All auto gt's select shift? - Mustang Evolution
Old 04-02-2016, 04:59 PM   #1
How do u all feel your car has the most power and pick up? Auto , sport mode or select shift mode? I just started playing around with all of them.
buddyrich14 is offline   Reply With Quote
Old 04-02-2016, 05:07 PM   #2
leave it in D, it has been tested on the strip its the fastest. The only time i use sport mode is driving in city only because it holds gears longer and as for the select shift its probably the worst out of the 3 but its an option for some who wants to do some manual shifting with a button.
13' Mustang GT, A6, Whiteline adj. phb & support brace, Roush a/b, Boss 302 brace, Pioneer door speakers, Alpine 10" 500 Watt RMS Amp and Sub, Michelin Pilot Super Sport
winkawak is offline   Reply With Quote
Old 04-02-2016, 05:11 PM   #3
Sometimes it feels more responsive in select shift mode because you can control the power range.
Old 04-02-2016, 05:38 PM   #4
Select shift is for imitating a manual on the backroad. It's pretty good for that, for an automatic. D and S have the same upshift behaviour. S just locks out the second overdrive and downshifts more aggressively and will hold you in the overrun at higher revs.
Frankly, I love having 3 shifting choices. I usually leave it in S around town. I go up and down hills and the upshift behaviour under light throttle is a little early so the engine can end up lugging a bit, popping it down a gear manually instead of putting your boot down is a preferred alternative to me.
Old 04-02-2016, 05:40 PM   #5
DiESeven's Avatar
I pretty much only use select shift for on ramps so I can hold 3rd and then punch it. Then I slide it in to drive.
Instagram: @v6beast
Old 04-02-2016, 05:43 PM   #6
The one thing I hate is when u hit it you have that split second down shift (I call it a hesitation) before it takes off like a rocket
Old 04-02-2016, 06:09 PM   #7
That same split second would have been you moving the gear lever in a manual but, I understand what you mean.
Old 04-02-2016, 06:44 PM   #8
grabber12's Avatar
In D is best but when I'm racing and it spins just a little in 1st it automatically shifts to 3rd then back to 2nd. Most annoying thing ever!!!! When its a money race I always shift manually because I cant afford for it to play the shifting game. It did it with the Bama tune and it does it with the Mike Roush tune so it might be a safety feature.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 04-02-2016, 07:23 PM   #9
It's part of the programming to regain traction. If you have traction it won't do this. get better tires or traction aids.
When I am on the road, I slightly pedal second so, i won't do this on the upshift when it wants to blow the tires off in second.
Old 04-02-2016, 08:31 PM   #10
grabber12's Avatar
I would really like to put the 13-14 auto shifter on my 2012 so I have the shifting capability with my thumb. I think its much more then just a shifter swap. anyone have info on that. Im thinking my trans isn't even programmed for a button shift.
Old 04-02-2016, 08:57 PM   #11
Yeah it is major. You need to change the instrument panel cluster, ECM and harness and use something like VCM to get all the parts to agree.
Old 04-03-2016, 06:25 AM   #12
FastFord13's Avatar
Its a little worse then that. After a test drive with the auto I felt the transmission was very clumsy. The Oem shift tables are terrible.
Sent from the future.
Old 04-03-2016, 06:56 AM   #13
A tune helps but I still want it quicker. That was my issue. Would a more aggressive tune help that? Thanks to this forum I will be going to vmp to see what Justin can do for me.
Old 04-03-2016, 07:15 AM   #14
It might but the stock converter will always be the thing holding it back slightly. In normal driving, the car tends to fire out strongly then dip into a relatively torqueless part of the powerband and that feels like a bit of acceleration softness. Heavy throttle tends to just incinerate street tires.
People forget that you can at least count on reliable performance Jn a straight line compared to the crapshoot that is every launch with the stick.
Old 04-03-2016, 07:25 AM   #15
FastFord13's Avatar
Its really not a crapshoot with a stick at all, I've missed a gear twice in four years, that's probably in the vicinity of 99.9% success rate. If someone is missing gears once or twice a week or so maybe stick isn't for them.
But yes an auto will hit its marks 100% of the time as opposed to my 99.9%, but its not always fun going from first to third then second with the auto's skip shift eco poop either so....
Old 04-03-2016, 07:48 AM   #16
DiESeven's Avatar
Tune will get rid of the skip shift thingy. Thankfully.
Instagram: @v6beast
Old 04-03-2016, 07:55 AM   #17
It's not a crapshoot for missing gears, it's a crapshoot for maximum accleration and repeatability. I've done A LOT of instrumented testing here, hundreds of passes at the dragstrip, on slicks; testing a lot of different launch techniques. There is no way that one gets anywhere near consistency here compared to the auto. If you really think you're John Force here and that you'll get 99.9% perfection here with a stick, you're delusional.
A tune or unplug of the solenoid ditches the skip shift.
Old 04-03-2016, 07:56 AM   #18
FastFord13's Avatar
Instagram: @v6beast
+1.
I'm not hating at all on the auto or why someone will chose an auto over a stick, and I hate when stick guys crap on auto guys.
A tune really helps the auto's with better shift tables, which is the biggest problem with the Oem auto Imo.
