Input on TT vs. Single Turbo? - Mustang Evolution
Old 03-25-2016, 07:22 PM   #1
What is your guys' input on going twin turbo vs. a big single turbo. what are the pros or cons to each? any input is appriciated!
BettyWhite5oh is offline   Reply With Quote
Old 03-25-2016, 08:08 PM   #2
TT is quicker spooling, instant power. Single means a compromise A/R turbine side because it feeds off 8 cylinders worth of exhaust so, it has to be big and that means generally requiring more effort to turn and thus more delay. There are ways around this, like twin scroll but, those are more complex solutions OEMs typically use. The pipe runs on the hot side of a single are more complex when fitted to a V engine and that can contribute to lag and packaging issues.
Downside of TT is packaging two turbos, their oil and drain lines and coolant hoses, two turbos to go wrong instead of one and underhood heat.
TT is definitely preferable on a street car, in this application.
Turbos are hardcore, man. It's A LOT of fiddly assembly work, even on expensive systems and generally lots of niggly maintenance hassles down the road a few years.
I built my own TT kit out of junkyard parts years ago on my 88 5.0. Holy **** did that make power, until it squeezed out its head gaskets. It was a blast. Then, I went with a centri blower, which was much easier to tune and lower maintenance.
I'd kinda think of it this way, if you like your car to wow with hood up at car shows or on jackstands, go turbo. If you want to drive it everyday, go SC.
Old 03-25-2016, 08:33 PM   #3
Whats the usual time span of the engine after installing either the supercharger, turbo or TT, or even supercharger? I know it depends on how hard you push the car and how often, but is there a normal time frame for how long your motor will generally last after installation?
Old 03-26-2016, 12:02 AM   #4
No reason to expect that it will last less long if you properly maintain the car and don't get greedy. I put TT on my old 5.0 with 200k on the motor. It was stillmaking healthy compression so I did it and it made the same healthy compression when I took it off....once I'd fixed the notoriously leaky Windsor head gaskets. HG was kind of a wear item on the 302. This engine was made for boost from the get go, by the engineers who designed it.
A single turbo Blackedout Pre-2005 V6 Mustang 147 06-23-2011 08:29 AM
Single turbo gt 04machazblue 1996-2004 Mustang GT 0 04-03-2011 01:46 PM
Installing a single turbo hp ? 2007STANG Pre-2005 V6 Mustang 20 01-09-2010 01:36 PM
03 GT Single Turbo Question TransAxle 1996-2004 Mustang GT 26 08-10-2007 06:16 PM
single turbo on a v style engine? fast64 Pre-2005 V6 Mustang 2 04-22-2004 07:28 PM
06:23 PM
