Sway bar relocation - Mustang Evolution
Old 03-26-2016, 05:19 PM   #1
Fabio_5ohh's Avatar
Sway bar relocation
Hey everyone so I'm about to order a set of SVE 15x10 rims and I'm seeing I have to buy the sway bar relocation bracket in order to use those rims.
I currently have the white line lower control arm relocation brackets installed, have any of you guys had any issues with the sway bar rubbing on the relocation brackets?
Fabio_5ohh is offline   Reply With Quote
Old 03-27-2016, 07:00 AM   #2
Can't say but, also can't see how it would, give the sway bar relos just move the bar up the shock mount a tetch. Why so much wheel? Power adder?
Old 03-27-2016, 05:20 PM   #3
grabber12's Avatar
Are you talking about where the sway bar has the bend in it? mine rubs right there. Not sure if it hurts anything but when I did the relocation brackets for my 15x10 wheels I didn't like how it touched at the bend. Was going to just relocate the entire sway bar one day.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 04-01-2016, 09:25 PM   #4
Fabio_5ohh's Avatar
Ima install the relocation bracket on Wednesday so I'll find out then.
Yeahhh this is going on soon just getting my car ready for it Click image for larger version
Name:	ImageUploadedByMustang Evolution1459563875.589105.jpg
Old 04-01-2016, 09:28 PM   #5
Fabio_5ohh's Avatar
Yeahh that's where I've heard it rubs , I'm hoping maybe I could grind away a little bit of the lower control arm bracket ? I shall see soon. Just wanted a heads up .
Old 04-01-2016, 09:35 PM   #6
Rapinator126's Avatar
Lol at people trying to step it up in the nitrous game.
LSX 408 FTW
Dragging your a$$
Rapinator126 is online now   Reply With Quote
Old 04-01-2016, 09:49 PM   #7
I'm certainly liking the N2O....
Old 04-01-2016, 09:59 PM   #8
Fabio_5ohh's Avatar
LSX 408 FTW
Dragging your a$$
step it up? How so? I'm just trying to go for a good hidden setup.
---------- Post added at 02:59 AM ---------- Previous post was at 02:58 AM ----------
Thanks man
Old 04-01-2016, 10:05 PM   #9
Yeah, hide that nicely, clean install. I kinda did the same with my setup.
Old 04-01-2016, 10:17 PM   #10
Fabio_5ohh's Avatar
What's your setup ?
Old 04-01-2016, 11:03 PM   #11
Nx plate, completely hidden under the cover, every line and wire covered in split loom, bottle hidden under trunk floor. Simple 100 shot.
Old 04-02-2016, 12:42 PM   #12
Why hide it? Never once wanted to hide anything.
And that DP is far from hidden. And haggard
LSX 408 FTW
Dragging your a$$
Old 04-02-2016, 02:19 PM   #13
I'm not a show-off and, I want to see how long I can psych my friends at the track with this strangeley-fast stock Mustang. Plus, the car will likely blow through the cage limit on a 100 shot and I want to be able to say, "I dunno, it's stock" and thus get the stock car/no-cage ET break in the rules.
It is kinda hard to hide a direct port, true....
Old 04-02-2016, 11:22 PM   #14
05saleen's Avatar
Do you guys have any experience with the Nano set up? My buddy used it on his vette and it seemed to work very well. I was thinking about it for my car.
Rab- set up advise?
05saleen is offline   Reply With Quote
Old 04-02-2016, 11:42 PM   #15
Don't go with budget systems. You'll want more and these systems won't support it without a lot of add one. Coyotes are a little touchy with nitrous delivery. LS motors don't really care as much how it gets into the engine.
I like NX and Nitrous Outlet, or, more expensive, JMS for this application.
Old 04-03-2016, 10:24 AM   #16
05saleen's Avatar
I was going with the nitrous outlet system and the nano 3000 psi set up. Also with the NOS controller. I'm also using the cobra jet intake.
I plan on adding a procharger when I do the bottom end
Old 04-03-2016, 07:25 PM   #17
05saleen's Avatar
I started a new thread for my questions, sorry if I was off topic.
Old 04-03-2016, 08:23 PM   #18
Courteous of ya, see ya over there.
This place is by far my favourite Mustang board. Not always a tech heavy as I like but people generally behave with good humour and dignity here.
Old 04-04-2016, 12:29 PM   #19
bsyo1021's Avatar
So my set up is very close to the brackets but the bar has a very small amount of clearance. I'll try to get a picture of it up later. I will say I have an adjustable rear sway and I had to orient the bolts in a way that way would clear or atleast touch less.
Edit: Let me just clarify and say I have the sway bar relocation bracket (for the 15x10s) and I have the whiteline LCA relocation brackets as well.
2012 GT with lots of stuff. ---> Overview Video: https://www.youtube.com/watch?v=tn7qoKqQXwY
Updated Exhaust clip: https://www.youtube.com/watch?v=UtxWRQlREmY
bsyo1021 is offline   Reply With Quote
Old 04-04-2016, 02:17 PM   #20
If you've got clearance of any amount it won't change. You could also just grind the bar slightly and paint it if you need a little more.
This is going to happen with all this aftermarket stuff back there.
Old 04-12-2016, 12:59 PM   #21
Fabio_5ohh's Avatar
So I ended up having to grind away at a little bit of the brackets so the sway bar wouldn't be rubbing against them
Name:	ImageUploadedByMustang Evolution1460483911.584311.jpg
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 01:38 PM
Sway bar relocation bracket issue grabber12 2011-2014 Mustang GT 8 08-14-2014 05:24 PM
Rear sway bar relocation bracket; hard to install? jrolivo1975 General Mustang Discussion 4 04-19-2014 06:12 PM
Sway bar relocation?? McQueen 2011-2014 Mustang GT 12 12-04-2012 07:43 AM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 07:37 PM
11:44 AM
