Passenger side engine tick.. - Mustang Evolution
Old 03-28-2016, 06:32 PM   #1
Billgluckman's Avatar
2014 gt, lund tuned, o/r x, borla s, 33,xxx miles
Took the car out for a ride this weekend and started hearing the noise so I brought it home to inspect. The noise is hardly audible when standing over the engine, but very noticeable when standing on either side of the car.
The noise is definitely coming from the passenger side. I used a stethoscope against the exhaust manifold to try and determine which cylinder the noise was coming from. I couldn't decide if it was # 2,3, or 4. Did some googling, found this...
5.0 Coyote Tapping/ Ticking/ Knocking - Ford Truck Enthusiasts Forums
..great. Now I'm not sure this isn't a valve train issue, but there seems to be a lot of people with cyl 4 problems so I'm expecting the worst.
Has anyone with a tune/exhaust car had this issue fixed under warranty? Should I even try to take it in?
Billgluckman is offline   Reply With Quote
Old 03-29-2016, 11:00 AM   #2
5pointYoBro's Avatar
I think I read something about the water pump causing a ticking noise.
Look up TSBs for the coyotes
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 03-29-2016, 01:35 PM   #3
This is not coming from the water pump or the the a/c. It's coming from the engine. It can be heard with a stethoscope on cylinders 2,3, and 4.
I'm stopping by the local dealership today to ask about the warranty. If I can't get it warrantied, I'm sending off for an oil sample test.
Old 03-30-2016, 05:21 AM   #4
I talked to a shop supervisor at a local dealership and he told me to reload the stock tune and he'd call me with an appointment. I'll keep this thread updated because I know there are others with this problem.
Old 03-30-2016, 05:37 AM   #5
RWSRWS's Avatar
This is the reason I won't do a tune till my factory power train warranty expires
Rwsrws
2013 GT Premium (auto) Crystalline,factory 19”wheels, black rocker stripe & heat extractors, redline armrests, Silverhorse windows Polk/Infinity speakers, Dynamat GT500A-bcks 1963 Studebaker Avanti R2 Factory Supercharged still own1938 Studebaker President still own 1969 Mustang Coupe, 302 Blue (sold 1978)1966 Aurora Thunderjet 2+2 Fastback - yellow w/red stripes (owned since age 9)1968 HOT WHEELS Redline Mustang 2+2 Gold - owned since age 11
RWSRWS is offline   Reply With Quote
Old 03-30-2016, 09:22 AM   #6
Honestly, if the engine is going to do this, a tune isn't going to be the cause. Frankly, I can't drive this car untuned, it's just so soft and flabby compared to the tuned version I can't stand it.
I had my transmission rebuilt when it imploded on my last car with a tune on it. They didn't even look or care but, in this case it might be more of an issue. The OP is best served to slap the stock tune on there like advised.
I think the plate kit might be my biggest obstacle if warranty work on the engine or powertrain is required.
Old 03-30-2016, 10:56 AM   #7
Rwsrws
If I could do it over I would have waited.
I agree stock tune vs performance tune is night and day but it's an excuse for ford to void the warranty.
Old 03-30-2016, 01:41 PM   #8
You just have to find the right dealership.
The one I bought my car from guaranteed they would still work on it under warranty if it was flash tuned.
As long as there is no signs of abuse, like going 20,000 miles without changing the oil
Old 03-30-2016, 03:40 PM   #9
RBK
Does a tune on a completely stock engine really make that much difference? What do you notice most about having a tune put into the car?
RBK is offline   Reply With Quote
Old 03-30-2016, 04:01 PM   #10
better throttle response, increased torque and power.
I put my fully loaded 2012 BBP GT into the 11s on a mild 91 tune and tire so, that should tell you what a tune does.
Old 03-30-2016, 05:17 PM   #11
I wonder if Lund tune was too aggressive. I have a bama tune but thinking about going with vmp since they are local.
buddyrich14 is offline   Reply With Quote
Old 03-30-2016, 05:26 PM   #12
Lund is an industry leader so, unlikely. I do like my Vmp tune though. Chosen bc automatic.
Old 03-30-2016, 05:29 PM   #13
I too went with the auto. I chose bama because I heard Lund was too aggressive. I am a newbie to mustangs so I just read a bunch of forums and bama seemed the safest. What do u like better with land over vmp? I am open to anything. Bama doesn't seem aggressive enough in the low rpm range
Old 03-30-2016, 07:36 PM   #14
Vmp or Mike Rousch for auto, no question. Lund is not "too aggressive", either but, the first two on auto.
