E85 Conversion - Mustang Evolution
Old 04-02-2016, 04:38 AM   #1
Region: New Mexico
E85 Conversion
So was looking to convert my mustang to E85 within the next few months and was wondering what all I would need to run it safely. I'm gonna go with ID1000s for the injectors. Was wondering if anyone could recommend a fuel pump to go with, and/or the required lines I would need. If I am missing anything small please let me know, I'd like to be aware of everything I would need,big or small. Also as gauges go, would it be in my best interest to go with a fuel pressure gauge or would an air/fuel ratio gauge be enough? Thanks.
BlackCoyote is offline   Reply With Quote
Old 04-02-2016, 06:06 AM   #2
Grabber Blue5.0's Avatar
Injectors and a tune are all you'll need.
Old 04-02-2016, 07:55 AM   #3
Pump changes don't benefit when using the stock system, because the pump voltage is controlled via the ECM and is capped at 54 psi. A boost a pump is a good addition to an e85 setup using the stock system, especially FI.
Why are you contemplating this? You have a heavy power adder or are planning one?
Old 04-02-2016, 10:06 AM   #4
utm18's Avatar
I just did a e85 flex fuel tune from AED. All I needed was #47 injectors.
utm18 is offline   Reply With Quote
Old 04-02-2016, 10:11 AM   #5
Totally plausible. ID1000s suggest a desire to go hard core with a power adder. They are totally overkill for an N/A e85 tune.
Old 04-02-2016, 10:25 AM   #6
all you need is 47lb inj and a tune, and regardless if your adding a power adder it makes a noticeable difference N/A
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 04-02-2016, 02:46 PM   #7
Yeah. 47lbers, tune, and rap suggested to me a BAP as well. Kenne Bell has one that I am most likely going with.
G x crSent from my iPhone using Mustang Evolutionôh
Old 04-02-2016, 03:01 PM   #8
Jn2
If you are NA, get 47's and a tune. You do not need a fuel pump for this, the injectors will supply enough fuel to keep you going even on E100...
13' Mustang GT w/Track Pack: Bottle fed CJ manifold, FRPP Intake,FRPP Monoblade TB, Speedmaster headers, Magnaflow 3" X pipe, Bassani quad tip ABs, Jn2uned, SRP Axles, MGW shifter, BMR LCA's
Jn2 is offline   Reply With Quote
Old 04-02-2016, 04:24 PM   #9
Region: New Mexico
Well I plan on getting a S/C as well within the week so that's why I chose the ID1000s in the first place. So besides that just tune and a bap? Cool thanks for the info!
Old 04-02-2016, 05:37 PM   #10
BLKBETTY13's Avatar
Should've mentioned that in the start brother...
BLKBETTY13 is offline   Reply With Quote
E85 conversion Sunnycalibear 2011-2014 Mustang GT 18 06-21-2015 03:57 PM
E85 conversion Mweigt07 2011-2014 Mustang GT 7 09-18-2012 07:13 PM
E85 testing on NA 08 Mustang GT 4.6L 3V justin00stang 1996-2004 Mustang GT 8 07-30-2008 01:49 PM
Anyone heard of E85? Dom The Bar 5 04-27-2006 12:20 PM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
06:53 AM
