Where to now?? - Mustang Evolution
Old 03-23-2016, 05:19 PM   #1
Famine's Avatar
Region: South Dakota
Where to now??
Ok, so first, let me list what I have currently.
2013 brembo m6
Ported cj manifold
CJ monoblade
Frpp Intake
SW longtubes
OR Xpipe
gt500 AB
373's
Shaftmasters one piece ds
BMR adj UCA
BMR LCA w/ relocation brackets
Koni yellows
FRPP k springs
BMR adj panhard bar
275 nt05's all around
AED tune
MGW shifter on the way.
So I'm looking for the next step. My tuner recommends against cams, but that's really all that is left to stay n/a. I wanted a nice n/a build with this car since my last 5.0 was a brenspeed 650r setup. I was thinking Stage3 Comp Cams without the limiters, but I have been informed that valve float would be an issue. No other cam setups have really been recommended due to this. I was thinking add boss valve springs and then those cams, but I'm not sure if I should continue down this road at this point. Any advise on a tad more power. I wanted to get to 500whp for a weekend fun car with the occasional non-competitive autox. I'm starting to think I should switch my goals to a nice Paxton w/ torque booster setup from beefcake. Anyone out there have any cam advise that could keep me on the n/a track? If so, what setup and do you have any helpful documented builds?
Famine is offline   Reply With Quote
Old 03-23-2016, 07:38 PM   #2
If you want 500 horse N/A, you're going to need to open the engine up and do some headwork, springs and yes, cams. Then rev it to the moon, Alice!
Old 03-23-2016, 07:41 PM   #3
Rapinator126's Avatar
Won't need head work
LSX 408 FTW
Dragging your a$$
Old 03-23-2016, 07:48 PM   #4
Rosariors3's Avatar
Not true bud I'm pushing almost 600
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 03-23-2016, 07:50 PM   #5
Rosariors3's Avatar
My bad misunderstood the post
Old 03-23-2016, 07:50 PM   #6
Famine's Avatar
I need more specifics on the cams. Do I need springs, which set to go with, limiters or lockers, etc. I was told if I was going to do it, go with stage 3 comps on the intake side, and stage 1 exhaust, both with boss springs with no limiters. Any opinions?
Old 03-23-2016, 07:54 PM   #7
The stage 3 intake and stage 1 exhaust is good for a daily driver and great on drivability and tuning.
Boss valve springs are fine with the comps no limiters is correct.
LSX 408 FTW
Dragging your a$$
Old 03-23-2016, 07:57 PM   #8
But when it comes to cams on the coyote I always recommend a custom grind. And deleting the VCT and phasers. For a real NA build
LSX 408 FTW
Dragging your a$$
Old 03-24-2016, 03:22 AM   #9
Really? 500 wheel and not even a port cleanup, just stock casting? Not rejecting just amazed that Ford would feel the need to improve in the head for 15 if that was true. I love this engine; under promise and over deliver seems to be its motto.
Old 03-24-2016, 04:44 AM   #10
Famine's Avatar
LSX 408 FTW
Dragging your a$$
Why this route? Isn't it beneficial to implement the vtc tuning into your can choice to help mitigate the low end loss associated with high lift/duration cams? As long as you keep from going too far and creating a ptv contact situation. I wondered how reliable the phasers can be going that route though.
Old 03-24-2016, 04:59 AM   #11
been talking to Shaun I see.
A real NA build, where you run a real cam you have to delete the VCT and phasers.
LSX 408 FTW
Dragging your a$$
Old 03-24-2016, 05:00 AM   #12
I think most people pushing the envelope here aren't towing a boat or trundling to the shops. Vct adds a lot of spinning weight to the ends of the cams. Ditching the stock phasers and locking them makes for quicker rev pickup and more stable cam timing under duress.
Plus I expect it gets to be a ***** to tune, as you add lift and duration, you start running out of space to put things wrt advancing/retarding the cams and enter into a potential interference situation?
Old 03-24-2016, 08:13 AM   #13
Famine's Avatar
Do you guys know any independent dyno comparisons for different setups (not shops pushing a product)? Yes Shaun in who I was talking with and with his background, I was inclined to go with his recommendation; however, when there is something I know little about, I tend to want to do more research on the matter before doing anything and I have never done cams on any vehicle. You may laugh at this, but I was a long time Honda guy and they have been playing with i-vtec where you could do the same type of cam advance and retarding and it was always a must to get the most out of the car; of course in those cars, you needed every bit of torque from advancing the timing on the low end, as you could.
Now heir this now heir this Mrsnow Shelby Mustang 1 02-19-2012 08:23 PM
Chevy trucks now come with VTEC!! .:DarkEntity:. The Bar 10 08-04-2003 11:58 PM
got springs, now what? sp33d Pre-2005 V6 Mustang 15 08-01-2003 07:44 PM
*DUW* Got my engine stuff, now to work on it all. n8r Pre-2005 V6 Mustang 4 07-22-2003 11:07 AM
Had the Brushed Aluminum GT's, now.... Ken Pre-2005 V6 Mustang 5 07-18-2003 01:09 PM
04:29 PM