Old 03-30-2016, 09:19 PM   #15
I use Bama but only cause it's free lol. If not I would use MPT or get a dunk tune.
On another note, my car makes the same ticking noise when idling after just starting her up. After a few minutes of warming up it goes away
Old 03-30-2016, 10:28 PM   #16
*Dyno tune not dunk haha.
Damn autocorrect
Old 03-31-2016, 06:20 AM   #17
Mine does not go away. Seems to get louder as it warms up.
Old 03-31-2016, 06:34 AM   #18
Region: West Virgina
Mine was bad at one point and went away entirely (crosses fingers). I posted a youtube video of it:
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 03-31-2016, 10:43 AM   #19
Mine sounds different than yours. Mine is consistent with rpm. It's a consistent tick and if I give it gas the tick just gets faster. I may try to get a video.
Old 03-31-2016, 11:45 AM   #20
It's not an exhaust leak??? Like headers or something?
Old 03-31-2016, 03:15 PM   #21
No definitely not. I wish it was.
Old 03-31-2016, 06:52 PM   #22
Video of the tick.
Old 03-31-2016, 07:41 PM   #23
Yeah, that don't sound right. This one needs a look. Can you do a compression test?
Old 03-31-2016, 07:58 PM   #24
It's going to dealership under warranty.
Old 03-31-2016, 08:08 PM   #25
Good.....
Old 04-04-2016, 04:02 PM   #26
Dropped it off today. I really don't trust dealership guys with my car. This is killing me. lol
I'm not sure what i'll do if they tell me this is normal..
Old 04-04-2016, 04:13 PM   #27
oxford5pointoh's Avatar
Which is exactly what they will do. Lol.
Old 04-04-2016, 04:22 PM   #28
owwww yeah that doesnt sound anything like what im talking about. You cant even hear mine in a video, and it goes away when you rev it, and eventually gone once it warms up.
At least you have the warranty though
Old 04-04-2016, 05:25 PM   #29
^^^Warranty is a great thing if they take it serious.
There's nothing normal about it. If i can't get it fixed I'm most likely gonna have to get rid of it, and I really don't want to.
Old 04-04-2016, 07:42 PM   #30
There is no way anyone can say thats normal.
Maybe the BS problem with the front control arm bushings that are noisy, and only because it happens to so many cars.
But something like this I dont think so.
Make a big enough deal about it, or go to corporate and it always gets taken care of.
Old 04-04-2016, 07:50 PM   #31
Jus play it cool. Trust me, the first person who loses their composure here loses the fight.
It took a month to get my trans repaired on my last car and, I'm a fighting union vice president and these were some of the toughest negotiations I've ever done.
Eventually it got done and the car was fine after that, until I killed it.
Old 04-06-2016, 01:34 PM   #32
The dealership called today and said my aftermarket headers were leaking and it would not be covered under warranty and I'd be charged a diagnosis fee. Funny thing is, I don't have aftermarket headers.
Old 04-06-2016, 01:48 PM   #33
Lol, this is getting good...idiots.
Old 04-06-2016, 01:51 PM   #34
Wow. You didn't buy it used tho did you? Maybe it does and you didn't know? But if it doesn't you should run far away from that stealership.
Old 04-06-2016, 04:34 PM   #35
Well I couldn't stand it anymore and I left work early to drive out to the dealership and talk with them. To make a long story short, I think they put the janitor on the job. The old guy wasn't even in ford dealer uniforms like everyone else. I ended up getting the shop supervisor to take a listen to the car and he agreed it didn't sound like an exhaust leak. He told me he'd call ford and see what he should do next.
Now, I haven't talked to anyone in the shop but the supervisor, but he seems professional and intelligent. I'm hoping he calls me back with better news tomorrow.
who on here is living with engine tick Mustangman705 1979-1995 Mustang GT 5 10-01-2013 12:55 PM
update engine tick Mustangman705 1996-2004 Mustang GT 1 09-26-2013 09:59 AM
TICK TICK TICK Mustangman705 1996-2004 Mustang GT 13 09-21-2013 06:30 AM
Tick when engine is cold Mikeyt03 2011-2014 Mustang GT 24 11-08-2012 05:59 PM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
» Members Mustangs
LaFawnduh
raceneck2000
Jessi
miket89
Add your Mustang
» Recent Discussions
01:38 AM