Old 04-03-2016, 08:12 AM   #19
There is a marked difference between the 11-12 autos and the 13-14, aside from the inclusion of select shift. The tune on the motor is better factory and the shifting performance is tighter. It still benefits hugely from a tune but, it was definitely better, even as delivered.
Another thing is the stick cars really need work in the shifter dept and, rear suspension control, right out of the gate. I've owned both types of 5.0 and I have extensive drag racing experience over decades.
Old 04-03-2016, 08:39 AM   #20
grabber12's Avatar
Tune never fixed my 1st to 3rd issue. Like I said I used bama & Mike roush.
Old 04-03-2016, 08:49 AM   #21
You can't fix that, it's not a tune issue. It's a traction issue. Fix that, and you'll have no issue.
Old 04-03-2016, 08:53 AM   #22
FastFord13's Avatar
The car I drove was a 13. If that was better I'd hate to drive the 11/12.
A 70$ bracket cleans up the shifting nicely.
Old 04-03-2016, 09:04 AM   #23
Is that not what a 2 step is for? I can honestly say after having one installed my launches have been perfect.
2013 mustang v6 premium package
Powder coated gold metallic wheels
MPT ghost cam tune
Quarter window louvers
3.55 gears manual
2008 fz1
Chris44117 is offline   Reply With Quote
Old 04-03-2016, 09:06 AM   #24
..but it does nothing for the wheelhop and the tendency for the rear axle to race the body to see who can get to the ditch first. Other critical upgrades on MT are an upper control arm at least, with LCAs and a panhard upgrade recommended.
A two step? Just to get a launch right? That isn't a good idea in a near stock car with cats in. A two step also won't necessarily help you with the clutch engagement action. You'll still need that to get that right.
My testing revealed that 4500 rpm was the sweet spot. High enough to not bog on the slicks. It wouldn't 60' any faster launching at higher rpm. I was dumping the clutch with a matching mat of the accelerator. 1.5 60' best. I know the auto won't do as well as this with the stock converter in, that's reality, especially with the 28" slick tires I have that I used to keep the 3.73 stick car in 4th through the stripe.
Old 04-03-2016, 09:33 AM   #25
FastFord13's Avatar
Your clearly a auto fan and ONLY run a 1/4 mile at a time.
Wheel hop is not anywhere as bad you say it is in a daily, maybe if your just running a 1/4 at a time it will become an issue, but your going to tell me that if your serious about running 1/4s with your auto car your going to run the stock rear suspension? I didn't think so, just saying.
I know your still upset about your stick crapping out but your logic on stick vs auto is flawed.
If you prefer auto that's fine, I hold nothing against them.
Old 04-03-2016, 10:00 AM   #26
Dude, I ran the stick for 3 years, on and off track. I've been driving stick for 35 years. I've had one automatic performance car in all that time: a 1974 Trans Am with a Turbo 400.
I'm not upset about the stick crapping out at low miles. Ford fixed it and that's it. It was fine after that. I'd still be driving the car if I hadn't wrecked it putting a blower on it.
The wheelhop on the road IS that bad and that's well documented. On the track, it's less of an issue because the surface is prepared and the slick tires gave full traction. Nonetheless, the minor tweaks I did out back there did help, I think.
I am running a suspension setup similar to what I had on the stick car because I took the parts off the stick car and I might as well use them. The car didn't need the help, nearly as much, that I can confirm.
Old 04-03-2016, 10:10 AM   #27
Nobody talking about the Eco boost but that thing has some pickup. I have one of them 2 but it's the wifeys car
Old 04-03-2016, 10:19 AM   #28
Because it isn't relevant at all to this discussion and this is the 11-14 GT section.
Old 04-03-2016, 10:44 AM   #29
FastFord13's Avatar
Just saying, anyone who is going to do serious track time IS going to do suspension work, auto or stick, that is also well documented.
Lets just face the fact that the solid rear axel isn't the greatest starting point for a great handling car and will always need help from the aftermarket world, auto or stick.
Old 04-03-2016, 10:53 AM   #30
I'll give you that but, wheelhop was very much less on the automatic version of this particular car. It isn't nonexistent, even after adding the bits but, it is much more settled, stable and converts power into forward motion more easily.
The up side of a stick axle is strength and, inexpensive mods to improve performance. I would rather have a reasonably sorted stick axle than a bad set of ideas in an IRS. Fortunately, it looks like Ford finally got an IRS right in the S550.
Old 04-03-2016, 11:05 AM   #31
FastFord13's Avatar
I really hope they did get it right in the S550, its been a long time coming.
13' AT select shift problems Nvrfastenough87 2011-2014 Mustang GT 0 05-04-2015 05:56 PM
Can a tune enhance performance in select shift mode? bazinga11 2011-2014 Mustang GT 10 12-26-2014 10:29 PM
Select shift clunking austin0324baird 2011-2014 V6 Mustang 17 02-07-2014 08:09 AM
2014 select shift automatic shifter AmericanBulldog 2011-2014 V6 Mustang 3 01-15-2014 02:11 PM
2014 Mustang Select Shift Issues Luis1991 2011-2014 V6 Mustang 4 08-06-2013 01:01 PM
10:15 PM
