear 255. 275 is what I'd say the car needs, minimum.
Old 03-23-2016, 10:37 AM   #5
Yep, after rear UCA the next larges contributor is track width... You can get an awful lot of that with tires. As stated if you've lowered your car, relocation brackets will be needed. They help add anti-squat which is what you are after initially. Chances are you will quickly firm up the suspension to the point where tires will be necessary to reap all the benefits.
To directly answer one of your questions. The mustang is not really all that different from other OEM applications. All OE stuff is for comfort and safety, you compromise performance to achieve that. Most if not all changes to your car to help it "hook up" better are no different than any other rwd car. The actual differences are which parts you change.
What have you done so far with your car? Do you plan on making changes? was this purely to learn, or are you considering something in the near future?
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-23-2016, 10:44 AM   #6
Thanks for all the info guys.
I'm lowered on BMR springs. I intend on buying their boxed lower with brackets and adjustable upper. I'm thinking I'll be ok with the stock upper mount?? I also intend to fit a 305 back their soon.
Old 03-23-2016, 10:57 AM   #7
I would not recommend under any circumstances boxed arms.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-23-2016, 11:05 AM   #8
Grabber Blue5.0's Avatar
Nope.
And the height of the sidewall is more important than the width of the tire.
Old 03-23-2016, 11:20 AM   #9
Originally Posted by Grabber Blue5.0 View Post
Nope.
Only in extreme cases, otherwise a wider tire gives a larger footprint, a taller sidewall does not.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-23-2016, 12:00 PM   #10
No way dude. You think a wide footprint with say a 30 or 35 series tire is going to hook with any decent power?
Old 03-23-2016, 12:23 PM   #11
Vs what?
I said extremes for a reason....
Old 03-23-2016, 12:26 PM   #12
Keep in mind the tire footprint goes both ways....side to side and front to back. Depending on what you choose, you can enlarge the footprint both ways.
No radial sidewall is worth a damn for transmitting power on road surfaces, even a drag radial. The radial carcass is just inherently stiff so, concentrate on tire compound and as big a tire as the rim will hold.
Old 03-23-2016, 02:13 PM   #13
Absolutely tire compound is important. As for the footprint I was generalizing. It is not entirely accurate to assume track width increases with tire width. However same for the sidewall height, all it does is generally modify the footprint to be longer and not wider but the overall area is more or less the same. Which leads into discussions about vertical load, tire pressure, etc.
However as it relates to the OP a wider tire will help after control arms and before anything else, we both agree there.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-23-2016, 07:12 PM   #14
Nope.
Okay, and why is that? It's best I go with a mount from the same manufacturer?
---------- Post added at 07:12 PM ---------- Previous post was at 07:12 PM ----------
Ok, why is that? What do you suggest I go with?
Old 03-23-2016, 07:18 PM   #15
If you are not going to get a watts link, then I'd recommend spherical bushings. Boxed arms have little to no flex at all and will bind and over time the axle articulation will damage the boxed joint since it is solid and has practically no give.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-23-2016, 07:20 PM   #16
Like a good old fashioned torsion bar, round tube resists twisting forces very common in the suspension action better than a box. a box, when twisted, will fail in mid flat bc of the work-hardening at the corners, if the stress is high enough. Round tube spreads the load all around the bar.
Old 03-24-2016, 10:13 AM   #17
Diehard's Avatar
How about the OP indicate what he has so far and go from there?
Based on his garage...
2012 GT with Track Pack
20x9/11 Saleen S197 rims, NITTO NT555 255/35ZR20 in front and 285/30/ZR20s in back, Eibach pro-kit lowering springs, aftermarket shocks & struts.
Old 03-24-2016, 01:07 PM   #18
Compstall's Avatar
To directly answer one of your questions...... ?
Now, directly answer what the best setup is for 1.70 or better 60's.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 03-24-2016, 01:10 PM   #19
A slick tire and upper and lower arms. On stock bbp springs, bars and shocks, that was good for 1.5 to 1.6.
Old 03-24-2016, 01:21 PM   #20
Rosariors3's Avatar
I'm at around almost 600whp. I threw on 275/60/15 MT drag radials. I'm hooking way more.
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
Suspension 2014 mustang gt 2014 auto waspo 2011-2014 Mustang GT 15 10-27-2014 01:39 AM
front suspension questions white98gt 1996-2004 Mustang GT 3 12-13-2010 08:20 AM
Suspension questions?????? CC plates? Panhard bar? Camaro Eater Pre-2005 V6 Mustang 4 07-02-2010 09:47 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
10:55 PM
