Suspension Mod Questions - Mustang Evolution
Old 04-03-2016, 04:48 PM   #1
I am modding the suspension on my 2014 GT Brembo, I will be getting the KONI Sport adjustable shocks and struts with H&R super sport springs. But i also want to replace my original strut mounts since they will clunk and make noise if reused. I just want to be clear that I Should buy the 05-10 KONI Shocks and struts so the GT500 mounts are compatible. Does this mean I have to buy the 05-09 H&R springs as well? I want the 10-14 springs cuz they drop 1.7F and 2.4R as the 05-09 drop only 1.9 in the rear.
Here are links to the parts that I am hoping will work. Please let me know!
The Springs I want -
https://lmr.com/item/HR-5169077/H-R-...-11-14-5169077
https://lmr.com/item/KON-0510AD/Koni...-Mustang-05-10
https://lmr.com/item/LRS-18183A/must...rut-mount-0514
ALso, If anyone has this setup can you please give some input on if the KONIs handle this drop well? How is the ride? Thank you!
visback is offline   Reply With Quote
Old 04-04-2016, 09:53 AM   #2
5pointYoBro's Avatar
I dont think 11-14 springs will fit 05-09 Shocks/Struts.
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 04-04-2016, 10:53 AM   #3
oxford5pointoh's Avatar
Yes they will no problem. Plenty of info about this and why it's done
Old 04-04-2016, 11:56 AM   #4
Damn forreal??
Im debating on selling my bc racing coilovers and getting eibach sportlines and koni's.
It's cheaper to get the 05-09 shocks/struts with the gt500 strut mounts instead of $300 caster camber plates
Old 04-04-2016, 11:59 AM   #5
Yeah if you are just trying to get low and not going extremely low CC plates are a bit overkill. You can get away with the GT500 mount flipped with the 05-09 struts.
Old 04-04-2016, 11:59 AM   #6
ZombieSlayer's Avatar
I know I have a V6. But suspension-wise, it should be similar to the 5.0s.
I can confirm the 05-14 suspension is almost the same (besides the front struts). I also went with the 05-09 front Eibach struts so I could utilize the GT500 strut mounts
ZombieSlayer is offline   Reply With Quote
Old 04-04-2016, 12:07 PM   #7
The ride quality of my 3.7 with the coilovers wasn't too great, real bouncy, I tried adjusting and whatnot.
So I haven't put them on my new car yet, still debating. Either sportlines and shocks/struts or save up for air ride
Old 04-04-2016, 12:46 PM   #8
It makes me sad with the predominant lack of suspension knowledge in the stang community...
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Old 04-04-2016, 12:52 PM   #9
The problem is somewhat costs vs how well people can get EVERYTHING to do it right.
Most people go the cheapest and imo the worst route with springs and a panhard bar. Which IS cheap, but it is not the correct/full way to lower these cars. Since the suspension is different on these Mustangs vs. other cars. On other cars, you can sometimes get away with cutting the springs or putting lowering springs on.
Then you look at the cost of what it really takes to get a full suspension setup ($1,000+). Not everyone has that.
Me personally, I told myself I wasn't going to do anything suspension-wise until I could afford to get everything. I don't see a point in taking apart the stock strut assembly, installing aftermarket springs, and then 20,000 miles later going back and installing aftermarket struts to match the damper.
But everyone has their own opinion...
Old 04-04-2016, 12:57 PM   #10
Yep, you're spot on. I'm already over 2k on custom valved bilsteins, thats before bump stops and springs.. I had no idea when I started really looking how involved it would be and before I bought the koni STrs just how bad off the shelf stuff is. I will say this though, the H&R springs and Steeda spring rates have not been horrible. But yea it would be silly to swap springs but not dampers for travel length and matching valve settings.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 04-04-2016, 01:02 PM   #11
Diehard's Avatar
Don't be sad!
With a community of this size there is a very wide range of experience/knowledge and only a very small number of the community are logged in at any one time.
Feel free to help educate or ask questions.
Old 04-04-2016, 01:08 PM   #12
Very true. I also went with doing the whole deal at once because with the 1 piece aluminum driveshaft, you have to get an adjustable rear upper control arm to fix the pinion angle on a dropped car.
Old 04-04-2016, 01:24 PM   #13
I had all the right parts, just the coilovers aren't the greatest quality, but I mean, you get what you pay for
Old 04-04-2016, 01:32 PM   #14
I have heard some great stories about coilovers. But they usually are in regards to the more pricey ones for other types of cars. I have yet to hear a bunch of people swear by any coilovers for our S197s. As far as the BC or SR coilovers.
Old 04-04-2016, 01:50 PM   #15
Your best bet is to match different springs with off the shelf coilovers for mustangs. The right way is custom everything. I allmost want to buy these and try them out:
CorteX, Double Adjustable Coilover System, 05-14 Mustang
but in the end I think going custom is the best bet for budget vs quality
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 04-04-2016, 03:44 PM   #16
I'll probably end up keeping them and put on soon.
The bc coilovers are good for what you pay.
Old 04-04-2016, 06:57 PM   #17
Thanks for all the replies, I wanted to do everything right on the suspension. I am going to be getting the KONI Sport adjustables with Maximum motorsport road and track springs (1.9F - 2.1R) with Maximum motorsport Caster / Camber plates (stock mounts on stock struts with SR Performance springs are clunking) and shorter bump stops. Still considering the adjustable end links but since I wont be tracking the car not sure if it is necessary for the little tweaks.
Old 04-04-2016, 07:00 PM   #18
Renuco612's Avatar
Damn forreal??
Why you selling the BC racing coilovers? Just wondering because I'm considering buying that setup. Do you not recommend them? How much are you trying to get and how many miles you got on them?
Renuco612 is offline   Reply With Quote
Old 04-04-2016, 07:50 PM   #19
I was just thinking I could get better ride quality with some Koni's and springs.
They have like maybe 10,000 miles on them.
But I'm pretty sure im going to keep them.
For cheaper coilovers (under $1000) they are good.
Old 04-04-2016, 08:09 PM   #20
Be nice....this doesn't help anybody....
Old 04-04-2016, 08:11 PM   #21
QUOTE=5LHO;2352535]Be nice....this doesn't help anybody....[/QUOTE]
It wasn't intended to be mean. But I didn't feel like getting on a soapbox either. So I left it at sad.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 04-04-2016, 08:14 PM   #22
I bought BBP because it was the best the factory offered. It ain't horrible. I don't want lower because I live in a real world of chuckholes and ragged pavement and I drive the car daily. Plus I'm slightly disabled and lower = harder to get in and out.
I did start with tightening up the rear arms and poly bushing the PH bar. If I was to do anything piecemeal, I'd get (after tires) shocks first, on stock springs.
Jerry's mod ( J-mod ) or shift kit Antdroid23 Pre-2005 V6 Mustang 1 07-26-2014 01:23 PM
First suspension mod i should do PBrown92 1996-2004 Mustang GT 6 09-21-2013 06:33 PM
Whats your suspension mod list ? Slow4V 1996-2004 Mustang GT 16 08-25-2013 11:13 AM
Best Mod and Worst Mod Rcary 2011-2014 V6 Mustang 30 06-04-2012 06:26 AM
What's the best suspension mod electricstang Pre-2005 V6 Mustang 34 04-22-2006 12:16 AM
07:04 AM
